DIY Rubber Stamps
68,470
519
17
About: I am most well known for my various Video Game themed baby nurseries, most recently, Mario Kart 8. I enjoy the challenge of making things using materials and processes that are new to me. The sense of explor...
In this Instructable, I am going to show you how to make a high quality stamp out of your favorite logo or symbol.
You will need the following materials (Amazon Affiliate Links):
Check out the video here: or above for examples of logos and carving technique. With a little bit of practice you will be putting stamps on everything!
Step 1: Select a Favorite Symbol or Logo to Use As a Stamp
Start by selecting a few black and white logos, symbols or other emblems that you would be interested in having a stamp of. It could even be some text.
Just try to avoid an image with very thin lines as these can be difficult to carve, and can bend/collapse under the pressure of stamping down.
Using an image editing program or even MS Word, create a black background and arrange them to appear side by side. Having the black background helps a lot when transferring images to rubber sheet.
*Note* There is no need to mirror/reverse anything as they will stamp exactly as you lay them out here.
Step 2: Printout Black and White Image on a Laser Printer
Once you image is complete, print them out on a laserjet printer. If you do not own one, you can also just get a photocopy made of your final image. Using a laser printer here is critical for the image transfer on the next step to work.
Step 3: Apply Steady Heat to the Back From an Iron, and Gradually Peel Away Paper
Using an iron on a medium temperature setting, place the picture ink/toner side down and start ironing.
The heat will transfer the image to the rubber surface. Take care as to not remain in one spot for very long as the rubber can deform.
Gently pull up one side and you can get an idea if it worked. If needed, you can lay the image back down and iron some more to get a darker transfer. Take care during this stept o not stay in one spot for too long as it will warp/burn/melt the rubber sheet.
Step 4: Using a Straight Blade, Trace the Image Out.
Now just begin lightly tracing your image with a exacto blade or the supplied straight cut blade in the Speedball Linoleum Cutter Assortment kit found in the material listing. Take care to not cut all the way through, 1/8" is plenty far enough.
Step 5: Cut a Chunk of Scrap Wood That Fits the Stamp Dimensions
Find a piece of scrap wood to use as a handle for the stamp that matches your rough stamp dimensions. A 1.5"x1.5" piece was perfect for me.
Using files and/or sandpaper makes the handle more comfortable to hold.
Step 6: Use Various Sized Gouges to Remove the Majority of Material
Using the other carving/gouging blades, hog out the remaining sections. Be careful as to not be too aggressive here, it is easy to make a mistake if you get carried away.
Step 7: Stamp the Top of Handle to Make It Easy to Identify
Stamp the top of the handle with your favorite color of ink. This makes identifying the stamp easier when you are making multiples.
Coat the surface of the handle with some Polyurethane spray to prevent the ink on the handle from getting on your hands during use.
Step 8: Use Two Part Epoxy to Attach Handle to Rubber Stamp
Use some 5 min two part epoxy to adhere handle to the rubber stamp. All adequate time to cure according to epoxy instructions.
Step 9: Enjoy Stamping!
Find your favorite color ink pad and stamp away! :)
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
  • Jewelry Challenge
    Jewelry Challenge
17 Discussions
Velvetkey
3 years ago
Good basic tutorial; I loved your images!
You might also add (for the extreme newbie that's never handled the pink stuff before) that they can use pencil tracing/rubbing to do their first few image transfers. (Pink stuff is too expensive to risk melting!)
I just carved Dean Winchester and Sam Winchester stamps for a letterboxing event this weekend with that method, so it's not too bad.
Thanks for sharing!
geeksmithingVelvetkey
Reply 3 years ago
Thanks! It really doesn't take a whole lot of heat to transfer the image and I have yet to come close to melting it. :)
Jedi_zombie85
3 years ago
simple and effective love it
Treasure Tabby
3 years ago
Oo I remember making these in high school. I may have mine lying around someplace. Of course it wasn't really used for just stamping but more like a print.
Thanks for sharing. :)
geeksmithingDzefri
Reply 3 years ago
Thanks! Exactly! There isnt a letter than goes out now that I dont throw a stamp on :D
geeksmithinggravityisweak
Reply 3 years ago
Speedball 6-Inch by 12-Inch Speedy-Carve Block both Amazon and even Michaels craft stores carry them.
Xenia123
3 years ago
thank you - I really feel stupid now as I can't find the text link as well...
geeksmithingXenia123
Reply 3 years ago
No worries!
https://www.youtube.com/watch?v=22XBhe5Nups
Xenia123
3 years ago
Like this. but could you put the video in it?
Reply 3 years ago
I updated the description to include a text link to the video if the embedded doesnt show up for whatever reason.
Lost Moai
3 years ago
Very nice. I've made letterboxing stamps galore. I prefer the "white stuff" and an exacto knife, but the linoleum cutter is great for taking out big pieces of material. I've been meaning to do my own stamp carving instructable, but you beat me to it.
I've never used an iron for transfers. Acetone has always worked well for me. Smelly, but it works.
That's not the Gummy Bear Medallion, is it?
geeksmithingLost Moai
Reply 3 years ago
Acetone definitely could also work! And yes, good eye, it is a Gummi Bear medallion! ;)
timsway
3 years ago
well presented and easy to understand. thank you sir!
