Create a Traffic Cone
Learn to create accessories to enhance your play time.
We will only need a few shapes.
Let's get started with the base of the cone!
Instructions
    1. Drag a Box shape onto the Workplane.
    2. Continue to the next step.
Step 1: Size the Box
Let's adjust the size of the box by making it shorter.
Instructions
    1. Select the Box shape and size it to 2mm tall.
Step 2: Add the Cone
Great work! Next we need the cone shape.
Instructions
    1. Drag a Cone shape to the Workplane.
Step 3: Size the Cone
We will need to trim off the top of the cone a bit, but first let's make the cone a bit taller.
Instructions
    1. Select the Cone shape and size it to 30mm tall.
    2. Size the bottom of the Cone to be 15mm by 15mm.
    3. Continue to the next step.
Step 4: Align the Shapes
Now we need to align the shapes, so they are centered on each other.
Instructions
    1. Select both shapes and click the Align button on the toolbar.
    2. Select the middle align handles on the Workplane to align the shapes.
Step 5: Add a Box Hole
We will need to trim off the top of the cone.
Let's get started.
Instructions
    1. Drag a Box Hole onto the Workplane.
Step 6: Lift the Box Hole
Let's position the Hole to trim the top of the cone.
Instructions
    1. Select the Hole shape
    2. Use the black arrow on top of the shape to lift the hole 25mm up off the Workplane.
Step 7: Duplicate the Cone
To hollow out the cone we will make a duplicate of the cone we already have and use it to remove material from the inside of the cone.
Instructions
    1. Select the Cone shape.
    2. Click the Duplicate button on the toolbar.
    3. Use the black arrow on top of the shape to drop the cone 3mm below the Workplane.
    4. Use the shape panel to set the new cone to a hole.
    5. Continue to the next step.
Step 8: Align All the Shapes
Now, let's center all the shapes one last time.
Instructions
    1. Select all the shapes, including the holes, and click the Align button on the toolbar.
Step 9: Group the Shapes
With all the shapes in their final position we can now group the shapes into a single object.
Let's make a traffic cone!
Instructions
    1. Select all the shapes, including the holes, and click the Group button on the toolbar.
    2. This will combine all the shapes and remove material where the hole shapes are positioned.
    3. Use the Shape Inspector to change the color of the cone to Orange.
    4. Continue to the next step.
Step 10: You Did It!
Great Work!
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
