DIY Recycled 12V 5A Battery Charger From SMPS
3,774
32
6
About: HelIo, I am Prasham a 15 year old diy hobbyist and a recyclist. Currently I am in the high school. I hope you would like the instructables made by me.
Electric Vehicles have come into the trend.Many People have different types of EVs such as Ebikes, Ecars, Escoots, etc. Battery Chargers are much expensive then the total cost of this project with fast charging.Today We are going to make a 12V 5A charger that can be used in Charging EV Batteries quickly.
PLEASE NOTE : ALL THE PROJECTS MADE SHOULD NOT BE CONNECTED TO POWER UNTIL COMPLETELY MADE.
So Lets Start:)
Step 1: PURPOSE
The electronic waste generated is rising day by day. Inorder to make some difference we will use recycled objects and a very few new objects.
Step 2: ALL WE NEED:-
SMPS(Power Supply): This can be old or new but should be working.I have extracted from my Old PC.You can chose one from a nearby junkyard.
Adapter For SMPS
TOOLS: Screw Driver
Wire Stripper
Electrical tape
Step 3: LETS START
Open the body and clean the inner portion if necessary.
See to it that there are all wires uncut
Step 4: CUTTING THE WIRES
Cut all the wires going out except green, black and yellow.
NOTE :THERE WILL BE MULTIPLE YELLOW AND BLACK WIRES AND WE NEED ALL UNCUT.
Step 5: JOINING
Make a group of yellow and another group of black and green.
Strip the wires an inch long and connect them top their groups.
Yellow pole forms positive pole while the black and green together forms negative pole.
Step 6: AND DONE
Check the voltage of the Powersupply.
It must be between 11V-13V.
Step 7: Thanks for Viewing
Thanks For Choosing this.
Anyone who has doubts can ask below.
Vote , like and share.
It means a lot to me.
I have entered the Power Supply Contest you can vote me here
https://www.instructables.com/contest/powersupply/
See you soon with a New And Interesting Instructable :)
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    6 Discussions
    NoskillsrequiredN
    1 year ago
    If you connected all the negative and positive terminals it means that are all separate outputs, and maybe we can have 12v at 0.5A per pair of cables or similar?
    raimundolemos
    1 year ago
    you can't full charge a lead battery with 12,8 volts, you need 14 volts
    but you can modify the ATX circuit :
    https://youtu.be/Z6WwlQXbscs
    raimundolemosPrashamS1
    Reply 1 year ago
    The ampere, SI unit symbol: A, dimension symbol: I, often shortened to "amp", is a unit of electric current.
    Electric current measures in Amperes
    The volt (symbol: V) is the derived unit for electric potential, electric potential difference (voltage), and electromotive force.
    Electric tension is measured in Volts
    One volt is defined as the difference in electric potential between two points of a conducting wire when an electric current of one ampere dissipates one watt of power between those points
    During charging of a lead battery, the voltage goes up and the current goes down
    PrashamS1
    1 year ago
    Sir but the current varies from 12V to 14.5V
    gm280
    1 year ago
    This is all good, except to be able to charger a 12 volt battery like a lawn mower or even a car battery, you will need more then 12.8 volts. If you can't boost this up to at least 13 or even 14 volts would be a lot better, it will not charge the battery full charge.
