Connect LCD to Raspberry Pi Without Breakout Board
40,325
445
33
Published
Introduction: Connect LCD to Raspberry Pi Without Breakout Board
About: Make it yourself if you cannot buy one!
This instructables show how to connect LCD to Raspberry Pi (RPi) without breakout board.
Step 1: Why?
I would like to make a MINTIA game console with RPi like my previous project:
https://www.instructables.com/id/Arduino-MINTIA-Gam...
LCD with breakout board is too thick for this project so I need direct connect LCD to Pi zero.
Step 2: Preparation
LCD
Any ili9341 SPI LCD should work. TM022HDH26 is the smallest SPI LCD screen I can found that have 320x240 resolution. It is 2.2 inch in size and use ili9341 chip (Thanks to Adafruit, RPi have very good support for ili9341).
FPC Ribbon Flat Cable
LCD and FPC ribbon flat cable have various pitch, it is required both at the same pitch. E.g. TM022HDH26 is 0.8 mm pitch so it should choose 0.8 mm pitch FPC ribbon flat cable.
RPi Board
Any RPi board can work. If you are using Pi Zero and yet soldered the pin header or do not want to solder it you may refer my previous instructables how to access the GPIO:
https://www.instructables.com/id/Testing-Pi-Zero-Wi...
Step 3: Read LCD Terminal Definition
Various LCD have different terminal definition, it is very important find and read the LCD data sheet first.
According to the TM022HDH26 data sheet, it need connect pin 2 to pin 9. I have skipped LED brightness control circuit, so I simply connect pin 10 to pin 9 and pin 11-14 to pin 8.
Step 4: Cut the FPC Ribbon Flat Cable
TM022HDH26 require connect pin 2 to pin 9 terminals, so trim the FPC ribbon flat cable to 8 lines only.
Step 5: Patch the FPC Terminal
The FPC ribbon flat cable is too long for this project, so I cut it in half and use a rasp remove the plastic cover.
Step 6: Soldering Work
  1. apply some flux to the FPC mental part
  2. apply some solder on the mental part
  3. align the FPC to LCD pin 2-9
  4. solder FPC pin to pin together
  5. solder LCD pin 9 and pin 10 together
  6. solder LCD pin 8 and pin 11-14 together
  7. solder FPC other side to pin header for testing
Step 7: ​Connect LCD to Raspberry Pi
LCD pin 2 RESET -> RPi pin 22 GPIO 25
LCD pin 3 SCL   -> RPi pin 23 GPIO 11 (SCLK)
LCD pin 4 D/C   -> RPi pin 18 GPIO 24
LCD pin 5 CS    -> RPi pin 24 GPIO  8
LCD pin 6 SDI   -> RPi pin 19 GPIO 10 (MOSI)
LCD pin 7 SDO   -> RPi pin 21 GPIO  9 (MISO)
LCD pin 8 GND   -> RPi pin 25 GND
LCD pin 9 VCC   -> RPi pin 17 3V3
Step 8: Test LCD
There are various document teach how to connect SPI LCD to Raspberry Pi, here are the summary:
spi-bcm2835
fbtft_device
  • Add to file /etc/modprobe.d/fbtft.conf
options fbtft_device custom name=fb_ili9341 gpios=reset:25,dc:24 speed=48000000 rotate=270 fps=30 bgr=1
  • install fbcp
sudo apt-get update
sudo apt-get install cmake git
git clone https://github.com/tasanakorn/rpi-fbcp
cd rpi-fbcp/
mkdir build
cd build/
cmake ..
make
sudo install fbcp /usr/local/bin/fbcp
  • auto run fbcp at boot time
sudo echo "/usr/local/bin/fbcp &" >> /etc/rc.local
  • find and edit the config in /boot/config.txt
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=87
hdmi_cvt=640 480 60 1 0 0 0
disable_overscan=1
dtparam=spi=on
  • reboot RPi
Ref.:
https://github.com/notro/fbtft/wiki
https://learn.adafruit.com/adafruit-pitft-28-inch-...
https://learn.adafruit.com/running-opengl-based-ga...
Step 9: Happy Hacking!
Once you can connect LCD without breakout board, you can create your project in much small scale!
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Creative Misuse Contest
    33 Discussions
    I cant find /etc/modules-load.d/fbtft.conf
    I have one question, how would i connect the touch pins to the raspberry pi?
    Thanks
    Hi sam57719, the LCD in this instructables does not have touch panel. If you have one in your LCD, please refer to the pin definition according to it's datasheet.
    kooth
    2 years ago
    Very nice! That is some delicate soldering! Thanks for sharing your Instructable!
    What a great guide... Wanted to say to Kooth.. that... this fine of soldering is easily done more by utilizing solder paste on the lcd board connections as a relatively inexspensive high quality soldering unit that incorporates both solder iron and hot air solder iron is as important as a base tool... as it is to always have a full set of US and Metric wrenches... using a 1/2 inch wrench.... on a 12 mm bolt head... much like dating our own sisters... :) is something we just don't do... ( don't know why.... my sister is kind of hot ) :) The solder paste method is the easiest way to solder a chip to a project board with chip solder locations... lots of good videos on YouTube on that practice... Gr'eat INSTRUCTABLES posting
    @Music Videoe, thanks for that info, I'll check it out!
    However, "we" can say that about your sister, but it'd help if you posted photos (of your sister....)
    Just a note to remind people to use 3.3V as you describe and not 5V like I did. It will work, but gets very hot and will probably burn out eventually. I was used to using the screens with breakout boards that included a voltage regulator on them and just connected there by habit. The bare screen doesn't have a voltage regulator and so should only be powered by 3.3V.
    need more details
    about it ... mainly input device
    what further detail you want to know?
    Where did you buy the pi Zero? they seem to be out of stock everywhere.
    I left my email at pihut and waited 2 months.
    Does the TM022HDH26 have touch controls?
    I saw a couple for sale on aliexpress, but they don't. There's a ili9341 screen on adafruit that does, but costs a lot more, and I'm curious if it's needed...
    Yes, I can found 2.4 inch ili9341 screen with touch sensor.
    Hello ! can any one here tell me where to buy this lcd screen in France??
    Thanks for sharing this. I have a small lcd 2inch from a vivitar camera would like to know if I can use this?
    Thanks
