Creme Caramel
22,725
115
40
This is one of my favourite desserts, and in my opinion the best pudding in the world. It may appear complicated to make at first, but in fact it's very easy. You will need:
For the caramel sauce:
- 100 grams of sugar
- 100 milliliters of water
For the pudding:
- 0.5 liter of milk
- 115 grams of sugar
- a few drops of vanilla extract
- 2 whole eggs
- 4 egg yolks
Utensils needed:
- sauce pan
- sieve
- mixing bowl
- measuring cup
- 4 small pots
- oven dish, large enough for the pots
- oven
Step 1: Make the Caramel
Put the sugar and water in a sauce pan, put it on low heat and stir until everything has dissolved. When it has, turn the heat up and don't stir anymore. This is very important, since stirring may cause the sugar to recrystalize.
When the sugar solution boils, it will form a syrup that gets thicker and eventually starts turning brown. Be very carefull with this, since it's very, very hot!
Step 2: Coat the Pots With Caramel
You'll have to be quick now, before the caramel cools down and hardens. Pour some of the liquid, hot caramel in the pots and turn them around so it covers as much as possible of the inside. As you can see, I wasn't quick enough with some of them and it hardened before I covered the inside entirely. This isn't really a problem, though.
Step 3: Make the Pudding
Now it's time to make the pudding. In a mixing bowl, mix the sugar, eggs, egg yolks and vanilla extract. Don't use too much of the vanilla, this is very concentrated stuff and a few drops will add a pretty strong vanilla flavour!
Heat the milk a bit (don't boil it) and mix it with the egg mixture. Pour the resulting mixture through a sieve (for removing any solid parts that may be left) into a measuring cup (is easier for pouring).
Step 4: Bake the Pudding
Fill all pots with the liquid pudding and put them in the oven tray. Fill this with hot water until the pots are 2/3 submerged in water. Heat the oven to 175�C and bake the puddings for 45 minutes. Keep an eye on the water, it shouldn't bubble.
I have five pots here since I had some of the liquid pudding left, so I took an extra pot without caramel. Also, I didn't have a large enough oven dish, so I had to use two small ones. After baking the pudding, let them cool down and put them in the fridge for a day.
Step 5: Digg In!
Cut the now solid pudding loose from the pot with a knife, put a plate on top of the pot, flip it upside down and gently shake the pot so the pudding will come out of it. The caramel will have liquified during baking and has formed a sauce that flows over the pudding.
It's a bit similar to crème brulée, with the exception the caramel topping is liquid instead of a solid crust. For making crème brulée, make the pudding without the caramel. Sprinkle some powdered sugar on top of it and caramelize it with a blowtorch.
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    40 Discussions
    ElizabethLeona
    6 months ago
    Thanks for letting me know you have your own recipe channel. I went to the address and subscribed. I will be curious to find what other recipes you have. Thanks again.
    maurice1993
    8 years ago on Introduction
    I cook pudding a little small, tiny different way... I just put every ingriedient at blender, then, after caramelising a pan (a metal one, with a hole at center) I put the liquid pudding in the pan, ant put the pan into a bigger pan, put 2/3 of the length of the small pan and put it on the stove, and let it cook with the vapour for (yes) about 45 minutes. simplier, but not so much different anyway, I love puddin and you stile looks.... just perfect for a single guy portion (compare to a 2,5 littler cooking pan - you'll realize that the puddin take about a week to be fully ate... and... puddin is to be eated in no more than 2 days xD)
    ElizabethLeonamaurice1993
    Reply 6 months ago
    Reading your comment about pudding, I guess would be also good but pudding implies using bread in the recipe. Though if you are familiar with it you can make unbelievable puddings.
    REA
    9 years ago on Introduction
    for all you lazy americans that dont feel like cooking in metric: For the caramel sauce: - 3 ½ oz. of sugar - ½ cup of water For the pudding: - 2 cups of milk - 4 oz. of sugar - a few drops of vanilla extract - 2 whole eggs - 4 egg yolks
    READoctor What
    we should. its easier to use since all measurements are easily divisible ten. theres no one sixteenth or eight twelfths.
    mhillREA
    What?! and quit using my slide ruler to figure out how much sugar to water I need for a triple batch??? By the way is it Kilo-meter or Kil-ometer?
    REAmhill
    i say kilometre (all together with no syllable break), but pronunciation depends on nationality.
    greenmiaREA
    Would you please help a VERY lazy american translate it to cups? :D
    REAgreenmia
    2/5 cups of sugar
    ½ cup milk
    thats all the dry to liquid measurements.
    imajemREA
    1/3 cup sugar should do it...I also use the MW to "bake" it.
    greenmiaREA
    That's perfect! Thanks so much. Oh and is the 2/5 cup sugar for the caramel sauce or pudding?
    REAgreenmia
    caramel. for the pudding its ½ cup. i missed that when i was converting.
    REAREA
    also ignore the mesurement i put down for the milk:
    >½ cup milk
    that was really for the pudding's sugar. sorry.
    BranchmateREA
    I'm not sure "lazy" should describe a person that doesn't have the tools to measure in metric....unless you meant it as a joke, in that case, Ha Ha. Your recipe sounds delicious, thank you for sharing it with us.
    REABranchmate
    well, unless youre using 19th century cooking equipment, metric is on all measuring devices sold in America. but i digress, as it was a joke.
