DIY Arduino Battery Capacity Tester - V1.0
166,934
1,036
145
[ Play Video ]
I have salvaged so many old lap-top batteries ( 18650 ) to reuse them in my solar projects.It is very difficult to identify the good cells in battery pack.Earlier in one of my Power Bank Instructable I have told, how to identify good cells by measuring their voltages, but this method is not at all reliable.So I really wanted a way to measure each cell exact capacity instead of their voltages.
You can find all of my projects on : https://www.opengreenenergy.com/
Few week ago, I have started the project from the basics.This version is really simple one,which is based on Ohms Law.The accuracy of the tester won’t be 100% perfect, but it does give reasonable results that can be used and compared with other battery, so you can easily identify good cells in a old battery pack.
During my work I realised, their are lot of things which can be improved.In future I will try to implement those things. But for the time being I am happy with it.I hope this little tester will be useful, so I am sharing it with you all.
Note : Please dispose the bad batteries properly.
Disclaimer: Please note that you are working with Li Ion battery which is highly explosive and dangerous . I cannot be held responsible for any loss of property, damage, or loss of life if it comes to that. This tutorial was written for those who have knowledge on rechargeable lithium ion technology.Please do not attempt this if you are novice. Stay Safe.
Supplies:
Step 1: Parts and Tools Required :
Parts Required :
1. Arduino Nano (Gear Best / Banggood )
2. 0.96" OLED Display ( Amazon / Banggood )
3. MOSFET - IRLZ44 ( Amazon )
4.Resistors ( 4 x 10K , 1/4W ) ( Amazon / Banggood )
5. Power Resistor ( 10R, 10W ) ( Amazon )
6. Screw Terminals ( 3 Nos) ( Amazon / Banggood )
7.Buzzer ( Amazon / Banggood )
8.Prototype Board ( Amazon / Banggood )
9. 18650 Battery Holder ( Amazon )
10. 18650 Battery ( GearBest / Banggood )
11. Spacers ( Amazon / Banggood )
Tools Required :
1. Wire Cutter / Stripper ( Gear Best )
2.Soldering Iron ( Amazon / Banggood )
Instrument Used :
IMAX Balance Charger ( Gearbest / Banggood )
Infrared Thermometer Gun ( Amazon /Gearbest)
Step 2: Schematic and Working
Schematic :
To understand the schematic easily,I have drawn it on a perforated board also.The positions of the components and wiring are similar to my actual board.The only exception are the buzzer and OLED display. In the actual board they are inside but in the schematic they are lying outside.
The design is very simple which is based on Arduino Nano. An OLED display is used to display the battery parameters.3 screw terminals are used for connecting battery and the load resistance.A buzzer is used for giving different alerts.Two voltage dividers circuit are used to monitor the voltages across the load resistance.The function of the MOSFET is to connect or disconnect the load resistance with the battery.
Working :
Arduino check the battery condition, if the battery is good, gives command to switched ON the MOSFET. It allows current to pass from the positive terminal of the battery, through the resistor, and the MOSFET then completes the path back to the negative terminal. This discharges the battery over a period of time.Arduino measures voltage across the load resistor and then divided by the resistance to find out the discharge current. Multiplied this by the time to obtain the milli amp-hour ( capacity ) value.
Step 3: Voltage,Current and Capacity Measurement
Voltage Measurement
We have to find the voltage across the load resistor.The voltages are measured by using two voltage divider circuits.It consists of two resistors with values 10k each. The out put from the divider is connected to Arduino analog pin A0 and A1.
Arduino analog pin can measured voltage up to 5V, in our case the maximum voltage is 4.2V (fully charged) .Then you may ask, why I am using two divider unnecessarily.The reason is that,my future plan is to use the same tester for multi chemistry battery.So this design can be adapted easily to achieve my goal.
Current Measurement :
Current (I) = Voltage ( V ) - Voltage drop across the MOSFET / Resistance (R)
Note : I am assuming the voltage drop across the MOSFET is negligible.
Here , V = Voltage across the load resistor and R = 10 Ohm
The result obtained is in amperes.Multiply 1000 to convert it into milli amperes.
So maximum discharge current = 4.2 / 10 = 0.42A = 420mA
Capacity Measurement :
Stored Charge ( Q ) = Current ( I ) x Time (T ).
We have already calculated the current,the only unknown in the above equation is time.The millis() function in Arduino can be used to measured the elapsed time.
Step 4: Selecting ​Load Resistor
The selection of load resistor is depend on the amount of discharge current we need.Suppose you want to discharge the battery @ 500mA, then the resistor value is
Resistance ( R ) = Max Battery Voltage / Discharge Current = 4.2 /0.5 = 8.4 Ohm
The resistor needs to dissipate a bit of power, so size does matter in this case.
Heat dissipated = I^2 x R = 0.5^2 x 8.4 =2.1 Watt
By keeping some margin you can choose 5W. If you want to more safety use 10W.
I used 10 Ohm ,10W resistor instead of 8.4 Ohm because , it was in my stock that time.
Step 5: Selecting the MOSFET
Here MOSFET is act like a switch.The digital output from the Arduino pin D2 controls the switch. When 5V (HIGH) signal is fed to the gate of the MOSFET, it allows current to pass from the positive terminal of the battery, through the resistor, and the MOSFET then completes the path back to the negative terminal. This discharges the battery over a period of time.So the MOSFET should be chosen in such a way that it can handle maximum discharge current without overheating.
I used a n-channel logic level power MOSFET-IRLZ44. The L shows that is a logic level MOSFET. A logic level MOSFET means that it is designed to turn on fully from the logic level of a microcontroller. The standard MOSFET (IRF series etc) is designed to run from 10V.
If you use an IRF series MOSFET,then it will not fully turned ON by applying 5V from arduino. I mean the MOSFET will not carry the rated current.To tuned ON these MOSFETs you need an additional circuit to boost the gate voltage.
So I will recommend to use a logic level MOSFET, not necessarily IRLZ44.You can use any other MOSFET also.
Step 6: OLED Display
To display the Battery Voltage,discharge current and capacity, I used a 0.96" OLED display.It has 128x64 resolution and uses I2C bus to communicate with the Arduino. Two pins SCL (A5), SDA (A4) in Arduino Uno are used for communication.
I am using U8glib library to display the parameters.First you have to download the U8glib library .Then installed it.
If you want to get started in to OLED display and Arduino , click here
The connections should be as follows
Arduino --> OLED
5V --->Vcc
GND -->GND
A4----> SDA
A5----> SCL
Step 7: Buzzer for Warning
To provide different warning or alert, a piezo buzzer is used.The different alerts are
1. Battery Low Voltage
2.Battery High Voltage
3. No Battery
The buzzer have two terminals, the longer one is positive and the shorter leg is negative.The sticker on the new buzzer have also " + " marked to to indicate the positive terminal.
Arduino --> Buzzer
D9--> Positive terminal
GND--> Negative terminal
In the Arduino Sketch, I have used a separate function beep() which sends the PWM signal to the buzzer, waits for a small delay, then turns it off, then has another small delay. Thus, it beeps once.
Step 8: Making the Circuit
In the previous steps, I have explained the function of each of the components in the circuit. Before jump to make the final board, test the circuit on a bread board first.If the circuit works perfectly on the bread board,then move to solder the components on the protype board.
I used 7cm X 5cm prototype board.
Mounting the Nano : First cut two rows of female header pin with 15 pins in each.I used a diagonal nipper to cut the headers.Then solder the header pins.Be sure the distance between the two rails fits the arduino nano.
Mounting OLED Display : Cut a female header with 4pins. Then solder it as shown in picture.
Mounting the terminals and components : Solder the remaining components as shown in pictures
Wiring : Make the wiring as per schematic.I used colored wires to make the wiring, so that I can identify them easily.
Step 9: Mounting the Standoffs
After soldering and wiring,mount the standoffs at 4 corners.It will provide sufficient clearance to the soldering joints and wires from the ground.
Step 10: Software
The software doing the following tasks
1. Measure voltages
Taking 100 ADC samples , adding them and averaging the result.This is done to reduce the noise.
2. Check the battery condition to give alert or start the discharge cycle
Alerts
i) Low-V! : If the battery voltage is below the lowest discharge level ( 2.9V for Li Ion )
ii) High-V! : If the battery voltage is above the fully charged condition
iii) No Battery! : If the battery holder is empty
Discharge Cycle
If the battery voltage is within the low voltage ( 2.9V )and high voltag (4.3V),discharge cycle start.Calculate the current and capacity as explained earlier.
3. Display the parameters on the OLED
4. Data logging on serial monitor
Download the Arduino Code attached below.
Step 11: Exporting Serial Data and Plotting on Excel Sheet
To test the circuit, first I charged a good Samsung 18650-26F battery using my IMAX Charger.Then put the battery in to my new tester.To analyse the entire discharge process,I export the serial data to a spread sheet.Then I plotted the discharge curve.The result is really awesome.I used a software named PLX-DAQ to do it. You can download it here.
You can go through this tutorial to learn how to use PLX-DAQ. It is very simple.
Note : It works only in Windows.
Step 12: Conclusion
After few testing I conclude that the tester result is quite reasonable.The result is 50 to 70mAh away from a branded battery capacity tester result.By using a IR temperature Gun, I measured the temperature rise in the load resistor also,the maximum value is 51 deg C.
In this design the discharge current is not constant, it depends on battery voltage.So the discharge curve plotted is not similar to the discharge curve given in the battery manufacture data sheet.It only support a single Li Ion Battery.
So in my future version I will try solve the above short comings in the V1.0.
Credit : I would like to give credit to Adam Welch, whose project on YouTube was inspired me to start this project.You can watch his YouTube video.
Please suggest any improvements.Raise a comments if any mistakes or errors.
Hope my tutorial is helpful.If you like it,don't forget to share :)
Subscribe for more DIY projects. Thank You.
24 People Made This Project!
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
145 Discussions
OzanH3
Question 2 months ago
Hi. How many milliamps maximum can be measured with this project?
1 answer
LucianoHannaOzanH3
Answer 4 days ago
Hi, I think it can measure max 3.4028235E+38mAh for ~71582 hours, if the value is greater than that, will have a overflow, don't know if have any limitation on hardware... probably not
s3_jarvis
6 weeks ago
Buddy, First off, I appreciate your work. Keep going on!. Now as I looked at the working principle of the design, I thought of another idea. Is it possible to directly read the discharge current using a current sensor (connecting sensor b/w Battery & Load Resistor) and then multiply it with the time it takes to discharge the battery (to say 2.5 V) and find out the capacity? Do let me know if it's possible.
Regards,
s3_jarvis
Open Green EnergyDarenS3
Reply 2 months ago
Congratulation for your build.
Thank you for posting the picture here.
Its really excellent, it inspires me to make my V2.0 :)
pistib
Question 3 months ago
Hi ,can i replace the load resistor with 12V/5W auto bulb? (consume cc.420 mAmp)
1 answer
necronumpistib
Answer 3 months ago
I wouldn't, an incandescent light bulb increases resistance when it goes incandescent, the reading will be off as the resistance will not remain constant.
DavinderM
Question 1 year ago on Introduction
I have 7 pin oled display. So how i will wire it with arduino. Some people say that you can change it with code some say that you can change resistance at the back of the oled display to make it work. I am now confused. Which is good. Can you please make the code for 7 pin i am very poor at coding. It will be very helpful if you modify the code. I dont want to spoil my oled display so that i want to go with code modification. Please help me.
1 answer
LocronanDavinderM
Answer 3 months ago
Change this...
// U8GLIB_SH1106_128X64 u8g (U8G_I2C_OPT_NONE); // I2C SH1106 interface
U8GLIB_SSD1306_128X64 u8g (10, 9, 12, 11, 13); // 7 pin spi SSD1306 interface
Pin connection is the same as 7 pin
Change code only
SSD1306 interface Need confirmation...
good luck!
DonatasG4
Question 9 months ago
Hi. I have ssd1306 OLED instead of ssh1106, which part of the code i have to change?
1 answer
LocronanDonatasG4
Answer 3 months ago
Change this...
U8GLIB_SSD1306_128X64 u8g (U8G_I2C_OPT_NONE); // I2C SSD1306 interface
(Pin connection is the same)
or...
U8GLIB_SSD1306_128X64 u8g (10, 9, 12, 11, 13); // spi 7pin SSD1306 interface
(Pin connection is the same as spi 7pin)
good luck!
surib2
Tip 3 months ago
Bluetooth sending battery bms 1 by 1 clear arduino make pls
arduinomaster
Question 5 months ago
How do I change this to test AA bateries?
FasihZ1AlejandroA165
Reply 6 months ago
Can you please post the wiring diagram for 16"2 display.
FasihZ1FasihZ1
Reply 6 months ago
Can you please post the wiring diagram with complete code.
unable to figure it out how to do that with 16*2 display.
i tried my self like more than 12 times. still no success.
FasihZ1
Question 6 months ago
Can Some one please help me out how to do that with 16*2 display.
Tried my self more than 12 times..... But unable to figure it out how to do that.
and somehow the current reading goes negative value.
1 answer
