DIY Phone Case From Soda Cans
17,129
62
24
About: Hello - I am the scientist formerly known as Naegeli and of course I was inspired by the artist formerly known as Prince. But in contrast to his royal badness I do not want be become the king of pop but the ...
This Instructable shows you an innovative way how to make a DIY phone case from soda cans. The method presented here can be used as a general approach how to make any kind of nice boxes from soda cans (see video: DIY phone case from soda cans).
In a previous Instructable (see Instructable: Flatten Soda Cans) I showed how to flatten soda cans with the use of an electric iron. The same principle of applying heat to soda cans can also be used when first forcing soda cans in a customized shape using spacers and then place it in an oven. After the heat treatment in the oven, the spacers can be removed and the soda can keeps the desired shape permanently.
In addition you can also remove the ink (see Instructable: Ink Removal From Soda Cans) from the soda cans in order to make it look cooler!
The project was done using a Samsung GALAXY A5 whereas the Huawei P-10 or the Samsung GALAXY S9 was working as well. In case you have a different phone you have to play around with different size soda cans and the thickness of the foam rubber.
If you like that project please vote for me in the "Trash to Treasure" contest?
Step 1: Parts List
For that project you need the following items:
Materials:
  • Small soda can (diameter 53 mm): Is used as the bottom part of the phone case
  • Middle size soda can (diameter 58 mm): Is used as the lid for the phone case
  • Large soda can (diameter 66 mm): Is used to make the second type of spacer
  • Foam rubber (2mm thickness): Is used to make the closure in the bottom part and the lid of the phone case. Moreover it is used as the lining material inside the phone case
  • Popsicle sticks (150mm x circa 17-18mm): Around 10 pieces are needed to make the first type of spacer
Tools:
  • Utility Knife
  • Scissors
  • Stapler
  • Wooden block 1 (25mm x 13mm x 64mm)
  • Wooden block 2 (9mm x 13mm x 64mm)
  • Ruler
  • Contact adhesive
  • Oven (200°C/392°F for 30 minutes)
  • Q-tips or cotton swabs
  • Edding marker
  • Double sided adhesive tape
Step 2: Selection and Preparation of Soda Can
The basic part of the phone case is made from two soda cans. One can acts as the bottom part the second one is used as a lid. Therefore the two soda cans should be different in size, so the lid can be placed over the bottom part. However the gap between the two parts should not be too big because otherwise the lid will fall off. Two millimeters foam rubber that will be placed inside the lid will act as a fitting between the parts. So the selection of the correct size soda can plays a crucial role in this project.
In my part of the world three main soda can types are sold with the following diameters:
  • 66 mm
  • 58 mm
  • 53 mm
For this project the two smaller ones (53 & 58mm diameter) are used. The bigger one is saved for a later step. Clean the emptied soda cans by rinsing twice with water and then let it dry.
Before you start to cut the soda cans apart you should consider if you want to remove the ink from the soda can surface. I have already posted an Instructable how to remove the ink from soda cans. You can find it under the following link: How to remove ink from soda cans.
Now we start a procedure to carefully cut off the upper and lower parts of the can. Pay attention to your fingers during this procedure, as aluminum edges can lead to heavy cuts. Use the utility knife to mark a groove around the can. Hold the knife on a piece of wood (wooden block 1) at a level plane and then rotate the can around. It is not necessary to cut through the aluminum. Apply some pressure with your fingernail near the groove to separate the top and the bottom part (see video: DIY phone case from soda cans). Repeat this step for both soda cans.
Step 3: Prepare the Spacers
In order to force the round shaped soda can pipes into the form required for our mobile phone case it is necessary to make some spacers. I found that the round shaped end pieces from wooden popsicle sticks are ideal to make the spacers. Only the length of the sticks has to be shortened with scissors to the desired length. I found that the following dimensions bend the aluminum can just nicely:
  • Lid part of phone case: 8.1 cm length
  • Bottom part of phone case: 7.3 cm length
To prepare the spacer for the lid, cut a popsicle stick after 6 cm from the end. Then combine two 6 cm popsicle sticks to an overall length of 8.1 cm and fix this first type of spacers with the stapler. The reason to take the stapler is that the spacer is exposed to high heat later in the project. Therefore hot glue is not a solution.
To prepare the spacer for the bottom part, cut a popsicle stick after 5 cm from the end. Then combine two 5 cm popsicle sticks to an overall length of 7.3 cm and fix this first type of spacers with the stapler.
If you have chosen to take soda cans with a different diameter than the ones mentioned in the parts list, you have to adjust the length of the spacers accordingly.
Prepare 4 spacers for the lid and 4 for the bottom part.
A second type of spacer is required to separate the spacers made from popsicle sticks in the can from each other. Separate a strip of aluminum (13.5 cm x 2.5 cm) from the third can and make a 1.3 cm slit about 2 cm from each end. Place both slits into each other to form a “fish-like” structure.
Step 4: Bend / Stretch Soda Can in Position Using Spacers
Start by adding wooden block 2 into the upright standing round soda can. Then add the popsicle spacer on top. Press the popsicle spacer against the wooden block 2 with the use of an Edding marker to bend/stretch the soda can in the shape of the phone case. Then add the “fish” type spacer on top. Continue layer by layer until you reach the top.
Step 5: Permanent Fixing of the Soda Can in the Shape of the Mobile Phone Case
Here comes the magic - place both stretched soda can parts in the oven for 30 minutes at 200°C (392°F) to permanently fix the cans in the desired shape.
What’s happening in the oven is the following: In order that the beverage inside the soda can does not come in contact with the aluminum, manufacturers of soda cans add special sealant glue on the inside. Since the soda can is produced in round shapes the later on added sealant glue holds the soda can in the round shape. In the oven you are heating the sealant glue past its glass transition temperature and allowing it to move. So the sealant glue is adapting to the new shape holding it in place. It is unlikely that the crystal structure of the metal is affected since you hardly reach the annealing temperature of aluminum in your oven.
After 30 minutes cool down the two parts under running tap water - remove all the spacers and you will see that the soda cans keep the new shape permanently.
Step 6: Prepare Lid
In order to shorten the lid to the desired length, place the Edding marker on wooden block 1 and mark a line around the soda can. Cut along the line with scissors.
Step 7: Bottom and Lid Closure Preparation
For the lid closure glue three pieces of foam rubber (30 mm x 90 mm x 2mm) over each other using contact adhesive. Place the 8.1 cm wooden spacer on top of the three pieces. Then cut along the wooden spacer with the utility knife so you obtain a closure in the exact same shape like your soda can lid.
Fix the closure into to the lid using adhesive glue.
Repeat this step for bottom par.
Step 8: Add Inner Protection
In order that the phone does not fall of the case and to protect it from scratches add two pieces of foam rubber on each side of the bottom part using double sided adhesive tape.
For the lid, use a single piece of foam rubber covering the entire inner surface of the can. Again fix it with double sided adhesive tape to the soda can inner wall.
On both parts (lid and bottom part) the foam rubber is overlapping the soda can acting as a fitting.
Now place your phone into the bottom part and close the lid. I hope that I have inspired you to repeat this project at home.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Arduino Contest 2019
    24 Discussions
    E3V3A
    4 weeks ago
    This is a great SECURITY project!
    As we all know, our phones cannot be trusted to be completely off. This is especially true for devices where the battery cannot be removed. Security research has shown how past mobile hacking tools have been used to impersonate a phone "off" state, when in fact being on and listening in.
    To complete the Faraday cage, make sure to also seal the ends with aluminum and use conductive copper tape to compete the seal, as aluminum can be hard to solder without melting. Also make sure the cap has a tight fit, as a just 1-2 mm may be enough for radiation to leak. (Some of the latest 5G modems are operating ~50 GHz.)
    PS. Even a completely sealed Faraday cage may not block all EM radiation because of the skin effect that depend on the frequency, material and its thickness. (I.e. If you x-ray'd the box, you'd still see the phone inside.)
    wv99999
    4 weeks ago on Step 5
    With regards to the explanation why "baking" the can in the oven does indeed fix the shape, have a look at http://www.totalmateria.com/Article139.htm, in particular on the section about "Recovery". Once the dislocations defining a particular shape (i.e. a stress pattern) are gone, additional heat treatment does not further soften the metal. The "practical" advice you find on the internet (e.g. https://makeitfrommetal.com/how-to-anneal-aluminum-the-beginners-guide/ or https://process.arts.ac.uk/content/annealing-softening-aluminium-plate/index.html) has at its heart methods not to overheat and melt aluminium, while using a torch to do the heat treatment. Because these methods of temperature control are so poor, their proponents conflate "Recovery", "Annealing" and "Recrystallization" into a single process and then make claims that do not hold up under much better control.
    Thanks for your input to the real subject - so far I just had no time to carefully check your links.... but I will go through them... maybe I have to adapt my world (smile)
    JustineM32
    4 weeks ago
    Very cool! My dad would love this!
    carolcox54
    4 weeks ago
    i am looking forward to making this with my teenaged grandson... as we live in Venezuela, and phone reception is intermittent at best, the lack of signal doesn't bother us. we keep our phones on airplane mode until we get to a secure location with a strong wifi signal...thus the case is for protection. very clever use of tin cans!
    RumpelS
    4 weeks ago
    As already written here it is a bad idea to put a phone into a metal box. The metal is a shield for the RF signal. As your phone permanently communicates with the base station it will consume more energy and your battery will become empty faster.
    ak08820
    Question 5 weeks ago on Introduction
    Will the metal surrounding the phone shield it from receiveing a phone call and ring?
    No the aluminum is not blocking the phone. I use the case myself.
    You can easily made the test yourself. Put the phone in the bottom part and then close it with the lid. Take another phone and call the phone in the case. You will hear it ring immediately..... don't forget that the closure on both sides is made from foam rubber so there is no closed shield around the phone. Hope this helps!
    Well .. i think, there might surely be enough leakage on the ends to be able to still get calls trough.. But it imposes another problem.
    Cell phones regularly communicate with the base stations in their surroundings. Just for telling them that it is still alive and still in their coverage area (or if they're not because you're moving, they arrange handover and stuff). That's necessary for a lot of reasons like you being still able to receive calls or transfer data for push notifications and such....
    The problem is; Your phone need to send stronger signals (more watt on the rf transmitter) because of the shielding the soda can still is... This _could very unlikely_ damage the RF circuits because of reflections and feedback within your soda can case.
    But! Even if not damaging, it drains your battery way faster than it would do without the aluminium around it.
    Overall .. a nice idea and a nice instructable ... but the usability is very limited if there is any at all... ;)
    just IMHO, some 2 cents from some netizen;
    hacky
    webcamsuak08820
    Answer 5 weeks ago
    The antennas at the smartphone are on the ends, if the ends of the case is dielectric then the signal will pass.
    shooshx
    4 weeks ago
    This is the best idea possible to kill your phone reception. Excellent for people who don't want any communication done through their phone. Seconds only the Apple iBrick.
    AntonZ5
    4 weeks ago
    Looks pretty cool, but I afraid the RF signal will be degraded because of metal shield. However, I will use this idea for other storage. For example to store plastic and credit cards with NFC chip. or to store hdd drive. Really liked the tip to bake it in the oven!
    Anyway nice enclosure!
    Netaawy
    5 weeks ago
    Great! it won't block phone signals as cans made of aluminum. Nice tuation.
    DinoDenNetaawy
    Reply 5 weeks ago
    Aluminum blocks electromagnetic waves. The bottom of the case is foam rubber. That's the entrance point.
    oliveira.igorm
    5 weeks ago
    Remember that it should work as a faraday cage, so you can use it to block the connectivity of your phone. If you want to receive messages and calls you should leave it open
