Creating Activated Carbon From Food Waste (CCC Carbon Method)
52,503
259
21
For a full Youtube tutorial: http://www.youtube.com/watch?v=dM1MMJJ3c08
Activated carbon is a porous substance derived from organic material (usually woody, fibrous stuff). The useful thing about activated carbon is that it can filter out contaminants from both water and air, which makes it an important substance in filtration system.
We examined a variety of methods (we considered 40+ samples to be adequate) to create activated carbon; through testing, we believe that we have found the optimal material and protocol to create the closest thing to commercial-standard activated carbon. We tried to create the easiest solution that implemented tools you already have around the household (because not everyone has a drum-steel burner on their hands).
This Instructable is meant for those DIYers with a bit of time (ok, only about two days) who aren't afraid to burn, burn, and burn. This flexible method takes all sorts of food waste and turns them into activated carbon for filtration. Use it while camping, biking, or even at home!
Our hope is that this method will eventually help impoverished areas improve overall health by providing an easy and flexible filtration option.
SO LET'S GET COOKING.
Supplies:
Step 1: Materials
Alrighty! If you're reading this, you've just completed the first step to creating your own activated carbon!
When thinking of materials, we tried to be flexible so that you wouldn't have to go out and buy everything (that kinda defeats the purpose, doesn't it?). Here's what you need to make the carbon.
A metal container, with a lid
An oven (or something that gets hot)
A fireplace, grill or pit (something you can burn on)
A strong acid, base, or salt (we'll explain later. Some examples we have tested include 25% Calcium Chloride, Bleach, and Lemon Juice Solutions).
The food waste.
Now, picking the food waste is by far the most important step here. You want a nice, fibrous substance that already has a lot of pores. For example, commercial carbon is made with hardwood or coconut husk (that's what you see above). These are fine, but we have also tested banana peels, orange peels, nut shells, and rye husks with similar results. Feel free to explore. If you choose something with a lot of water content, you might want to dry it beforehand to prevent steam buildup.
Step 2: Char
The first step is to heat the material to a stage where everything but the carbon burns off.
Place the food waste into the metal container and seal/close it loosely (you could also drill a small vent hole). The priority here is to limit oxygen exposure, which causes unwanted chemical reactions, while preventing the container from becoming a pressure bomb.
Next, place the container within a VERY HOT location (aka a burning fire). We placed ours within a bed of burning coals, so this a great excuse for an impromptu BBQ party. You could place it in the center of a campfire, or in an established cooking fire. The goal here is to maintain a temperature of 400+ degrees Fahrenheit, which is when pyrolysis and charring begins. After a while, you should see steam and gas escaping from the vent holes, which should only increase the strength of the fire.
The time it takes to fully char varies depending on the material and heat, but we have found that 4 hours tends to be a good consistent number. Remove the container and let it cool before you check the insides. The material should be black and have the consistency of charcoal. Use your hand or a hammer to crush the carbon to a powder.
Step 3: Chemicals
The next step is to increase the preliminary pore size of the charcoal. This is where the acid/base/strong salt comes in.
You're going to want to make a 25% solution of any one of the following:
Calcium Chloride (a salt used in the aquarium industry)
Bleach (in our opinion, the easiest option)
Lemon Juice (you're going to need a lot of lemons. However, this is great for making food-quality activated carbon).
Online, other people have recommended more dangerous solutions (such as battery acid). We personally do not approve of using anything you wouldn't be willing to ingest (because your drinking water will be mixed with this carbon).
To remove the ash content within the carbon, you should first rinse out the carbon in the container. If you have time, let it fully dry.
Add enough of the solution to the container to fully submerge the carbon. Cover, and let rest for 24 hours.
Step 4: Cook
Applying heat to the activated carbon after chemical exposure helps to fully refine the product and maintain its integrity.
After the 24 hour waiting period, rinse out the solution and drain the carbon. You want to have wet carbon, but not saturated carbon. Place it back in the container.
You now want to exposure the carbon to 225-250 degrees Fahrenheit for about 3 hours. This can be done the following ways.
The easiest solution is an oven, gas or electric. The heat will dry the carbon and finish the product.
If you don't have access to an oven, we recommend placing the container above a fire, and adjusting based on the temperature. An easy way to measure temperature is to place the container next to or inside a pot of water, which will boil at 212 degrees.
A final method to cook is by creating an impromptu solar oven. This would only work in a very sunny climate, between noon and late afternoon. Seal the carbon in a BLACK metal container, and place on a reflexive surface (a tin roof, for example). To measure temperature, you may want to place wax near the container, and watch to see if it melts.
Step 5: Use!!
Congratulations! You have developed your own strand of activated carbon.
When used with boiling techniques and UV radiation, activated carbon can visibly improve the quality of your water.
Depending on the particle size of your carbon, it can also be used to absorb odors and improve air quality.
Finally, if all of your materials are food-grade, you can ingest it to neutralize toxins you may have accidentally consumed (we assume you accidentally ate that toxin, and we recommend this only as a last resort if you have no other option).
As you can see, these uses are vital in universally improving the quality of air and water. It's our goal to spread this method and knowledge about the uses of activated carbon to those who need it the most, especially to people in third-world countries. We thank you for reading, and we hope you will spread and improve on our methods.
Feel free to check the many other Instructables on how to use your new activated carbon!
For those interested in the full investigation we conducted to develop this method, you can visit our Google Science Fair Entry here:
http://goo.gl/0eFsz
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    21 Discussions
    I honestly have no idea. In theory, coffee grounds should be able to function as a suitable food waste, as the origin of grounds come from seed "berries". However, you'd still have to fully char them, even if they are roasted. Have fun testing!
    harlyquinnocureforcrazy
    Reply 2 years ago
    Coffee grounds would, I guess from my light Wikipedia research, be a good choice, as they have already been partly pyrolyzed. Roasting brings the coffee seed up to 196 C(385 F)-270 C(473 F). The darker the roast, the higher the temp of the roast. So, as a feed product, this would be a good choice. Now, to test this notion.
    harlyquin
    2 years ago
    in the charring step, does the material need room to expand? I am thinking that the ideal way to limit oxidation would be to stuff the container, but as you mentioned, we don't want to make a bomb by producing too much pressure. In summary, how much material should be in the metal container?
    darlene kleinm
    3 years ago
    What are the properties of calcium chloride or the bleach to make the coconut shell into an activated carbon? Thank you. I really need your reply.
    nocureforcrazydarlene kleinm
    Reply 3 years ago
    Calcium chloride solution and bleach are both corrosive on the microscopic level, increasing the surface area of the char by creating pores and thus increasing the filtration properties of the substance.
    darlene kleinmnocureforcrazy
    Reply 3 years ago
    Can i use sodium chloride as a substitute for calcium chloride? Thanks in advance.
    Reply 3 years ago
    I don't think sodium chloride will work... that's just plain table salt. You're always welcome to try though.
    LeaP3nocureforcrazy
    Reply 2 years ago
    Actually table salt works very well.I am really unsure why no one is using this method instead since its a lot less caustic.
    http://ojs.library.queensu.ca/index.php/ijsle/article/viewFile/4244/4344
    MahtabL
    3 years ago
    Hi everyone, i read all the comments, i love it, very useful.
    i am referencing this page to my patient to read as a general/useful information.
    CrantaC
    3 years ago
    This is a very cool tutorial and easy to do in primitive style, but i read somewhere else that for the activation there need to be ~537 degrees Celsius treatment after adding the chloride water. as i am ceramist it makes sense, ceramics(mud) also have this 537 degrees C point where it reaches full impermeability
    obaron
    3 years ago
    Beautiful...
    Edbed
    3 years ago
    This is really good.
    brenda-
    5 years ago on Introduction
    thanx i love this.am definately gonna try this. but im a little slow.when you say 25% ,am i putting 75% water with 25% bleach or lemon juice?
    Dream Dragon
    6 years ago on Introduction
    I've always wondered what makes "Activated Charcoal" different from the basic variety that might be used in a barbecue or an artists supplies. Thanks for addressing this issue.
    I would also like to know because I dont like bleach. It's a strong chemical that I prefer not to have around my son or pets.
    keastestherobotichand
    Reply 6 years ago on Introduction
    IMHO it should, the question is what should the absolute concentration of the acid/base/salt be? vinegar is standard at 5% acetic acid, where lemon juice citric acid content can vary up to 25% between lemons (i dont know the average concentration off hand sorry.)
    nocureforcrazykeastes
    We tested 10-50% dilutions of some extra-strength white vinegar (10% acetic acid) we found at our local market. The results were at most feeble: all dilutions have a 12.5% increase in porosity. 25% bleach has an 62.5% increase in porosity. 25% lemon juice has the same effect, but the citric acid content does vary depending on your location.
    That's why we recommend bleach, with lemon juice as a backup. You could test for stronger dilutions of both lemon juice and vinegar if you'd like. We will be soon posting all of our research data online as part of the Google Science Fair 2013. Hope this helps!
