DIY Electric Powered Wheelchair
18,528
65
14
About: I'm a Mechanical Engineering graduate from UC Davis and I love to build things and figure out how stuff works. I enjoy design work, both in the field of engineering and general graphic design as well. When...
When studying Mechanical Engineering at UC Davis we were required to participate in a Senior Design Project. For my project, I chose to work on a DIY Electric Powered Wheelchair that anyone could build. Myself and two of my classmates used our engineering background over the course of two quarters to design the following wheelchair. I created the instruction manual attached in the last step as a way to document our build in hopes that anyone could follow our steps. This Instructable summarizes the document and showcases the performance of the chair.
Step 1: Project Background, Needs and Specifications
Project Background
Current electric wheelchair users constantly have to deal with high insurance prices and long wait times when it comes to purchasing and repairing their electric wheelchair. Specifically, our sponsor Pamela had to wait several months just to have her caster wheel assembly replaced. For someone who requires their chair for a main mode of transport, this is unacceptable. Additionally, the wheelchair manufacturers have been creating chairs with lower specs (torque, average speed, etc.) while insurance companies are raising the costs to own such a chair.
The goal of the project was to avoid these negative setbacks and also prove someone could build their own electric powered wheelchair in their garage using basic tools such as a chop saw and drill press. The scope of our project included producing a working drive-train and frame that would provide a solid foundation for our sponsors, WHIM Unlimited, to develop a fully working and refined electric powered wheelchair. We hope this assembly guide will provide the necessary framework for others to build their own chair, ending the longtime dependence on inconvenient health and insurance companies. This guide is by no means includes a final product, but rather a proof of concept and a framework for others to build off of to fit their own personal mobility needs. For more information, please visit whimunlimited.com.
Project Needs
Based on our meetings with our sponsors, we determined our chair would need to exhibit the following:
  • Powertrain Needs:
    1. Powerful motor,
    2. Ability to climb road curbs
    3. Good acceleration
  • Body Needs:
    1. Stable and sturdy
    2. Maneuverable
    3. Meets ADA specifications
  • Overall Needs:
    1. Safe
    2. Modular
    3. Easy to build
    4. Easily obtainable parts
    5. Long lasting
Project Specifications
Based on our project needs, we created the following project specifications:
  • Powertrain Specifications:
    1. 3 MPH up a 4 degree incline
    2. Can go up a 10 degree curb (bump)
    3. Accelerate from 0 to 5 MPH in under 2 seconds
    4. Max speed of 8 MPH (wheelchairs on the market average about 4 MPH)
  • Frame Specifications:
    1. Max size of 30"x42" (ADA)
    2. Chair height of 15" to 25" off the ground
    3. Can handle a 500 lb load
    4. Turn radius < 44" (taken from ADA chair dimensions)
  • Overall Requirements:
    1. Use standardized parts (minimize custom parts)
    2. Easy to build (no complex geometries)
    3. Adaptable to the user
Step 2: Bill of Materials
As stated previously, we wanted our materials to be readily available and easily accessible for anyone to find. The reasoning behind this was to avoid long downtimes or having to go through a supplier that has a monopoly on selling specific parts (i.e. only one set of motors that works and only one supplier who offers them). This would also allow someone with a chair in need of repair to go to their local hardware store or order a part online and replace the faulty one quickly on the chair themselves or with a little help. Thus long down times would ideally be eliminated.
As part of our project, we researched different suppliers to find our initial sources for the parts, but we also found alternate suppliers and parts in case the primary source disappeared. The overall cost of the chair was roughly $2000 as compared to chairs on the market that range from $1000 to $6000+. Our chair is on the lower end of this price range, but it offers the specifications one would find on a more expensive model. Overall, our cost could be reduced with various design improvements and material changes, but again this was meant to serve as an initial prototype and proof of concept.
Step 3: Tools Needed, Custom Parts, and Gridbeam Cut List
As Mechanically Engineering students, we had access to a full machine shop capable of creating all the custom parts to our hearts content. Unfortunately, the average person doesn't have this luxury, thus if we took advantage of these tools then it could get quite difficult for someone to follow our instructions. For this reason, we chose to work with tools that the average person may have laying around in their garage.
A majority of our build was made using only a chop saw and drill press, however we did have to make a few custom parts. These included the driveshaft, motor mounts, and driveshaft coupler parts. We felt these parts required the most stability and reliability possible, so we chose to make simplified custom parts. We then created drawings for these parts so someone could go to a local machine shop or makerspace or even contact an online service to have them made.
We were able to use only a few custom parts thanks to our choice of framing material: Gridbeam. This material is best described as 2" square tubing with 7/16" mounting holes every 1". Unfortunately, the material is fairly heavy (~5 lbs/foot) but it does make assembly fairly easy once the cuts have been made.
Step 4: Caster Assembly
During the summer before my Senior year, I had the privilege to work at Aerojet Rocketdyne as Visual Planning Intern. Long story short, we would take advanced rocket assemblies and create a virtual build of the model so the technicians on the floors had something easy to follow when assembling the parts. Basically, I created Ikea/Lego-like instructions for rockets. Seeing as the wheelchair needed a set of easy to follow plans, I created a guide by applying the same skills I used during my internship. The finished result is a clean, easy to follow list of steps that doesn't require a B.S. in Mechanical Engineering to follow.
We created our entire assembly using Solidworks. I then planned out the best way to assemble the parts, and create the virtual build by putting together vector drawings using Adobe Illustrator and InDesign. The first assembly we decided to build is the caster assembly. The caster wheels make it a little awkward since they rolled around fairly easily, so it's best to have some help or somewhere to put the assembly as it comes together. Make sure all the Gridbeam pieces are square to each other before tightening the bolts.
Step 5: Motor Assembly
The next assembly to put together is the motor assembly. This one is a little trickier to put together and required some finessing in order to get the motors, driveshaft and motor mounts to all line up. Luckily none of the fasteners are permanent so if you mess up there's nothing to be worried about.
Step 6: Final Assembly
Once the caster and motor assemblies are together it's time to put it all together. Both assemblies are fairly heavy and awkward in size so it helps to have at least two people to put them together.
Step 7: Controlling the Chair
Our chair utilizes the open sourced Arduino and two H-Bridge shields to control the electricity to each motor. We also use a USB host shield and a cheap USB joystick to provide an intuitive control scheme. For batteries, we used two 12V lead acid batteries hooked up in series to provide a total voltage of 24V. We found this to be more than enough power and control for the prototype, however the Aruidno code needed to be refined further before the chair could be used for everyday use.
Note: I mainly worked on the overall chair design and documenting how we assembled the build. One of my other teammates worked on the actual Arduino code, but I believe he just researched code that other people had used with the H-Bridge shields. Again, we were Mechanical Engineers so learning/writing code from the ground up wasn't really really in our scope. Apologies if the lack of refined controller code is what prevents you from making your own chair.
Step 8: Testing the Chair
As part of our project, we needed to prove our chair met the specifications we outlined at the beginning of our project. We also participated in a Senior Design Showcase put on by our school where all our classmates also showed off what they had worked on for two quarters. Everyone at the showcase was impressed with the maneuverability and ruggedness of our chair and we didn't shy away from showing it off. Attached are some videos of our initial benchmark tests along with footage from our showcase. By the end of our project, we were happy to have something that actually worked and had a fun time showing it off and playing with it.
Step 9: Design Recommendations, Add-ons and Accessories
Seeing as our course was only two quarters and we had a finite budget, we didn't get to fully develop the chair like we would have. It's obviously missing a chair and other elements to provide a smooth and comfortable ride. We iterated through our design countless times but there's always room for improvement. Again, this is mainly a proof of concept and initial crack at a problem, so there are many things that could improve the chair.
Step 10: Maintenance Guide
No machine works well just by itself, but instead requires maintenance to prolong it's life. Our wheelchair is no exception. Although we were done with the project a few weeks after it was built, we still were able to forecast which components would require upkeep in order to have the best performance possible. These suggestions are mainly based on the manufacturer's suggestions for the parts, and we don't know for sure if problems would arise with other parts.
Step 11: Assembly Document
Overall, this project was my first time applying my coursework to an actual, real world problem. I hope if you choose to follow this Instructable that you share with me your hardships or any suggestions for improvements you may have. At the start of this project, we wanted to make the chair easy for anyone to follow, but at the same time allow others to adapt it to their own needs. Thank you for taking the time to read through my Instructable, and I hope you enjoyed it as much as I did making it and the DIY Electric Wheelchair contained herein.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    14 Discussions
    CherylT71
    Question 1 year ago
    hi! may i ask what motors did you use? im also doing an electric wheelchair project and wondering which motors are generally used thanks!
    jtaggardCherylT71
    Answer 1 year ago
    We searched a lot and there weren't many suppliers of the type of motor we selected. However, we were limited by the specifications we wanted for the wheelchair (i.e max speeds, ability to go up certain inclines without sacrificing power, etc.). So if you don't need as much torque then there are cheaper options out there. Mainly just do the calculations to determine what torques you want based on your desired speeds for different situations. We steered away from hub motors since their specs didn't match up with what we needed, but this may not be the case for your project
    jtaggardCherylT71
    Answer 1 year ago
    Hi there! For our project (and other ones I've seen) we used two 24V DC brushed motors. Step 2 lists the specific ones we used
    CherylT71jtaggard
    Answer 1 year ago
    wow thats expensive! do you know any other cheaper alternatives with similar specs? im not really sure what kind of motors i should get? do you think hub motors are suitable for a wheelchair project like this?
    jtaggardDhirajK30
    Answer 1 year ago
    Yep if you reference Step 2 one of the images has all the materials we used
    milesnorth
    1 year ago
    My daughters electric wheelchairs motor just died (It is a very old one and they dont have parts anymore). Would you have some insights on how to retrofit a new motor to a existing electric wheelchair. It is an old invaracare one. Would love to be able to get it working again. Everything but the motor works on it I think. Frame and wheels are good. Thoughts very appreciated.
    jtaggardmilesnorth
    Reply 1 year ago
    The biggest thing we found with the motor is finding one that provides the desired torque and speed balance. Once we knew what horsepower we wanted we then shopped around online until we found one that would fit within our frame. There are various types of motors online both meant for wheelchairs and those that aren't so it's up to you which route you choose since both types typically run similarly. Regardless you'll most likely be constrained by the shape of the current frame so try to look for a motor of a similar form factor and then you'll probably have to create some sort of adapter to match new motor with the pre-existing frame
    Jim Keefover
    2 years ago
    My wife of 50 years has come to the point where she can't get around any more unless she has some type of help and because of the way our home is and the ground this motorchair is just what she needs. It's fantastic
    jeremysimons
    2 years ago
    This is awesome and well made! how long do the batteries last (distance/time). Also how long do you anticipate the batteries would last given daily use. Electric wheelchairs cost as much cars in the UK and I'm fairly sure with medical insurance they're even more expensive in the US! The maintenance alone costs thousands annually...
    jtaggardjeremysimons
    Reply 2 years ago
    The batteries that we used actually were stand ins but we were able to get around 2 hours or so out of them with constant use. They did take a while to charge but then again they weren't meant to be the permanent solution. By increasing the battery capacity or using a newer technology (i.e. lithium ion) we probably could have gotten a better range. I definitely agree with you about the crazy costs though! Our sponsor had to pay large amounts just to get the special order parts and then she couldn't even get them installed right away
    rbeforee
    2 years ago
    Wow! I need to build/modify something solar powered to get around Burning Man in Autumn 2017. Your design and instructions are amazing. The cost is well out of my means but I'm hoping I can glean solutions for several of my challenges from your excellent guide.
    jon_chalk
    2 years ago
    Very detailed instructions. Also wonderful to be able to download the instructions too. I saw that this is primarily to build the "basic" structure. Other parts (Seat, foot plates, etc.) can be customized accordingly. This one gets my vote.
    Swansong
    2 years ago
    Great instructable and awesome project! I'd suggest adding some foot plates, it appears that your toes came pretty close to the road when you went over the curb. The mobility and responsiveness you put into this is impressive :)
