Custom Embossed Notebooks Using 3D Prints
5,211
103
4
About: I'm a content creator. I make open source projects and videos for said projects. My goal is to create free and open knowledge for everyone.
This is a very simple, yet very effective process of embossing using 3D prints. You can put a logo, or a name, picture, anything you want. These custom embossed notebooks make great gifts!
Supplies:
Step 1: Watch the Video!
Step 2: Gather Your Tools.
For this Instructables you will need:
  • 3D printer
  • Some type of CAD software (123D, Fusion 360, TinkerCAD...)
  • A large vise or press
  • Small scrap wood
  • Glue gun
  • Notebook or Sketchbook you want to emboss the design onto.
Step 3: Create Your Design
You will want to create your design in the CAD software. I'm only doing the word LEGIT. You will need to mirror the word (as if you're looking through it) to make sure its the right way on the book. My design is only 4mm thick total. 2mm for the word LEGIT, and 2mm for the flat back.
Step 4: 3D Print Your Design
Its a good idea to have a lot of infill so that it is strong. I went with 80%. Its pretty small so the print should only take a few minutes. Also layer height doesn't really matter here. So you can max out your extruder layer height.
Step 5: Hot Glue
At this point you will want to get your small pieces of wood ready. These are going to be used to clamp each side of the book so the metal of the vise doesn't damage anything. I first hot glued the 3D print to one of the pieces of wood. I also hot glued the other piece of wood to the vise to avoid having to hold 3 pieces together while trying to align the print.
Step 6: Install in the Vise
You want to open the notebook to the cover you want to emboss. Carefully align the pieces of wood in the vise with the notebook and position the 3D print so it is in the correct location. Its probably not going to be perfectly aligned, but thats okay it will still look cool! Especially since you're making it yourself.
Step 7: Clamp!
Once its all aligned, tighten the vise as hard as you can. Let it sit for a few minutes.
Step 8: Done!
Remove from the vise and check out your work. The first one might not be great(mine wasn't) but the second will always be better. If you take your time aligning everything, you should have a now custom embossed notebook.
These make great gifts for the holidays!
Step 9: Support These Projects!
If you enjoy these projects, I strongly suggest you subscribe to my YouTube Channel(Click here!) - I have many different types of projects and there will definitely be others you will like.
Also if you think you can spare it, considering becoming a patron on Patreon. The support of my patrons strongly influences the amount of projects I am able to create. They're the best! I also try to give back to them as much as possible! Check out my Patreon Here.
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    4 Discussions
    BrownDogGadgets
    5 months ago
    Fun tip if you don't want to do design work, just go onto Thingiverse and make a custom Key Chain with text. Then in the 3D printing software mirror the image. It makes things very quick and easy for those who don't want to mess with 3D design work. I recently did that for something my wife was working on.
    PeterM520
    5 months ago
    Have you experimented with making the 3D piece out of different materials? I would imagine some work better than others.
    Penolopy Bulnick
    5 months ago
    Such a great way to make embossed notebooks :) So many possibilities!
