Chevron Cutting Board
10,545
106
13
About: Hi, I am Ashley. I am a geek and woodworker. I am author of the DIY and woodworking blog, Handmade with Ashley. I also have a YouTube channel where I share video tutorials. I have always been into crafts. M...
Hello everyone, today I’m sharing how to make a round, chevron cutting board. This cutting board was created from some maple and walnut scraps I had laying around in the garage. I came up with the idea for the board while brainstorming ideas for the second Instagram Mini Builder Challenge. I love how it turned out and I’m excited to share how you can make one of your own.
Supplies:
Step 1: Tools and Materials
The following items are some of the tools and materials (affiliate) I gathered to create the chevron cutting board.
TOOLS
MATERIALS
Step 2: Glue Walnut and Maple Strips Together
I have previously documented steps on how to take rough sawn lumber and mill it into ready to use lumber. CLICK HERE to read my detailed tutorial on how to make a cutting board. In this Instructable, I will skip over the milling steps.
Rip the walnut into 1 1/2″ strips and the maple into 1/8″ strips. I used my Micro Jig GRR-RIPPER with the 1/8″ leg to safely rip the thin strips.
Use ample amount of glue and clamp together the walnut and maple strips.
Step 3: Crosscut Walnut and Maple Board at an 45 Degree Angle
Clean up the dried glue and cross cut the board into strips at a 45 degree angle on the table saw. My strips are about 1 1/2" wide. This can be a tricky cut as you get to the last cuts. Take appropriate safety precautions.
Step 4: Arrange Pieces Into a Chevron Pattern and Glue Together Again
Arrange the strips to form a chevron pattern. Use ample amount of glue and clamp together.
Step 5: Cut Out a Circle
Clean up the dried glue and cut the board into a circle. There are several ways to do this. I used a router with a circle cutting jig. In hindsight, I wish I made a circle cutting jig for my bandsaw and cut out the circle via that route.
Step 6: Round Over the Cutting Board's Edges
To spice up the appearance of the cutting board, I added a 1/4″ round over to the top and bottom edges of the cutting board.
Step 7: Sand and Prep for Finish
Cycle through grits of sandpaper up to 220. Raise the grain of the cutting board with a damp cloth before one final sanding with 220 grit sand paper.
Step 8: Apply a Food Safe Finish
Apply a food safe finish.
I used a coat of mineral oil. Once it dried, I added a coat of Howard’s Butcher Block Conditioner.
Step 9: Enjoy!
I’m really happy with how the chevron cutting board came out. I love the look of the board and can’t wait to make a few more. Thanks for checking out my Instructable!
Watch a video tutorial down below:
Instagram: https://www.instagram.com/handmadewithashley/
YouTube: https://www.youtube.com/channel/UC6SOnloZ_nBrrVLJu...
Twitter: https://twitter.com/handmadewithash
Website: www.handmadewithashley.com
Stick It! Contest
First Prize in the
Stick It! Contest
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    13 Discussions
    jessyratfink
    9 months ago
    Absolutely stunning!!
    dnhandcrafted
    9 months ago
    I love how this turned out Ashley! It is so striking, especially the contrast and the beautiful lines. Great overview video as well. I'm really starting to get an itch to make a cutting board after seeing this as well as Bruce Ulrich's video and 'ible on cutting boards.
    Bruceaulrichdnhandcrafted
    Reply 9 months ago
    Right on! Do it! What wood will you choose? If you use walnut, people will say you're going to poison people. ;)
    attyschack
    Question 9 months ago on Step 3
    I don't see the dimensions you used to cut the 45 deg strips. Also, your video mentions that you made a couple of mistakes. Might be helpful to say what those were so we can avoid them if we try to make this. Very nice result.
    1 answer
    handmadewithashleyattyschack
    Answer 9 months ago
    thanks for pointing that out. I'll update the step. The strips are about 1 1/2" wide. The main mistake I'm referring to is a slight alignment issue when I clamped together the chevron pattern. Not really noticeable unless you really stare at it, but because I know it's there it bothers me. :P
    Perpetual98
    9 months ago
    Did you not use the planer you called for in the tool list?
