DIY - Mini Belt Sander
33,699
298
21
I made a simple Belt Grinder Machine using scrap material.
The electric motor was an original 550w hydromassage pump.
At 2400 rpm, the belt goes to 15 m / s.
The base is made of 120 mm "C" iron profile.
The wheels are original spare parts of 125mm rotating-wheels for 30mm width.
The machine it's built for use the same belt of another belt sander I have, but split for three (4x36 belt).
Supplies:
Step 1: Motor Flange Adapt
The electric motor was an original hydromassage pump (In the image the first to the left).
For this project, I need to remove the impeller and modify the flange on the lathe.
I build a motor Arbor's adapter for extending and to host the wheel.
Step 2: Make the Base Frame
The base is made with two pieces 120 mm "C" iron profile.
The horizontal piece supports the motor and under the electrical connections and motor's capacitor.
On vertical piece, I made slots for the support tables and flat plates.
On back the vertical pillar for upper wheel support.
Spring inside the vertical pillar keeps sanding belt tight on wheels.
To cover the electrical contacts, with a scrap aluminum plate I made the bottom cover of the base.
I used a Sheet Metal Shears and a hydraulic press.
Step 3: Make Support Tables and Flat Platens
With some pieces of metal, I made the fixed table supports for sanding and support platen provides flat sanding surface.
Step 4: Make Upper Frame
The upper frame is made for supporting the wheel bearings hub.
The frame has the shape of an "L".
On the top a cross hole as a hinge and a slot for bearing hub.
The bearings hub is hinged on the frame and a screw knob it allows adjustable wheel tilt.
The bearing hub is made on a lathe.
Step 5: Finish
And finally the wheels.....
The machine works very well and I'm very happy about has done.
This project it's made in mind without a blueprint.
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    21 Discussions
    jaxboy
    1 year ago
    I like your machine. Does anyone have any ideas on how to source wheels cheaply? Every place I have looked, the wheels are VERY expensive! Any ideas maybe on making your own? Any ideas would be appreciated.
    RealElwood
    1 year ago
    Great build, I will definitely use this for inspiration, I wonder about the wheels. Is it spare parts for a belt sander or just standard wheels for a cart or similar?
    sbinf74.RealElwood
    Reply 1 year ago
    Thanks,
    The wheels are original spare parts of 125mm rotating-wheels for 30mm.
    You can find them in rubber or Polypropylene.
    gm280
    1 year ago
    Very nicely build. My only question is, why didn't you go for a much wider belt setup? The motor could easily drive a lot wide belt and that would make the belts last longer as well, more area to use. But nice build anyway. Thumbs Up!
    sbinf74.gm280
    Reply 1 year ago
    Hi gm280,
    I chose this setup because I use the same belt of another belt sander I have but split for three (4x36 belt).
    This machine it's made for fine work.
    Thanks for thumbs up ;)
    JariH2sbinf74.
    Reply 1 year ago
    Hi! Would You advice, how You split the belt? If You use knife blade, do You start inside the belt or do You use a cutting jig etc?
    sbinf74.JariH2
    Reply 1 year ago
    Hi, for split the belt, it's enough Just a small cut, about 4 cm,
    then just pull it.
    The fiber in the belt will guide the cut.
    Greetings from England...I'm looking forward to coming over again to Italy in a few weeks time. I love the country that you live in.
    Congratulations on producing this excellent instructable. The final product is great quality. I'm very impressed by all the different engineering processes that you have used while you were making this machine. It looks good, it is made to a high quality, it works very well, and in every way it demonstrates what Instructables is all about.
    d.eco
    1 year ago
    Great build. This tool is in my wish list of tools. Do you think I could make a even smaller one, using a smaller motor, like the 775 dc motor?
    sbinf74.d.eco
    Reply 1 year ago
    I think you can try ;)
    Daggs42
    1 year ago
    Great presentation, I do not have the lathe or a folder in my back shed but it has stirred some imaganative thoughs as to how I could do something like this with the tools that I have.
    The video clip was awesome, I wonder what software did you use for this?
    Cheers
    sbinf74.Daggs42
    Reply 1 year ago
    Daggs42
    thanks for your comments.
    For the video clip, I use Windows Movie Maker.
    MakrToolbox
    1 year ago
    great job, nicley done
    JimOHoff
    1 year ago
    Nice looking machine, very good work.
    Lorddrake
    1 year ago
    Nicely done.
