Construction Folding Boats From Polypropylene Sheet
20,699
111
31
I have already had experience in building boats "Skif" of wood. As a result of its use, I wanted to make the boat as light in weight and with the possibility of storage under the bed or under the wall in the garage.
Supplies:
Step 1:
Bring to your attention the process of building a folding boat made of polypropylene own design. The boat was conceived light, compact, reliable - stability, maneuverability and ample. I sailed on a boat over 300km and is fully satisfied with the result! Boat weight about 40kg in the assembled form. Board height 50cm, width 1.20 m, length 3,75m. Transported on a car roof. Very stability. Under the motor 3.5 hp with 4 people on board is 10km / h, with one person speed of 12km / h. Going on shore in 9 minutes.
When folded, the boat is a flat pack size 4 * 0.60 * 0.05 meters. Paddles and fin fit inside, sitting separately.
Step 2:
To build the boats need 4 pieces of 5 mm thick polypropylene. I chose 4m long sheets of them to get a boat length of 3,8 m.
First marked out the pattern on the sheet and cut out using a jigsaw. Next, using the manual milling machine cut grooves along the edges of the sheet to be able to bend side and bottom that allows you to fold the boat. Milling depth of 0.3 mm slot width 5mm.
Further, the sides and the bottom are connected by means of bolts and nuts. Between the sheets used sealant. Assembly of the half boat check for leaks, collect water inside. Leak should not be. Next, connect the two halves of the boat and check for leaks again.
Step 3:
In the boat has three seats. It can is 4 people. Aft transom mounted to the motor. The seats are attached to the sides of the bolts. Under the seats installed units buoyancy foam. Under the seats and floating keel blocks is inserted to enhance rigidity.
Step 4:
General view of the patterns represented on the photo. Good luck!
Step 5:
And now the boat with steering and remote control gas and reverse.
video
Step 6:
Files with the plan board, and the bottom of the seat.
New video
Step 7:
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    31 Discussions
    Tahquitz
    5 months ago on Step 5
    Previously I assumed this was to be stored flat and I pondered use of 1/4 turn fasteners like Dzus. I included a link with details.
    Now I understand this is not stored flat and ponder using pop rivets for less
    Tahquitz
    5 months ago
    Great project. I was having trouble figuring out the joint until I read ALL the details. Since you want to store this in winter, are you unbolting everything? Are there any 1/4 turn fasteners that would save assembly/disassembly time?
    asi2007_ukr_netTahquitz
    Reply 5 months ago
    Hello, glad that you liked my work)
    I keep the boat assembled as there is a place in the garage. Prior to that, at the end of the season, he disassembled it and stored it in folded form.
    What did you mean - quick build 3/4 turn? Is it about the seat assembly? Did not think about it. Perhaps there is a solution ... Where are you from?
    NikolayP12
    9 months ago
    Hello,
    I looks really nice, great job. I was searching for detailed drawings how porta bote was made, however when I saw your work, I really liked it. I plan to build, or at least try to do it with 3 meters long PP sheets (not sure how much load will be able to take then, but we will see). I will share the result later :D In case it is convenient, I would like to ask you to share the dimensions you used when doing the curves, so I could avoid wrinkles. last but not least thanks for sharing your idea.
    Thanks in advance.
    I wish you great day ahead!
    asi2007_ukr_netNikolayP12
    Reply 9 months ago
    Thank you for your interest in my work!
    I'll be glad to help.
    Let me know the email address and I'll send you the blueprints.
    Where are you from?
    I would make a 4m boat. Better more than less!
    NikolayP12asi2007_ukr_net
    Reply 9 months ago
    Hi again,
    My mail is nikolay.parvov@gmail.com. I am from Bulgaria, Sofia. This night I was thinking the same better more than less, so I will try to find sheets with 4m length. So far I have found 3,00x1,50m, but I will search for longer ones.
    Thanks!
    Have a great day!
    WillF43
    Question 11 months ago on Step 6
    Where and how did you apply the silicone sealant? Is it just on the seams inside the boat?
    1 answer
    asi2007_ukr_netWillF43
    Reply 9 months ago
    Sorry did not see the comment. I used silicone only at the seams.
    asi2007_ukr_netsoyebravat
    Answer 1 year ago
    Hello!
    Thank you for appreciating my work :)
    a) What nuts and bolts did you use? galvanized bolts M5 length 18mm
    b) How many of the eddas you scored? looks like an inch? - I do not remember exactly, about 350 pieces, after 15 mm.
    c) Why are there 2 bars on the back? - I did not understand the question?
    d) Have you used a special type of sealant or will you do it? (I hope to do this for fishing). - a common silicone sealant for bathtubs.
    e) Is the boat suitable for fishing and salt water? - Yes
    f) How much cargo can a boat, such as a hold - 300kg
    g) What kind of material is foam under the seats? - polystyrene for insulation, polystyrene
    h) Can you use the boat in heavy waves of bad oceans? - for large waves, I would increase the height in the bow. If you swim alone, then the risk of pouring a wave through your nose - no. But if the boat is loaded - I would increase the height. It is necessary to increase the curvature of the lines and the nose will rise. Try on a carton model in scale 1:10
    I) Do you have pdf? I called, but they do not seem to sell 4 million sheets here in the UK. Max, which I can get, is 3 meters. I'll have to do it less, but I can not wait to do it.
    I have a DXF and a JPG file.
    Look for a polypropylene sheet in rolls. It is used for the construction of pools and reservoirs for water, sewage. If in Ukraine there are 2 * 4 m in the UK for sure :) It is better to make a boat with a length of 4 m, especially since you want to use it in the sea.
    Write to me on the mail: asi2007@ukr.net
    soyebravat
    Question 1 year ago
    Love your project and I'm very keen to making one myself.
    I would like to ask you:
    a) What kind of nuts and bolts did you use?
    b) How much from the egde of the pieces did you mill in? looks like an inch?
    c) Why are there 2 bars sticking out at the back?
    d) Did you use a special type of sealent or will any do? (I'm hoping to make one for sea fishing.)
    e) Is the boat suitable for sea fishing and salt water?
    f) How much load can a boat like this hold
    g) What kind of material is the foam under the seats?
    h) Can you use the boat in heavy waves bad oceans?
    I) Will you have a pdf? I called around but they don't appear to sell 4m sheets here in the uk. Max I can get is 3meters. Will have to make it smaller but I cannot wait to make this.
    dongiulio
    1 year ago
    Wonderful design, thanks, I love it. It is a bit too big for me though, if I make it only 3 meters long, should I keep the other dimensions unchanged, or should I scale them too?
    Also I'm not sure where to find the polypropylene, will keep looking
    asi2007_ukr_netdongiulio
    Reply 1 year ago
    Thank you for evaluating my work!
    Yes, you can resize up to 3m.
    Such sheets are on sale.
    Look for the size of 2m by 3m, so there will be no waste when cutting. Polypropylene sheets are used in the construction of pools and reservoirs for water and sanitation.
    Ask them. Where are you from?
    biomasterification.
    2 years ago
    Nice job bro. I’m Amir and I’m from Malaysia. I just want to ask you
    about the material that used for the hull. I saw that you used PP sheets. What
    if I use HDPE sheets instead of the PP sheets and what’s the pro and cons
    between the two materials for building the folding boats? Glad if you willing
    to share. I can be contacted via WhatsApp +60192644102 or email
    ultegraxt@gmail.com
    asi2007_ukr_net
    3 years ago
    But, i dont have plans in pdf, vector. I have plans on a paper:(
    I specifically made boats photo pattern with a high position so you can increase them without strong distortions.
    To translate the drawings into electronic form I need time and opportunity to do so.
    And I do not know how to do it efficiently.
    How long do you want to do a boat? What is your name?
    Euripedes
    3 years ago
    Please plans in pdf, vector etc. Thanks from Brazil. euripedessolucao@hotmail.com
    wing
    3 years ago
    How did You prevented wrinkles in the process of "folding" the fastening curved edge? (see the attached picture to better understand what i mean)
    Hello. Unfortunately, the pattern of the boat is not in PDF format, there are patterns on paper. Principle to get a pattern you need to increase and draw the outline of parts of the boat in the picture where there is a view from above. I am sending you this picture. If you are familiar with your computer is not difficult.If you could not, I'll try to make the photo paper patterns in high quality pictures.
    Glad you liked my design. I added a video where the boat had steering and remote motor control.
    https://www.youtube.com/watch?v=CJp0R-h2gfA
    Good luck!
