Customizable Elastic Band Backpack Organizer
15,207
257
24
Made a second version of my gadget organizer. (Hope it will stop here before this becomes another obsession.) Can be used in a backpack, or outside. The base is a perforated aluminium board and the gadgets are held in place by loops of elastic band. Loops of any size can be created at each desired location on the board using the holes and some hair pins.
Features:
- Fully customizable
- No wasted space (gadgets can sit right next to eachother)
- Anti slip material makes gadgets sit secure
You need:
- Perforated aluminium board that fits in your backpack. See my first organizer instructable for how this is made: Backpack organizer version 1
- Sandpaper
- Black metal paint (or radiator paint)
- Double sided tape
- Anti slip elastic band (this is elastic band used in clothing, which has silicone material sewed on top)
- A tiewrap
- A lot of hair pins
- Gadgets
Supplies:
Step 1: Spray the Aluminium Board Black
The aluminium base is not visible in this design, because the entire surface will be covered with elastic bands. But to prevent the metal from peeking through, I spray it black.
To make the paint adhere better, I start with sanding one side of the board and wipe it clean. Then I spray it with black radiator paint. (Any metal paint will do.) Spray a couple of thin layers, until it is entirely black. Spray outside or use a well ventilated area. (Or sacrifice brain cells)
When it is dry, move on to the next step !
(To see how the aluminium board is made see my first Backpack organizer instructable.
Step 2: Tape the Rounded Edges of the Board
I want to wrap the elastic band all around the board. That will work fine on the straight edges, but on the rounded edges, it will slip off. To prevent this, I stick some double sided tape on the rounded parts of the edge. The tape must not overlap with the perforations too much, because we need to access those later. So I cut out a number of narrow strips of double sided tape from a larger roll. The images are self-explanatory. Note that I don't stick tape all around the edge. This way the elastic loops can always be moved a bit if necessary.
Step 3: Wrap Around the Elastic Band
Now I want to completely cover the board in loops of elastic band, wrapping all around. If the board you are using has a rectangular shape, this is easy. But the rounded edges in my board make it a bit more difficult. (At least if the result has to look more or less neat.) I'll give a step by step description of how I did it in the image notes.
You may need to adapt this way of wrapping to the shape of your own board. May take some tinkering...
Step 4: Create Custom Loops for Objects to Sit In
The board is now ready to use ! You can lay out your objects and then create custom loops to hold them. The loops are created by clamping the band onto the board using hair pins. I'll describe how to do this step by step in the image notes.
Step 5: Solve Problems
In creating the lay out, I stumbeled on several issues. I'll address them in the notes of each image.
Step 6: Insert in Bag and Zip Up :)
This is the finished result with all items installed. Just slide it in your backpack and zip up :)
As you can see, this particular backpack has a compartment that opens almost completely from top to bottom. Very nice for this kind of organizer. (and its only 20 euro and holds a 17'' laptop)
Step 7: Vertical Loop Version
In testing the organizer with horizontal loops as described in step 1-6, I found that some heavy objects do slide down over time. The grip of the bands is very tight, but apparently, not tight enough. This problem is also reported in the 'Grid-it' organizer, as I read in various customer reviews on Amazon.
The simplest way to solve this I think, is to use only vertical loops. The objects then can't slide down past the attatchment point of the loop. I made a version of this for testing and it holds up quite well so far (see image).
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    24 Discussions
    JosV10Loufourmountains
    Reply 2 years ago
    wooo that looks so nice... how did you get it to line up so perfectly..?
    Loufourmountains JosV10
    Reply 2 years ago
    i used a plate of 25 cm and a band of 2,5 cm so if you calculate... 25/2,5=10 it fits 10 times. And the pattern... it was stressfull but after 25 times i made it!!!!!
    Reply 2 years ago
    yes the pattern is what i meant... Great that someone actually made this haha. And it really works too, Ive been using it ever since. And only hand stuff falling out once or twice..
    JosV10JosV10
    Reply 2 years ago
    ps did you make it for your backpack? or just to slide in a bag?
    Reply 2 years ago
    I thank you so much of sharing this project i am young and i like to work with my hands and this was really fun! The best part.. Painting with the spray (-:
    Azfar800
    2 years ago
    thhxx bro great workk!!
    tyler roberts
    2 years ago
    new twist on an old idea, I like it
    old idea: https://en.wikipedia.org/wiki/Pouch_Attachment_Ladder_System
    ruso_cj
    2 years ago
    Me gusta mucho! It's fantastic!
    Gregbot
    2 years ago
    Sweet! Thanks!
    rozf3k
    2 years ago
    yeahh very good
    darkclaw42
    2 years ago
    Wow - I have a large Alienware backpack that would be perfect for this and all my tech junk. If I get to making it, I'll be sure to share.
    ior2
    2 years ago
    i thought about doing this once i saw one of these in the market, pretty complex yet not so hard to make. way better than your last one.
    very well sir!
    JosV10mosix
    Reply 2 years ago
    Curious to see yours if you are making it..
