Create an Alarm in Batch
92,053
35
88
About: One of my favorite hobbies is dismantling electronics, then either combining them together to create something new, or adding components to make them better. I also like gadgets, whether it's taking them apa...
Alright... In this instructable I will show you how to create an alarm in a batch file. When activated, a tone will come from the internal speaker of your computer, over, and over. If you are lazy, you can just download it in the last step!I highly advise you not to play around with batch if you are not familiar with it! If you aren't, check out these basic,Intermediate, and advanced, batch tutorials.
Supplies:
Step 1: Capture the "Alarm"
In order to create an alarm, we will need a sound. There is a special character that when in a batch file or entered in command prompt, will cause an error and a tone will play through the internal speaker. In order to get that special character, you need to do a key combo in command prompt then save it so you can copy and paste it. That's what I'll do in the next few steps.
Step 2: Open Command Prompt
Goto start> run, then type in cmd, then press OK
or
Goto start> All Programs> Accessories> Command Prompt
Step 3: Change Directory
Once in command prompt, type
cd desktop
That will change the directory command prompt is in, to the desktop.
Step 4: Echo, ECHO!
Now that you've navigated to the desktop, type this:
echo @echo
Step 5: Key Combo
Now hold down ALT & 7 (must be on the numpad) at the same time. "/\G" should appear. See picture.
Step 6: Save As Batch
Now Type:
>alarm.bat
">" means "output" and "alarm.bat" is what you are outputting.
Make sure you remember the ".bat" part, or it won't be saved as a batch file.
Step 7: Obtain the Character
Right click on the newly created batch file and click Edit. Then select the box looking letter that is the character, and copy it. You've now successfully captured the rare alarm character! Clap Clap Clap...
Step 8: Delete
You can now delete the file "Alarm.bat"
Step 9: Alarm Code
First, open Notepad. Then type:
@echo off:alarm
"@echo off" means that it won't show you whats happening. Keeps batch files clean.
":alarm" is a label
Then paste the special character in a new line under that.
Next type in the next line:
clsgoto alarm
"cls" means clear screen. It just removes everything on screen off the command prompt. Sorta like a dry erase board. "goto alarm" means that it will goto the label ":alarm"
Step 10: Save As
Goto File> Save As, and save it as "Alarm.bat"
Step 11: Done!
You can now run the batch file "Alarm.bat" and it will sound an alarm through your computer speakers! One neat thing to do is if you have a password protected batch file, you can sound an alarm if they get the password wrong! Another thing you can do, is make an alarm clock! Good luck, and have fun!
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    88 Discussions
    Sembot
    1 year ago
    how can i adjust the speed of moving , en make sound
    goro nes
    4 years ago on Introduction
    When we create alarm with batch files. Can we use other songs eg.*.MP3 .
    GameV8
    11 years ago on Introduction
    For the people who don't have number pads to get the "special character" just go to the character map tool, pick any font, and go to unicode 2022. (Bullet)
    michaelb958GameV8
    Actually, I thought everyone had a number pad. On most laptops, there are number pad key markings on a set of keys on the right side of your keyboard - to use them, hold Fn and press one. (For example, to get a NumPad0 on my laptop (very important for the Alt+0160 character!) I press Fn+M.)
    Regulatorsmichaelb958
    Reply 5 years ago on Introduction
    not all special symbols are valid, batch file or cmd only read special ASCII symbols. go get ASCII symbols that valid for batch file and cmd, get it here
    http://textuploader.com/tprq
    Regulators
    this is cool, but i made my own batch file, that allow you to download file from internet, just like download manager. please visit this instructables
    https://www.instructables.com/id/How-To-download-File-on-internet-using-batch-file/
    thanks dude!
    dragon239
    where do you think i should add the alarm code to in this locker code:
    @ECHO OFF
    title Folder Private
    if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
    if NOT EXIST Private goto MDLOCKER
    :CONFIRM
    echo Are you sure you want to lock the folder(Y/N)
    set/p "cho=>"
    if %cho%==Y goto LOCK
    if %cho%==y goto LOCK
    if %cho%==n goto END
    if %cho%==N goto END
    echo Invalid choice.
    goto CONFIRM
    :LOCK
    ren Private "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    echo Folder locked
    goto End
    :UNLOCK
    echo Enter password to unlock folder
    set/p "pass=>"
    if NOT %pass%== 345742 goto FAIL
    attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
    ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Private
    echo Folder Unlocked successfully
    goto End
    :FAIL
    echo Invalid password
    goto end
    :MDLOCKER
    md Private
    echo Private created successfully
    goto End
    :End
    dragon239
    how do i add the alarm batch file to my Locker batch file?
    si13ntsl4y3r
    I clicked on your link and got this:
    @echo off
    color fa
    title password required
    set tries=4
    :top
    cls
    set /a tries=%tries%-1
    if %tries% equ 0 (goto penalty)
    echo you have %tries% attempts left.
    echo please enter password
    set /p password=
    if %password%==boom (start www.google.com)
    goto top
    :penalty
    exit
    It works fine but I can't change the destination when you get the password right to a vbs, other batch, file folder, or word doc. Plz help
    thillryansi13ntsl4y3r
    Heres the code you wanted
    @echo off
    color fa
    set tries=4
    :menu
    if exist pass.bat goto top
    goto passme
    :passme
    set /p pass=Enter Password:
    echo set pass=%pass%>pass.bat
    goto top
    :top
    cls
    set /p password=Please Enter Password:
    call pass.bat
    if %password%==%pass%(goto start
    :start
    goto good
    :good
    echo Password Right
    pause
    :penalty
    exit
    jmarri
    8 years ago on Step 11
    It dosen't work!!! all it says is "   "" is not recognized as a internal or external command... etc."
    si13ntsl4y3r
    what would be a script for a password that if typed incorrectly, the alarm would sound, all I see here are bits and pieces and I don't understand exactly what to type into notepad.
    Arbitrorsi13ntsl4y3r
    If you don't know how to put it together, then I don't think you should even try. Read some basic batch tutorials or 'ibles first.
