DIY Electronic Alarm Clock Kits
2,469
20
Introduction: DIY Electronic Alarm Clock Kits
About: Email: louise@elecfreaks.com
Electronic Alarm Clock Kits is a set of tool for producing an electronic alarm clock. With our guidance, you can make an electronic clock completely by yourself.It is very easy, simple and funny.
Note:
For more funny creation, you can pay attention to : http://www.elecfreaks.com/
Our product store: http://www.elecfreaks.com/
Step 1: Tools&Materials Needed
To make an electronic clock, we have to prepare something first. Then we will need:
1. Adjustable Thermostat Soldering Iron
You can choose 20W internal heated or 25W external heated soldering iron. The head of soldering iron shall be cutting head. If you are a starter, you can choose prong head as well. Normally, we set solder iron temperature value to 350 degrees.
2. Ø 0.8mm Resin-core Lead Solder
3. Materials
Step 2: Solder Resistance
Firstly, we have to use solder iron to solder 10K resistance onto PCB board. (Resistance has no positive or negative point.)Then solder 4.7K and 5.1k resistance according to the relative marks on PCB.
Step 3: Solder Thermistor
Thermistor was marked NTC on PCB board. Solder thermistor onto the green circle area showed in the following picture.
Note:Thermistor has no positive or negative point.
Step 4: Solder Ceramic Capacitor
Solder ceramic capacitor onto C1 and C2.
Note:
1. Ceramic capacitor has no positive or negative point.
2. This component contains ceramic capacitor 12pf.
Step 5: Solder Monolithic Capacitor
Monolithic capacitor solder on C3 and C4.(See Picture below.)
Note:
1. Monolithic capacitor has no positive or negative point. 2. This component contains monolithic capacitor 0.1uf.
Step 6: Solder Crystal Oscillator
Solder crystal oscillator to Y1 marked on PCB board.
Step 7: Solder Triode
Electronic clock adopt 8050 Triode marked Q1-Q5 on PCB board.
Note: Triode must solder in the same direction with PCB board.
Step 8: Solder IC Socket and Plug IC
Solder IC socket before plug IC.
Note:
One end of IC socket has a small concave. This end shall in the same direction with the concave mark on PCB board.You can see the above picture for reference. There is a small concave on both IC and socket.Plug IC into socket according to the direction of concave.Don’t plug IC wrong !
Step 9: Solder Battery Base
Note:
1. Battery base belongs to surface mount type. Before soldering, you have to add tin to a side of solder plate. 2. Battery base has positive and negative point. The mark for battery base on PCB board has a horizontal line. When soldering, you have to make the iron plate of battery base mounted on the line marked on PCB.
Step 10: Solder Microswitch
You can solder microswitch according to the picture above.
Step 11: Solder Buzzer
Solder buzzer onto the green circle area pointed out in the picture below.
Note:
1. Buzzer has positive and negative point.
2. Usually, you can see the positive point marked.
3. The pins of buzzer are comparatively longer.
Step 12: Solder DC Socket
DC socket is the main power supply port of electronic clock. You can solder DC socket according to the picture below.
Step 13: Solder LED Display
Before soldering, we have to test LED display first. Supply power to LED display and check the number showed on the screen. If it works well, then you can start soldering.( The third number shall be placed upside down.)
Once you have completed soldering. Don’t forget to paste film paste!
Note:
Originally, there is a protection film on the surface of LED display and both side of film paste. Before pasting film, you have to tear down the original protection film on the surface of LED display and backside of film paste.The backside of film paste is adhesive, you can paste it on LED display directly. Then tear down the protection film on the surface and press it with a small cloth for cleaning the surface.
Step 14: Outer Shell Installation
You can refer to the above picture to do assembly by yourself.
Step 15: Test
After installation completed, you have to reset circuit so that it can work properly.
You can do it according to the following steps:
1. Cut off power supply and press functional key and "+" key at the same time.Then supply power again and release the two keys. It will display “7:59”.
2. 5 seconds latter,it will display “8:00”. This indicates successfully reset.And then buzzer alarms.Press "+" key, the alarm will stop.(Or you have to wait one minute before the alarm automatically stops.)
Feature:
Temperature Display: Every 30 seconds it will display present temperature.
Step 16: Clock Adjustment1
  • Hour Adjustment:
Press "OK" key(functional key),then hour digital tube display will start to flash. Press "+" key to adjust hour.
  • Minute Adjustment:
Press "OK" key,then minute digital tube display will start to flash. Press "+" key to adjust minute.
  • Alarm Clock Hour Adjustment:
  • Alarm Clock Minute Adjustment:
Step 17: Clock Adjustment2
  • Alarm Clock ON/OFF:
Press "OK" key, then the digital tube display illuminate but not flash. Press "+" key, the signal light on the right bottom corner of fourth number illuminates, which indicates we turned on the alarm clock . When signal light is off, the alarm clock function is closed.
  • Round Clock Alarm Set:
a. Press "OK" key,hour digital tube starts to flash. Press "+" key to adjust the beginning time of round clock alarm. If you adjust it to the number “7”, then it alarms at 7 o’clock in the morning.
b. Press “OK” key again, then minute digital tube starts to flash. Press "+" key to set a terminal time for round clock alarm. For example, if you adjust it to the number “23”,then from 8:00 am to 22:00pm you will hear round clock alarm.
c. Press "OK" key to exit. Then you have completed setting.
Note:
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Metalworking Contest
    3 Discussions
    dtpit
    1 year ago
    please upload circuit diagram n components list
    Hello, have you assembed it successfully?
    where to get components?
    any Link???
