DIY Portable Counterfeit Money Detector and Torch
15,950
134
10
About: Born as a farmer, studied electronics ,working as a Consultant and a 3D printing enthusiast by night..
Instead of buying one of those expensive Counterfeit Money detectors ,make your own using a couple of Ultraviolet LED’s a coin cell battery and 3D print the parts attached in Step 2, which fits nice and snug in your Wallet/Purse.
The two 3D printed the parts are about 4 credit cards thick and double up as a torch which you can use to protect yourself tripping over things in the dark.
Watch the short video above for the direction on how to use the Portable Counterfeit Money detectors and torch.Basically the 3D printed base has 3 slots
  • one to store the coin cell battery when it is not being used
  • second slot on the left has 2 UV LEDs where you will have to insert the coin cell battery
  • third slot on the right which has a bright white LED which lights up when the battery is inserted and acts as a torch
Warning : Do not point the UV LEDs in the direction of your eyes for too long as this could be harmful for your eyes.
Step 1: Things You’ll Need
Here are electronic components that you will require in addition to the 3D printed parts
Two Ultraviolet LED’s
White LED (5mm LED)
Coin cell battery - CR2302
Super Glue
Step 2: 3D Printing Credit Card Size Holder
Download the 3D printing software that you printer supports, in my case i am using the Printrbot Simple Metal which use Repetier-Host as a software to
  • Slice the STL files attached, which basically means cutting the part into various layers
  • And send commands to the 3D printer while printing
Download the STL file attached and load it in your printer software and slice the file,and hit run to print both the STL files attached.
Based on your printer setting the Base should take about 35-40 mins to print and the Lid take about 15-20 mins to print.
Step 3: Adding LED's to the 3D Printed Base
Add the two UV LEDs to the base 3D printed part and then add then add the white LED.
Use super glue to secure the LED's to the base, but just before you super glue the LEDs to the base test the LEDs as shown in the pictures above.
Step 4: Attaching the Lid
Using super glue on the button extrusions of the lid 3D printed part snap it into the base as shown in the picture .
Congratulation your build is complete ! and you are now ready to use your DIY "Portable Counterfeit Money detector and torch" to protect yourself against Counterfeit notes, and use it in the dark to prevent yourself from tripping over and injuring your self..
    • Woodworking Contest
      Woodworking Contest
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    10 Discussions
    This is really a nice product.I am planning to make one now after seeing this.
    mcfunworld
    4 years ago
    this is cool I wish I had a 3d printer :( I don't wana get scamed with fake money
    CJA3Dmcfunworld
    Reply 4 years ago on Introduction
    Thanks for the comment, here is a suggestion, you can download the STL files and take it to your local maker space to get it printed or printing service 3dhubs or shapeways..
    tjdux
    4 years ago
    this could be made out of thin acrylic or possibly wood sheets and carved with a dremmel tool. It may be a little thicker but easy enough to keep in a pocket or purse.
    I could see this being useful for street vendors or flea market or craft fair booths.
    There are also inexpensive currency test pens but they do not double as a handy flash light. Neat Instructable.
    profort
    4 years ago
    ELEGANT
    vashishta
    4 years ago
    Super cool stuff... very much needed these days
    sangh
    4 years ago
    Thank you for giving me more information on this. I think I might make one myself.
    RBEWorldBuilder
    4 years ago
    I got news for you, the money you think is real, is nothing but monopoly game money. I call them Federal Reserve Accounting Unit Devices F.R.A.U.D.s just something to consider.
    CJA3Dsangh
    No,this is something the bank tellers have to check the validity of a note, and in addition you can buy something similar from Amazon for personal use ..but the one above is portable and something that you can carry in your wallet/purse.
