DIY Cable Drum Rocking Chair
47,941
1,117
30
This is our first time doing this... so its a little rough around the edges.
What you need:
Nuts, Washers, Nails, Tape.
Tools:
Router, Drill, Hammer, Wrenches and what not.
Anything else you take a pleasing towards.
Step 1: Locate Drum
Step one, go find yourself a nice looking wooden cable drum. Make sure it doesn't already belong to someone.
Step 2: Gather Your Tools
consider them gathered
Step 3: Dismantle
Don't loose any of your pieces, they will be handy later on.
Step 4: Router That Bitch
We used the wood panels from the drum to measure out where the router should route, penciling in where each panel was and numbered them accordingly.
Step 5: Copy and Paste
If you have trace paper, excellent; we did not. We used Baking paper and traced the grooves from the first routing experience and traced it onto the other piece of the frame (obviously turn the paper so it works).
Step 6: Drill That Mofo
next comes new holes for the metal rods, for support. You will see in the next few steps where we found the best positioning for those rods where in order to get enough support for the structure.
Step 7: Positioning
Position your nuts and bolts and what not on you metal rods so that there are 4 on the rods screwed down maybe approx. 10cm down the rod (basically screwed enough to put the rods through the holes from the drilling). .
Step 8: Line Everything Up
after putting the rods in their rightful place (and nutting it on the outside of the structure), put everything into place. Wood panels in the routed areas. It took a couple of times for us to get it to work, as you can see form the picture, we ended up taping all the panels so they wouldn't fall all over the place.
Step 9: Popping the Lid Ontop
Next is putting the next round bit on. one of us had to guide it in from the bottom and the other from the top. Again, didn't get this on the first try.
Once everything we in and secured, we tightened everything up with the torque wrench.
Step 10: Finish the Beauty
Once all is tightened and secured test it out. This was our first go at this, so its not perfect and quite rough around the edges (or rather wonky everywhere). But it looks great, nice and "rocky" and set for them summer BBQs.
Hope this was clear, enjoy!
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
30 Discussions
JhomaylaV
2 years ago
nice steps hahaha
AnthonyA15
3 years ago
One way u can get your hands on FREE wire spools is go to Lowes ask electrical associate to save u a wire spool they have plastic and wooden spools with woden core/slats just give them your name and number and presto u have full access to all the free spools u want.
hogthrob
4 years ago on Introduction
Good Work! - lovin step 2 - then I realised its spray and not a can of beer!
Oh and Lime 3D does he not realise mofo is in reference to 'Morrison Foerster Law' www.mofo.com - who wouldnt want to put a drill through a lawyer!
zork the destroyer
4 years ago
It is doubtful you would find one, there is a $45-$90 deposit to the wholesaler. Electrical companies tend to want that deposit back as they go through several of these rolls every job.
lime3D
I'm no saint myself, but I can do without the inference to profanity in your step titles.
SirRahKnight
4 years ago on Step 10
Love the concept, I know where I can get a couple of these spools, I have a simple modification I would recommend and that is a rocker stop (just 4 4 inch 2x4s) tacked on to maximum rock position fore and aft on the rockers to prevent it from rolling over and hurting someone. This as it is is dangerous around children. You could even just use the edge of the rocker as a guide to cut the contour of the rock stop. But I will definately be building a couple of these.
antiochnoktedarketab
Reply 4 years ago on Introduction
What's going on in that pic with what seems like a huge cable drum in the background?
(I mean, other than a cute guy probably driving girls wild!)
bettina-sisr
Last summer there was some construction down the road, and sitting in the midst was a huge one of these with a note saying "FREE, TAKE ME". Since I only lived a couple blocks away a friend and I just decided to roll it home when a cop pulled up alongside of us and said "uh, are you supposed to be doing that?" OK now I am a 46 year old Mom so I thought the cop was joking, I quipped back "no officer, we just stole this, ha ha" he wasn't sure what to think at first, but as I realised he was serious, he realised I was joking I said "oh no, there was a note" We both laughed, but make sure you don't get arrested if you do find one of these! P.S. Great job guys!!
hamsammy
4 years ago
Looks great! I like that it doesn't require anything extra: if you find a spool, you've got a chair.
hiboyford
4 years ago
Thinks for the great idea. Now I have some thing to tell my wife what I'm doing with things I drag home!!!
User1
Nice idea! Looks like this could easily be made for two people. This setup is supposedly for one right? If it was for two people, the sides would give it a little privacy and little more intimacy ..... wink, wink. Seems like you could easily make some sleeves to cover the threaded rods too.
JonGoku
Awesome concept. It feels a bit "figure it out as we go" but that's what 'rocks' about it! I'm sure if you decide to build another it will be even better.
A couple questions:
1) Did you guys consider extending the back beyond the diameter of the wheel, or did the seat use up all the original core wood parts?
2) Are there any stops along the back base of the wheel, or will leaning too far back leave gravity, athleticism, and survival of the fittest to decide the outcome?
3) It's hard to get a feel for scale, but where do a typical adults arms come to rest while seated? If the top of the sides are too high for comfort, without destroying the cool circle effect, would it be possible to hole out slots large enough to act as "arm rests"?
Again, what an awesome idea! If I find a similar type drum I may have to give this a go!
