DIY Super Electromagnet
38,493
126
11
How to Make a BIG and Powerful Electromagnet with the Primary of the transformer of a microwave oven. Remove the Secondary. With Iron or Steel (ferromagnetic materials) it attracts with a really great strength. With non ferrous metals like aluminum and copper it repels them due to Eddy currents.
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
11 Discussions
PeterK2
2 years ago
Quick question, could you cut off the excess ends of the "E" to lighten it?
bubalPeterK2
Reply 2 years ago
It is possible, but I don't know how much, because the E does an important function. Increases the magnetic permeability so the magnetic field is channeled better in one direction.
How hot does it get, and could I cut the excess ferrite off the transformer to make it lighter?
eyejuice
3 years ago on Introduction
How long can you keep the magnet on without tripping a breaker? Have mine hooked up to a power strip which trips after a few seconds. Tempted to plug directly into a wall outlet but i dont want to risk overheating the coils.
dmalamas
4 years ago on Introduction
Hi, could you tell me what is your input source (voltage value) and if this electromagnet works with AC (50 - 100 Hz) input?
Thank you
bubaldmalamas
Reply 4 years ago on Introduction
230 volt 50 Hz. But if you live in a 120 volt 60 Hz country you will find microwave oven transformers that work with that values so it is more or less the same.
artist10
Hi,
What did you connect the wires from the primary core to?
cpallette
4 years ago
How strong is it?
