DIY Inexpensive Deck Rails Out of Steel Conduit!
12,447
95
27
About: There is nothing I love more then making something new and usable again that someone else would have thrown out or torn down! And there's no reason to buy new when you can build it yourself!
A post on how I built inexpensive deck rails out of steel conduit. Have you seen the gorgeous steel wire railings that have been populating Pinterest the last couple of years and gaining huge popularity? Well I sure have and I’ve been drooling over them for months and months… at least until I saw the price tag. It was an absolute no go for us, on top of that they do require tightening over time and that kinda bugged me too. I was leaning toward just wire fencing (yes like hog panels) but that felt a little rough and I would have wanted to frame them out in wood and that would have been labor intensive and costly.
I didn’t want to do the regular spindles for several reasons: the first being I find them kind of boring and the other reason being that, they too, are very labor intensive and expensive when it comes to a deck the size of mine (over 700 square feet!) I also really didn’t want to obstruct the view.
Step 1: Steel Conduit Installation
The light bulb went off one day when I was in the electrical department of my local fleet store and I caught a glimpse of the 1/2″ steel conduit. And then I saw the price and my heart literally jumped: at $2.99 for 10 feet this could work! At first I was going to drill through every single post around the whole deck and thread all of the conduit through them. Well, I don’t know about you, but the idea of drilling three holes through my posts really made me wince at how much I would be hurting their structural integrity. I literally had images of them breaking off in my next serious storm. So, no go on the drilling. I saw steel hole straps on Amazon (at only $10.49 for 100!) and I knew exactly how we were going to do this.
I went around the deck first making a mark where each pipe strap would be using a scrap 2×2 that I marked with a magic marker. I put all the straps over my marks leaving the screws a touch loose so it would be easy to thread the pipe through. Once the pipe was in place I just had to tighten them all down. I cut the pipe when I needed to using an angle grinder with a steel “blade”. At first I didn’t want any “seams” but these little pipe couplings were small enough that they didn’t bother me.
Step 2: Competion
At first I was going to try and have the seams random but once I started adding the pipe I preferred the look of all the seams in the same place. When I was working at this it occurred to me just how versatile this idea is. Why not use PVC pipe and spray paint it to look like copper or wrought iron? Or you could just literally use copper pipe or galvanized pipe (though the expense would be more) and you could also use big rope here too.
All in the deck rails cost only about $110! Pretty amazing for only a couple of hours of work and now my deck finally looks almost finished. Next job is to make the gates! (Note: you will have to check with your local building ordinances if you want to build a deck railing up to code ESPECIALLY if you plan on selling your home. Every state, city and county has their own very specific ordinances I also double checked with our house insurance company to make sure that this would work with our plan.)
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    27 Discussions
    Olga M Sacasa
    11 months ago
    I found your project by accident and absolutely love it. I've been thinking about how i could replace my railing that is all warped. Bingo! You gave me the solution.
    GrandmasHouseDIYOlga M Sacasa
    Reply 11 months ago
    Awesome! These have held up well so far no rust even after our ridiculous winter lol!
    Billtco
    1 year ago
    If you want to eliminate the couplings you could use wood dowels inside the conduit and wrap some foil duct tape over the seam. the wood will swell up and stay secure inside. The tap keeps rust from showing on the un-galvanized ends.
    I would hesitate about drilling holes in the 4X4's.It won't weaken the columns if you drill in the center as the greatest stresses are in the outer wood fibers
    PetrN18
    1 year ago
    Dobré řešení :-)
    GrandmasHouseDIYkwhit190211
    Reply 1 year ago
    Hi there, we're kinda hoping for that here lol, think it will go fine with our "barn yard" look we have going on. But I would think a good rustoleum paint would take care of that problem. Thanks for coming by and checking it out!
    merideth
    1 year ago
    This is a cool looking solution! This is going right in my "save" folder.
    onlyHischild
    1 year ago
    What are "seems"? Could you possibly explain the term? I'm an inexperienced/new wood worker. I really should find a glossary of terms through Google. I love the deck railings!
    TeresaM7onlyHischild
    Reply 1 year ago
    She means "seams." The joining between two separate pieces to make a single piece. In
    sewing, it's where two pieces of fabric are sewn together to make a
    "seam." In this case, couplings were used to join pieces of conduit
    together.
    AR1911
    1 year ago
    My new deck rails look identical to your "before" photo. I had considered conduit as well but was concerned that they would bend too easily. Not a problem? I would totally drill the hole. There is virtually no loss of strength. Looks good, I'm off to buy some conduit. Thanks
    GrandmasHouseDIYAR1911
    Reply 1 year ago
    Awesome! The conduit we purchased was surprisingly sturdy!
    EdM42
    1 year ago
    Yes, many codes require being able to pass the "4 inch ball" test. However some locations also ban horizontal bars. Anything climbable is no good.
    Otherwize, I like it. We chose a more expensive design. We bought a typical vinyl railing kit and replaced the most of the vertical strakes with horizontal stainless steel bars. Usually SS bars would be way too expensive but we lucked into a cheap source. If we had thought of conduit, we would have gone thsat way.
    GrandmasHouseDIYEdM42
    Reply 1 year ago
    Oh that looks awesome! Thanks so much for sharing with us!
    jimarch
    1 year ago
    To comply with the 4” code I used “hog panel” available from the local farm supply. Only the top 2 rows are larger and could be cut off if you want. It’s just as cheap and looks great.
    GrandmasHouseDIYjimarch
    Reply 1 year ago
    That's a wonderful idea and actually something I considered doing too! Thank you for sharing with us!
