Cup Holder for Crutches
7,282
67
7
Those who have broken an ankle know how frustrating it is that you can't carry anything in your hands while crutching. Just because you're off your foot for six weeks doesn't mean you can't drink with the best of them! Use this mod to be more independent and wow your friends.
Supplies:
Step 1: Materials and Tools
All of these materials I found at an ACE hardware in Salt Lake City.
Materials:
- a six-inch steel plate
- corner brackets x 2
- 1/4" hex bolts (1" x 4, 1/2" x 2)
- washers and nuts
- 1/2" section of 3" dia PVC pipe
- 1/2" section of 4" dia PVC pipe
Tools:
- vice grips
- pliers (needle nose and regular)
- tin snips
- duct tape (duh)
- adjustable width pliers
- lighter
- nail
- rasp, file or screw driver (for widening holes)
Step 2: Widen Bolt Holes
Because you didn't buy the right hardware, open a beer and get to it. Using force and misusing any skinny tool you can get your hands on, widen the holes in your cheap aluminum hospital crutches. Try not to slice open your hand. You've been there before and it's not pretty.
Step 3: Attach Corner Brackets and Cross Bracket
By some stroke of luck, the bolt holes align so put the pieces together (for once in your life).
Step 4: Sterilize Needle / Drill Holes in PVC Rings
For lack of appropriate tools, you decide to melt holes into the sides of your cup holder and support rings. These are for the bolts that act as an axis. Use a lighter to heat a nail and force it through the rings. Make sure they are exactly opposed or the cup won't swivel right.
Step 5: Bolt Everything Together
Tighten nuts around support ring (black) and to the cross plate. This is the one point of contact the crutch has with your coffee, so make sure it's strong. Make sure there is enough play for the inner ring to spin freely.
Step 6: Enjoy Your Crutches Cupholder
Make a duct tape net for the inner ring so it can hold your beer, or leave as is for tapered vessels like coffee cups and mugs.
Ta-da! Now go get sloshed.
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    7 Discussions
    Wish i had this when i was on crutches, was my second biggest problem (after walking). Well done.
    ezeisel
    4 years ago
    Go 3-axis and it will have 0% spill factor! Just a little bigger, but prototype and sell!
    S3rj
    4 years ago
    incredible genius! :))
    you can put another ring for rotation on 2nd 2D axis (parallel with the walking direction)
    smorgsborg
    4 years ago
    Um, this concept is amazing. Bravo!
    Susitna
    4 years ago
    Thank you. I am going to make one for my sit-on walker. Mary Alice
    That's so smart! I think you actually have to try to spill it to get it to spill, and even then I'm not convinced it would spill.
    enelson8
    4 years ago
    This is ingenious!! I love how it is convenient for the user and its spill resistant!!
