DIY Buck/Boost Converter (Flyback)
58,993
330
67
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how a buck/boost converter (flyback) works and how you can easily build one that can step up and step down DC voltage efficiently. Let's get started!
Step 1: Watch the Video!
After watching the video you should have the basic knowledge to create your own buck/boost converter. The next steps though will contain additional information to make your life easier.
Step 2: Order the Components!
Here you can find a parts list with example seller:
Amazon.com:
1x ATtiny85: http://amzn.to/2e1mPzU
1x MCP602: http://amzn.to/2e1mPzU
1x 7805 5V regulator: http://amzn.to/2e1mPzU
1x IRLZ44N: http://amzn.to/2e1mPzU
1x 100kΩ Potentiometer: http://amzn.to/2e1mPzU
1x 0.03mH Inductor: http://amzn.to/2e1mPzU
1x 1N5819 Schottky Diode: http://amzn.to/2e1mPzU
2x Screw Terminals: http://amzn.to/2e1mPzU
2x 100nF Capacitor: http://amzn.to/2e1mPzU
1x 100µF, 1x 220µF Capacitor: http://amzn.to/2e1mPzU
2x 10kΩ, 2x 5.1kΩ, 2x 20kΩ, 1x10Ω Resistor: http://amzn.to/2e1mPzU
Ebay:
1x ATtiny85: http://rover.ebay.com/rover/1/711-53200-19255-0/1..
1x MCP602: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 7805 5V regulator: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x IRLZ44N: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 100kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 0.03mH Inductor: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 1N5819 Schottky Diode: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
2x Screw Terminals: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
2x 100nF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 100µF, 1x 220µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
2x 10kΩ, 2x 5.1kΩ, 2x 20kΩ, 1x10Ω Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
Amazon.de:
1x ATtiny85: http://amzn.to/2dWIc4j
1x MCP602:http://amzn.to/2dLaboV
1x 7805 5V regulator: http://amzn.to/2dWHC6K
1x IRLZ44N: http://amzn.to/2dL9WKB
1x 100kΩ Potentiometer: http://amzn.to/2dLaikl
1x 0.03mH Inductor: http://amzn.to/2dWIojS
1x 1N5819 Schottky Diode: http://amzn.to/2dLapwo
2x Screw Terminals: http://amzn.to/2aTTLNW
2x 100nF Capacitor: http://amzn.to/2dWJaNW
1x 100µF, 1x 220µF Capacitor: http://amzn.to/2dL9dsO
2x 10kΩ, 2x 5.1kΩ, 2x 20kΩ, 1x10Ω Resistor: http://amzn.to/2aAsWdV
Step 3: Create the Circuit!
Here you can find the schematic and pictures of the circuit that I created. Feel free to use them as a reference. You can also find the schematic on EasyEDA: https://easyeda.com/GreatScott/ATtiny_Buck_Boost_C...
Step 4: Upload the Code!
Here you can find the code that you need to upload to the ATtiny85 before plugging it in the circuit. If you don't know how to upload the sketch then make sure to watch this video of mine:
Step 5: Success!
Awesome! You did it! You just created your own buck/boost converter!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
67 Discussions
erastescientifique
17 days ago
J'ai essayé de charger le code mais voici l'erreur qui s'affiche : exit status 1
'TCCR1' was not declared in this scope/
que faire s'il vous plait ????
razim_sha
Question 3 months ago
please anyone tell what is the value of R9
1 answer
sivadasrajan007
Question 7 months ago
Hi
i tried to replicate the results with following changes
used a breadboard
1.used an arduino nano
2.replaced irlz44n with irfz44n
3. didnt use 100nf cap at output of 7805
4.used attached code
5,didnt use the feedback circuit
i powered the circuit with a 12v rectified filtered(not regulated) output
when i adjusted the pot and went above 16v something (i suppose 7805) started to make a buzzing noise i kept going up and my nano behaved erratically and windows refused to detect the nano for a while.
can anyone tell me what went wrong?
Relaf
Question 9 months ago on Step 5
May i know the max voltage and the max current this circuit is capable of?
KIGULAB
Question 1 year ago on Step 4
whats is the logic of using "cont int" instead of "int " ???
i never under stand when to use which.............
1 answer
Valenorious.KIGULAB
Answer 1 year ago
"int variable_name" is declaring a variable, which could potentially be altered in the course of the program's execution (accidentally). Pin-numbers should not be considered variable. The hardware is allways connected to the same pin. They are to be considered constants. Hence the "const". "const int" means the name after it is a constant of type integer. Constants are not allowed to be altered during the course of the program. You'll get compilation errors if you try. So this is proper programming ettiquete.
khavoc
Question 1 year ago
Why do you have the signal going to the IRLZ44N on a voltage divider. Are you using the Mosfet itself to limit the current?
Edit: I just noticed it was 10 ohms and not 10k as the base resistor. I thought it was 2 10k ohm resistors making it a 1/2 voltage divider.
1 answer
Valenorious.khavoc
Answer 1 year ago
R3 is a pull-down resistor, keeping the mosfet off in case the attiny pin is left at a floating voltage (input-state) like during a reset or off. When the attiny is unpowered you don't want to accidentally switch the mosfet.
R4 is a resistor to limit the in-/out-rush current. The gate acts like a capacitor. Too much current through the pin can blow it's internal circuitry.
LexenZ
1 year ago
May I know what is the duty cycle of this circuit?
AbduA7
1 year ago
hello guys , can someone explain to me where i must connect the voltage regulater part
Minecrafter211
1 year ago
Is it possible that 2 new ATTINY85 from Reichelt are bricked out of the box?
wingweaver77
1 year ago
hello,can i use this project for solar charge controller?
thank you
AbduA7wingweaver77
Reply 1 year ago
hey dude ,, did you build it using a solar charger ?
AbduA7
1 year ago
hey , i built the same exact circuit as in the sketch with the same components and i uploaded the code to the attiney85 ,,, but it didnt work
i received an output voltage of 5volts at my 20kohms load and the potentiometer was not changing the outpout voltage ,, am thinking that the problem is with the defined pwm inputs and the pot input in the code ,
any suggestions to help make it work?
LexenZ
1 year ago
The code has seem to be changed, I am unable to replicate the same results as with the previous code... may I have the older code uploaded?
Nonametruck
1 year ago
Is there a way to add current control to this also? I am Novice Newb please help
jeverhar
2 years ago
How about a list of specs such as input/output voltage range, output current, etc?
LexenZGreatScottLab
Reply 1 year ago
I can't seem to produce a 1-2A based on this specs, I am only able to get 0.3A at most to charge a smartphone, any solutions on this?
