DIY Bath Bombs
2,193
45
This year for Valentines Day I was looking for a project that I could do with my four year old. I decided that making a bath bomb would be a cool idea because she could have fun while doing it and after we were done. It's a really easy project and is lots of fun in the bath.
What you will need:
Dry Ingredients:
  • Baking Soda 1/2 cup
  • Citric Acid 1/4 cup
  • Cornstarch 1/4 cup
  • Epsom Salt 1/4 cup
Wet Ingredients:
  • Vegetable Oil 3 tsp
  • Essential Oil 1 tsp (I used Lavender)
  • Food Coloring (to desired color)
  • Water 1 tbs
You will also need mixing bowls and a mold of your choice, I used a 3D printed PLA mold* and an ice cube tray.
*The 3D printed mold wasn't 100% effective, I may try again using ABS. Here is a link to the one I used:
http://www.thingiverse.com/thing:1333958
Step 1: Mix the Dry and Wet Ingredients Separately
For this step you simply want to combine the dry ingredients, and stir thoroughly until they are mixed together very well.
Then in a separate bowl or cup mix your wet ingredients until they are well combined.
Step 2: Slowly Add the Liquids to the Solids
You will want to slowly add the liquids to the solid mix and stir thoroughly. If you add the liquids too fast it will activate the chemical reaction and make the bomb ineffective and you'll need to start over. I used the teaspoon to slowly add it. it doesn't take long.
After you have it mixed in you should be left with a slightly squishy feeling mixture.
If the color you desire isn't there you can add more food coloring directly into the bowl and continue to mix it in.
Step 3: Place Into Molds, Let It Sit, Demold
The last thing you need is to pack it tightly into the mold of your choice. Then let it sit overnight before taking it out and testing it. If you are in a hurry stick the mold in the freezer for a couple hours. After you take it out of the mold you are ready to go.
If you have any questions please let me know. If you like this project you can find my other projects in the links below:
KagedCreations@gmail.com
Facebook: https://goo.gl/3EBL8W
Instagram: https://goo.gl/3EBL8W
Instructables: https://goo.gl/3EBL8W
Twitter: https://goo.gl/3EBL8W
YouTube: https://goo.gl/3EBL8W
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    2 Discussions
    XaviOrin
    2 years ago
    Good tutorial! I make these for a living and from personal experience I would say cutting out the water and using however much oil gives you a damp sand texture that sticks together is my own process. I've found that not using water at all helps prevent cracking once the bath bomb is dry.
    While I've never tried a 3D printed mold I have tried silicone molds and I would say try to avoid silicone if possible because the harder you're able to pack the bath bomb the better it sticks together later.
    Thanks for sharing!
