Copy Your Keys With SUGRU
38,830
397
53
Lost a key & want to -make- a new one? Use SUGRU to shape a key with Epoxy.
Supplies:
Step 1: Prepare the Key
Step 2: Use a Holder
Step 3: Insert the SUGRU in the Holder
Step 4: Put the Key in the SUGRU
Step 5: Press the SUGRU So the Key Will Be Formed
Step 6: Add Epoxy Too the Key
Step 7: Use the Malls to Insert Epoxy
Step 8: Wait for 10 Minutes & You Have Made Yourself a New Key!
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    53 Discussions
    dflynn5
    2 years ago
    First useful instructable on Sugru I have seen. Thanks for sharing.
    Breezy58
    4 years ago on Introduction
    Pay the $2 for a double-sided key at your Home Center. Much cheaper to make a few spares. Safer,too. I imagine that epoxy dust(from the grinding action) would get into the cylinder.I agree that this was a 'secret ad'.
    bkotlins
    4 years ago
    This is a Sugru ad. Every instructible KoenA1 has done is a quicky Sugru "project".
    ralenti
    This isn't a very good or clever instructable. I would've liked to see the finished product instead of a stock photo. Also, how did you attach the epoxy key to a handle? Does it last for more than a few uses? I imagine the teeth would be worn down by the cylinders, filling the lock with epoxy filings.
    Syd0the0kid
    Do you have a photo of the finished key made of epoxy? The one here looks like a stock photo and I'm interested in know how well the copy works compared to the original. My car key cost $135 a piece and it would be nice to have an emergency copy in my wallet.
    AJMansfieldSyd0the0kid
    Reply 4 years ago
    This probably wouldn't work for your car keys. Expensive car keys are expenses because of a special transponder microchip in the base of the key, not because of the physical metal key. So while you could make a key that could open the doors and such, that key would be unable to actually turn the car on.
    AJMansfieldtony114445
    Reply 4 years ago
    Some keys are more expensive. While typical house keys (such as C or KW1 types) are cheap, there are some types of keys, such as those for dimple locks, that are much more expensive. Also, some keys have special control measures against copying them: if you took one of those to a locksmith, you would also need to present a legal document authorizing copies before he could legally duplicate the key.
    Catley
    This is interesting, but to me, one of the most puzzling things is how you get a top on the new key.
    jmcdonald23
    Good idea but not something you want to try with epoxy. Also this can easily be used for criminal activity, ie grab someone's safety deposit key, safe key, etc and make a copy and then when they ain't around the criminal can break into the locked enclosure and steal whatever is there. I'd rather goto a locksmith or key copy place and have my key copied rather and experimenting with epoxy which can easily break off into the lock and then you are going to have an expensive repair bill to get it out.
    rpotts2jmcdonald23
    Reply 4 years ago
    use the epoxy copy as the "original" in a key copying machine?
    jmcdonald23rpotts2
    Reply 4 years ago on Introduction
    Whats the point in doing that if you still have the original? Making the epoxy key serves no purpose in my opinion.
    Not a troublemaker, just someone who sees this as if its easy for you to make then its even easier for a criminal to do. This way of making a key costs about $20 roughly whereas taking your key to a locksmith to have a copy made using a real key blank so that you have a spare will only run you about $5.
    mikecz
    This seems an incredibly complicated way to make a non-metal key. When I retired 2 years ago after owning a hardware store for 30 years, I was charging $1.99 (US) to make a simple single cut key, as shown in step 4. This would be a nickle plated brass key and I guaranteed it to work! We cut 16,000 to 18,000 keys a year in our little store and 99 point something-something % of them worked! We could almost always make good working copies from broken keys, too. Why not just have your locally owned hardware guy make your keys?
    Battlespeed
    I can't figure out why people use the very expensive Sugru for mold-making when there are so many excellent cheaper alternatives.
