DIY Star Wars TIE Fighter Bookshelf
5,607
176
14
About: Hi, I am Ashley. I am a geek and woodworker. I am author of the DIY and woodworking blog, Handmade with Ashley. I also have a YouTube channel where I share video tutorials. I have always been into crafts. M...
Hi, I'm Ashley. I'm a long time lurker and this is my very first Instructable!
Since the release of The Force Awakens, whenever I brainstorm new project ideas a Star Wars related idea always comes up! Today’s project just so happens to be another Star Wars themed project; it’s a TIE fighter bookshelf! I was able to make use of some scrap lumber I already owned. Paint was the only item I purchased for the project. Everything else I had on hand. Follow along and build one for yourself or the Star Wars fan in your life.
WHAT YOU WILL NEED:
  • Circular saw
  • Jigsaw
  • Kreg Jig
  • Ruler / straight edge
  • clamps
  • Orbital sander
  • Lumber
    • 3/4" thick plywood - 13" x 26"
    • 1x8 board - 48"
  • Gray paint
  • Black paint
  • 1" thick painter's tape
  • 1/2" thick washi tape (I used this as painter's tape)
  • Wood glue
  • Wood filler
  • Screws
I originally shared this project on my DIY blog, Handmade with Ashley.
If you enjoyed this Instructable, please vote for it in the Woodworking Contest! :)
Supplies:
Step 1: Cut the Wood to the Appropriate Sizes
Cut the sheet of plywood down into two 13" squares.
Cut the 1x8 board into two pieces 24" long.
Step 2: Cut Out the TIE Fighter Wing Shape
The TIE figher wings are shaped sorta like a hexagon. Use a jigsaw to cut out the shape.
  1. Draw a line from the midpoint of each side
  2. Mearsure 2" from the corner and create a line from that point to the midpoint.
  3. Cut along the diagonal lines
Step 3: Drill Pocket Holes
Create pocket hole joints to join the boards.
  1. Create 3 pocket holes on the long side of one of the 1x8 boards
  2. Create 2 pocket holes on the each short side of the 1x8 boards
Step 4: Paint the Bookshelf
Prep the surface of the lumber for painting. (You can assemble the shelf before painting. I painted half, then assembled the shelf and then painted the remaining half.)
First coat the shelf with a base of gray paint.
Once the base coat is dried, paint the TIE figher wings:
  1. Tape of border of the wing with 1" painter's tape
  2. Use tape to connect the opposing corners
  3. Use tape to create a small hexagon shape at the intersection of all the tape lines
  4. Paint the exposed area with black paint
While the wings are drying, paint the TIE fighter cockpit:
  1. Draw the shape of a semi-circle in the center of the 1x8 boards (If you are painting the shelf before assembling be sure to take that into account when you draw the semi-circles)
  2. Draw the shape of an octagon in the center of the joined semi-circles
  3. With 1/2" painter's tape (I used washi tape because I could not find painter's tape that thin), mask off from each point on the octagon to the outer circle (see picture).
Step 5: Assemble the Bookshelf
Join the 1x8 boards at 90 degrees. Attach the shelf to each wing.
Step 6: Seal the Project and Enjoy
Finally coat the shelf with your favorite sealer and start filling it up with books!
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Classroom Science Contest
    14 Discussions
    AnılY17
    2 years ago
    ıts very creative thans for sharing
    http://ecemiselbiseleri.com/
    Riffifi
    2 years ago
    on a slightly bigger scale, it becomes a bench :D
    Natalina
    2 years ago
    Great idea! The fighter works so well in this form. And doubles as a toddler bench :)
    BKLaRue
    2 years ago
    Totally awesome!!! Great work! Voted...
    Hiroak
    2 years ago
    Great job I'm going to make one like this as a bench. I also went to your website, you do fine work indeed, keep it up.
    handmadewithashleyHiroak
    Reply 2 years ago
    thank you! :) Share a picture when you finish it. I'd love to see how it turns it out. :)
    MissionSRX
    2 years ago
    Nicely done! A strong start and welcome to the party! (we'll be watching your career with great interest)
