DIY: Illuminated House Number Powered by Solar Panels
33,183
390
23
This time I made illuminated house number powered by solar panels.
How I made it - you can check by looking DIY video or you can follow up instructions bellow.
For this build you will need:
Materials:
6 solar garden lights
1 AAA rechargeable battery
a piece of plastic board
some wires and isolating materials
L shape aluminium profile
Tools:
Soldering iron
Drill and bits
Screw driver
Rotary tool (for example Dremel)
Step 1: Solar Garden Lights
The power source for this project will be solar garden lights. They are super cheap and simple construction. In day time, they collecting solar power and store it in one AAA battery. When solar cell can't detect light any more - internal circuit turn LED On. For this project I'll use 6 of them.
Step 2: Preparing Materials
Like I said - there's solar panel, simple circuit and battery. From 6 solar garden lights I'll use all LEDs, all solar panels, one circuit and one battery. Let's take them a part and desolder necessary parts.
Step 3: Making One Big Solar Panel
To hold all solar panels in one place I made a simple holder by drilling 6 holes in piece of plastic.
Drilled small holes for wires and soldered them together.
All panels was connected in parallel and soldered to operating circuit board. Soldered two wires to connect LEDs later.
Step 4: Working on Panel
Those solar garden light came with one AAA 600mAh battery inside. I tested the real capacity of them - and got only about 50mah of capacity. So I'll change that crappy battery with Panasonic Eneloop with 750mAh of capacity.
Assembled everything back.
Sanded holder surface and painted in black. All panels fitted very snugly, so there's no need any additional glueing.
Step 5: Engraving Acrylic Plate
A number plate was made from 8mm acrylic. I have possibility to use a friends engraving laser machine. All engraving process took about 15 minutes.
Acrylic plate dimensions is 21 by 17 centimeters.
By cutting with laser it leaves very nice edge. It looks like been polished.
Laser engraved about few parts of millimeter in acrylic surface. Top quality job.
I left protection film on back of plate, until I'll finish fabrication process. So that's why acrylic is looking a little bit blue.
Step 6: Engraving Option With Rotary Tool
Engraving process could be done with any rotary tool and engraving bit. Here is a quick example. This is really time consuming process, but with some patience you could get very good results.
Step 7: Soldering LEDs
Drilled 6 holes to fit LEDs inside.
Before start soldering - I want to remind you, that LEDs are sensitive for polarity. There is the negative and opposite side the positive terminal.
All 6 LEDs will be soldered in parallel. I measured a good place for soldering point and marked it by pressing with nail. With electric wire striping pliers prepared surface for soldering, twisted wire on LED leg, soldered and isolated with shrinking tubes. In same technique was soldered all of rest LEDs and connector too.
Step 8: Mounting Bracket
Mounting bracket for acrylic plate was made from L shape aluminium profile. Drilled few fixing holes. Screwed bracket in place and glued connector. To make good joint I sanded both surfaces.
Step 9: Testing...
Ok let's peel off protective film of and take a look at final result.
Solar panels are detecting light, so LEDs are off. When lightning source was turn off - at the same moment LEDs will kick in and numbers starts glowing.
As you could see - glowing only engraved surface and edges of acrylic plate. This could be eliminated by painting edge, but at moment I like how it is.
Step 10: Instalation Outside
Let's mount every thing outside. Solar panel fixed on a roof.
Step 11: Operation at Night
Here is how it glows at night. I'm very happy how it looks. Numbers are illuminated very evenly. The intensity of light is very delicate. It it easily visible from 3 meters.
I hope you liked and will try to make it:)
Solar Contest 2016
Second Prize in the
Solar Contest 2016
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    23 Discussions
    bundyb
    2 years ago
    Nice little project. Good project for those that want to combine a little bit of electronics with some handyperson projects. I like it. Just some more info for those that may be interested. Using more than one battery in parallel (- to - and + to +) will allow a greater storage capacity for a longer lasting light. One battery is 600mAh (in picture), two would give you 1200mAh, etc. Light time is relative to the amount of LEDs you use, the more LEDs you use the shorter the light time on one battery. Note: placing batteries in series (- to +) will increase the Voltage. Not good for the LEDs.
    PavelS70
    2 years ago
    It could be even better if the laser would be focused inside of plastic board to burn numbers inside of the plate
    A PottsPavelS70
    Reply 2 years ago
    That's not really possible with the type of laser that is commonly found and used for engraving. If you change the focus from the front of the panel to the middle, it will still effect the front, but the engraving will be unfocused and possibly uneven. Turning the power up or the speed down on the laser will produce a deeper engraving, and flipping the illustration and engraving from the rear will leave the front surface smooth and may look better in this application.
    Source: I do this 80 hours per week
    PavelS70A Potts
    Reply 2 years ago
    With this type, yes, it's not. But it must be possible with significantly convergent beam
    loskop100.
    2 years ago
    I don't know if it is the same with a laser but with a router if the engraving is done on the rear face, the etched area is much brighter viewed from the front side.
    mikadillo
    2 years ago
    I am unclear why you used the 6 panels. The LEDs are being powered by the battery. Putting more panels in will not change the power output of the battery and thus not change the brightness. It will only speed the recharge time during the day and might get the battery completely charged on overcast winter days. The better battery only gives you a longer lasting light. Am I missing something?
    DriesV
    2 years ago
    Be careful, I think there is a registered patent by the name "Number Light"
    Mick GibsonDriesV
    Reply 2 years ago
    I used to make them with Christmas tree lights and they would blink. I could get 8 different colors for my ads, in 1971.
    Mick GibsonDriesV
    Reply 2 years ago
    It does not really apply! The parts are different and the device is made by hand!
    You can make any patent if you can figure it out. You can not sale them!
    Beekeeper
    2 years ago
    I wonder if I could mask the numbers and use sandpaper as I don't have an etching machine or sand blasting equipment? Any ideas out there as to whether this might work?
    KyleA37
    2 years ago
    Well done!
    Gilo
    2 years ago
    Opps. DennisB6 already suggested that.
    Gilo
    2 years ago
    Exactly what I needed for my post box. Great job.
    I think you can also use sand blasting to etch the numbers using the plastic protective film as a stencil.
    Crazzed1
    2 years ago
    Very nice. I wonder how covering the edges with foil tape would reflectivity. Guess I'll build one and find out.
    DennisB6
    2 years ago
    I like this vary neat. Another way to put etching on Glass or Plexiglas lay it all out with tape and stencils but cover the the hole face that you don't want anything on sand blast it works well. Thank you
    Stezo_15
    2 years ago
    Awesome job! Thanks!
