Craft Stick Catapult!
51,068
264
13
About: I made a book with some new projects in it! It's called Marvelous Makeable Monsters. Check it out here: https://amzn.to/2xN1uWj The Oakland Toy Lab is a community-based wonder lab for students to build, ti...
The craft stick castle isn't going to invade itself! With a quick craft stick catapult, you'll be launching pom-poms over pipe cleaner parapets in no time. Whether you're using it to learn about levers simple machines, or want to join in a 2,400 year history of launching projectiles, the craft stick catapult can be your new favorite toy.
  • What: Craft Stick Catapult
  • Concepts: levers, simple machines, projectiles
  • Time: ~ 3 minutes for your first
  • Cost: ~ $0.05
  • Materials:
    • 6 rubber bands
    • 7 craft sticks
    • catapult basket (bottle cap, plastic egg, etc)
    • pom-poms or other projectiles
  • Tools:
    • hot glue gun
Let's launch!
Supplies:
Step 1: Prep Thy Fulcrum
Slap five craft sticks together, and rubber band them at both ends, wrapping the rubber bands until tight. You can add more or take some away later to test different build designs.
Step 2: Attach Thy Flinger
Take your two remaining craft sticks, and rubber band them at one end. Wedge the fulcrum in the middle so they splay apart. You can change the lever length of your catapult by moving your fulcrum to different positions. This is great for learning about leverage.
Step 3: Secureth in Place
Use two rubber bands to make an "X" around the entire flinger and fulcrum. Leave it loose enough so that you can change the lever length when you want to.
Step 4: Attach Thy Basket and Launch!
Be it plastic egg, bottle cap, clay, or folded paper, hot glue it to the end of the flinger. Load it up with some projectiles, pull back, aim (not at humans or animals), and fire away!
After you fling a few pom-poms around, try making some targets out of paper or cups, and adjust the fulcrum height and lever length to play with different designs.
Which lever length works the best? How does it change the flight path of the pom-pom?
Have fun, and keep exploring!
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    13 Discussions
    EpicMario99
    3 years ago on Introduction
    I'm probably just really bad at life, but how do you get the rubber bands to stay on the sticks for the fulcrum? No matter what I try, it just falls apart.
    SaliA1
    I like it.... I will make it for my kids.... Nice Summer to Nice craft
    salmanfarsi
    3 years ago
    خیلی خلاقانه است.
    Jobar007
    It looks like it is mostly shooting vertically. If you angle the cup when attaching it, does it make a difference in the direction the projectile travels? Perhaps a higher angle of the spring arm is needed to get a more horizontal flight path?
    Hey JoBar,
    That is a mighty good point, at the current angle it has a pretty steep arc (maybe 60 degree launch angle?) I think your second thought helps out the most, of adjusting the spring arm angle by adding more popsicle sticks to the fulcrum. It's fun to adjust both that, and the length of the spring arm position on the fulcrum.
    It's also fun that we get to discuss all this about a toy catapult. Thank you for the wonderful comment as always!
    Sunglowart
    3 years ago
    Easy and super cool
