DIY Fairy Door Using Cardboard
3,562
85
31
I made a rustic fairy door lamp recycling some cardboard from a thin rectangular box, a matches box and a couple of pizza boxes. The only bought materials I used are the colors, the hot glue and a little piece of craft foam that I used for the hinges. It took me about three days to finish.
Step 1: Cutting and Gluing the Cardboard
I started by drawing the door and the wooden frame around it. Then I cut the pizza boxes in small pieces that I glued together to make the wooden frame around the door. I wanted to have some depth so the frame looks like thick wooden beams. I glued the matches box in front of the door as a step. This will be the hidden compartment where the batteries and the lights switch will be. I used pizza boxes to create the little roof with tiles and everything. I also made flooring and and door details using the same kind of cardboard. For the hinges I used a little piece of craft foam I had.
Step 2: Texture
I sanded and cut the rough edges so I end up with an old looking wooden frame and door. I made the textured wood using a ball pen and pressing the wooden pattern deep in the cardboard. It adds such a nice effect and it will help a lot in the next step when adding color and patina.
Step 3: Painting
Painting the little door was fun. Remember I told you about the texture? Here's how it works. I cover the surface in a base color first. Then I add a very bright color or even white, but only to the surface of the texture, so I get a nice contrast. On top of that bright color you can add other colors. I made the door blue and the roof red but you can play around with any color combination you like.
Step 4: Finishing Touch
I glued the little door in place and now it can be opened and closed with ease. I covered all the surface in with a water based varnish and glued the whole thing to the wall and turned on the lights from the secret compartment. Let me know what you think.
2 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Fandom Contest
    Fandom Contest
  • IoT Challenge
    IoT Challenge
31 Discussions
Gadisha
3 months ago
Nice, you could leave this partly hidden under the trunk of a fallen down tree and Let kids wonder about it :)
FlorinJ
3 months ago
Can you maybe write a tutorial about painting? I'm pretty sure I can do the cutting and gluing, but I was never good at drawing, and it's not just plain painting what you do - plain painting, like walls or furniture, that I can do.
FlorinJCreative Mother
Reply 3 months ago
I watched that one too :-) You are right, there is a tiny bit more detail on painting there. I meant more of a generic painting tutorial. But I'll see what I can do starting from there.
What kind of paint did you use? Any advice on brushes?
Creative MotherFlorinJ
Reply 3 months ago
I used acrylics, and cheap, medium sized brushes you find at craft store, nothing fancy.
FernMakes
3 months ago
I don't know how you get such character and texture out of cardboard with all your projects...fab job!
sicnarff
3 months ago on Step 4
I just love it and I can't wait to have a go at making one myself. Thank you for sharing your design.
Fran
TossManual
3 months ago
Shhhh, kids. You hear those little clunks in the other room? Mommy's creating. With Fairies. ;)
Love it.
