Deadpool Knife Block
328,997
774
114
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
In this Instructable I am going to show you how I built my Deadpool Knife "Block".
Usually in my Instructables, I just walk you through the process to repeat what I have made. This Instructable is a bit different. I figured that by not just only sharing the final stl file, but also the process I used to design it and what I learned, this Instructable could benefit others (and to be honest myself by getting feedback on how to improve).
I recently cleaned out my kitchen drawer and realized that I have some really nice knives that deserve to be placed in a knife block.
So while I was searching for one I liked I read an Asterix comic and the idea for a "Ceasar Knife Block" was born. The Adventures of Asterix is a French comic series which you should definitely check out, should you not know it. So I googled to see whether I could buy one anywhere and found this picture. Sadly it was obvious that it was just a photoshopped image, so I decided to build one myself. The only problem was that I have absolutely no modelling skills.
Once I was nearly done designing the knife block I watched the Deadpool movie and decided to rather go with a Deadpool one instead.
All the programs I used are freeware so anybody should be able to replicate what I have done.
Step 1: Trying Out Autodesk Recap 360
I had an around 14 cm high figure of Caesar, which I wanted digitise. So I decided to try out Autodesk Recap 360.
It's a free online software and to be quite honest due to the small size of the figure I wasn't expecting too much. Though since I have seen really some nice results with bigger objects I decided to give it a shot.
You can see my first and second attempt in the pictures. I set my camera up on a tripod and placed the figure on a turn table. For the first attempt I used a white backdrop (just a white blanket) and took 50 pictures (the maximum you are allowed to use in the free version). As you can see, while I was already getting quite a nice model, the program had a few problems to distinguish between the background and the figure.
So for my second attempt I decided to use a black backdrop (just a black blanket). I took 36 pictures. Since I was only interested in the head and not the body I focused on that area. I uploaded the pictures once again and was really surprised how good the result was.
As you can see in the third picture, the head still needed some improvements. I used Sculptris to do so and found it really easy to use, even though I had no experience.
Simply import the *.obj mesh that you got from Autodesk Recap 360 and start playing around with it. If it is asking you whether you would like to "go to paint", simply state "No"
Here is a good video to get you started.
I used Autodesk Meshmixer to cut the head off the body. You can also use it to improve the head, but I found Sculptris easier to use.
Step 2: "Designing" the Body
While I was trying to figure out how to design the body of the bust I stumbled over an awesome project: Scan The World
Here is what they say about themselves:
Scan The World is an initiative that is creating a digital archive of
sculptures, landmarks and monuments from around the world using 3D Scanning and Printing technology. We are calling on the public to scan sculptures near them and submit them to us, read more about the project on the Scan The World page!
You should definitely check them out, the quality of the scans is amazing.
So I looked for a roman bust I could use and found this one of Marcus Aurelius at The Metropolitan Museum of Art, New York.
Once again I used Autodesk Meshmixer to cut the head off.
Next we will have to add the head to the body. I originally wanted to use thinkercad to do so, but sadly there is a limit of 25 MB for importing files. So I tried to use MeshLab. I managed to connect the meshes after using multiple filters, but when I wanted to reproduce what I had done for this Instructable, I couldn't (pathetic I know, but a month had past and I just couldn't remember what I had done, there are internal faces I just couldn't remove properly the second time around). Then I tried to use FreeCAD, but even though it is quite interesting and has a lot of features, I could not manage to connect the meshes. Next I tried to use netfabb basic, but uniting meshes is sadly a "pro feature" you will have to pay for (also there is only a 32 bit version for windows). At this point as you may imagine I was really frustrated.
So I decided to use a program I had all along: Meshmixer
And I was surprised how easy it was to unite the two meshes. Simply import them, scale them (here is a good instructable on how to do so) and move them around so that they fit.
Then select both meshes by holding the ctrl key, click on "Edit" and "Boolean Union" and you are done.
After uniting the two meshes I went back to Sculptris to smooth the transition.
I've uploaded the design to this step, should you want to use it.
Step 3: Going With Deadpool Instead
As you can see in step 3 I was nearly done with designing the Caesar bust, when I decided that I would rather like to go with Deadpool.
Deadpool is famous for shooting himself in the head to save himself from boredom, so I figured that he would be perfect for the knife block.
So I started over from scratch. Before once again using a figure, I decided to search the web for a 3D design I liked.
Here are a few I found:
I decided to go with the last one, but pick which ever one you like.
Step 4: Preparing the Head (wow That Sounds Weird)
First I removed the belts. I found that the best way to do so is in MeshLab. Click on "Select Connected Components in a region", select the belts and hit "delete".
As you can see in the first picture, the original mesh is quite rough. This can easily be corrected in Sculptris. Simply open the mesh and click "SUBDIVIDE ALL".
I did all the other editing (like closing the eyes, removing the weird bump from the nose and some more smoothing) in Meshmixer. Here are some great tutorials to get you started.
I've uploaded my final version, should you want to use it.
Step 5: Choosing the Knives
These are the knives I used:
Use any 3D modeling tool you like to design the knife blades (e.g. tinkercad). Make them slightly wider and longer, in order for the knife to fit later on. As you can see in the next step, I used a fairly simplified version of the blades. In most cases a rectangular box should be enough.
You can also use Meshmixer to design a rectangular box, simply click on "Meshmix", make sure "Primitives" is selected, click on the cube and pull it into the designing window, as shown in the second picture. Deselect "Uniform Scaling" and simply put the measurements under "Size X", "Size Y" and "Size Z".
Step 6: Removing the Knives
Meshmixer is great tool to move the knives to the correct position and to cut the mesh. Use "Edit" and "Transform" to place the knives. You can hide the head by clicking on the small eye in the Object Browser. Make sure that the knives don't overlap.
Sadly you can't remove the knives all at once in Meshmixer. Select the head and a knife (by holding the shift key) and select "Boolean Difference". Deselect "Preserve Group Borders" and "Auto-Reduce Result" and click accept.
Repeat the process with all the knives.
Step 7: Making It Fit the Print Bed
My 3D printer, a Replicator 2 (thanks a lot to instructables!), is not big enough to print the whole head in one go. So I had to slice it into multiple parts. Here is a very nice and detailed explanation on how to do this.
You will have to click on "Edit", "Plane Cut" and select "Slice keep both". Once you hit accept you won't see a difference. Click on "Separate Shells" to see both parts in the object browser.
I decided to hollow the face out (underneath the first cut in order to need less support structures), to make cleaning easier and to cut down print time. In order to do so I constructed a cylinder in Meshmixer, scaled and positioned it and cut it from the figure the same way I did with the knives.
Step 8: Time to Print and Paint
I tried printing the first part, but couldn't get it to work right. Either the piece was impossible to remove from the raft or (when I printed without a raft) it started to warp. So I decided to invest into a hot plate and while I was at it, I also got a new full metal z-axis (I got them here and here).
I made videos on how I installed the hot plate and the new axis, should you be interested.
Thanks to the upgrade I was able to print the pieces without any problems.I suggest to print the middle part upside down. This way you won't need any support structures.
The settings I used were (I've uploaded the profile to this step):
Printer Brand: MakerBot
Printer: MakerBot Replicator 2
Rafts: No
Supports: No
Infill: 10%
Layer Height: 0.25
The print took about 40 hours.
Afterwards I glued the pieces together. I noticed, that using acetone and rubbing the head down with a towel saved me quite a lot of sanding later on. I highly suggest to spend some time on sanding and priming (use a "Filler Primer"), since it will improve the smoothness of your final product quite a lot.
Now all that is left to do is to paint the head. Congratulations, you are done.
Step 9: UPDATE
UPDATE:
After about a two weeks I realized that some imperfection were starting to show up. I didn’t pay much attention to them until after a month cracks started to form where I had glued the parts together. After spending hours priming and sanding I couldn’t believe my eyes.
I used "Universal Primer Filler" from Spraila which seems to have different material properties than the PLA and so due to the temperature changes in my kitchen it started to shrink.
Since I had recently bought XTC-3D I decided to give it a try. It’s a resin specially developed for coating 3D prints. I used a thin layer, which didn’t cover the cracks, so I decided to use a thicker layer. This was a very stupid decision, due to the low viscosity drips started to form and I had to spend a very long time sanding the head to get rid of them. As you can see in the second picture I accidentally sanded through the XTC-3D in some places. So I filled the cracks with Autobody filler, used a thin layer of red primer (Dragon Red by Army painter) and went with two thin layers of XTC-3D. After carefully sanding the head I primed it again and painted it.
So far it still looks perfect, I will keep you posted.
Check out this link should you want to see a video of it in action.
3D Printing Contest 2016
Third Prize in the
2 People Made This Project!
  • Party Challenge
    Party Challenge
  • Classroom Science Contest
114 Discussions
AndreaB315
Question 5 months ago on Introduction
Hello, i habe no 3D printer, maybe you sell one when i give you the knife size?
TadasJ5MarkR439
Reply 5 months ago
i ordered one, but i guess they are scam, way to cheap and no communication at all.
MarkR439TadasJ5
Reply 5 months ago
I was posting it as a warning that someone stole the design and was trying to sell it. (apparently also a scam)
AG3DP
7 months ago
Printed in one piece, scaled to fit on the Prusa i3 MK2 fully. 3D printed in black PLA, Spray painted red, and then acrylic for the mask details. I changed the nozzle to 0.60mm and the layer height to 300 microns. 10% Honeycomb infill. Cut time down to just under 20 hours for printing.
I made this for my brother for his new kitchen and he LOVES IT! This instructable was very helpful - great job! I made a timelapse of making it, you can find it here if you're interested:
Screen Shot 2018-10-08 at 9.33.04 PM.pngScreen Shot 2018-10-08 at 9.32.35 PM.pngScreen Shot 2018-10-08 at 9.32.16 PM.png
MarkR439
11 months ago
Printed this using the individual parts instead of doing it all at the same time, and ran into a pretty serious issue. The solid top section + the two hollow lower sections cause it to be very top heavy. So, I made a base for it after all was said and done. Great instructable and an awesome idea in general.
Raymond Potter assembled the body and was the painter on this model.
https://www.facebook.com/raymond.g.potter
BrittLivMarkR439
Reply 11 months ago
Great job, thanks for posting a picture. The base looks great, really smart problem solving
Brokk Hrafnsson
12 months ago
Hehe. The irony.
But sheesh, that there paint job came out marvelous! I can never get paint to work out. Congratulations on a glorious head you can stab whenever you're cooking.
Gandolf the green
12 months ago
https://www.shapeways.com/
Brittliv, you should register your design, and print it through the above website. They are super good, helpful and sell quality products. You can upload a generic version (not custom for your knives) and they will print and sell them for you. You get a commision for owning the design, but you dont have to make them. In addition their printers are large enough that they can print it all in one piece.
Quiero
2 years ago
I want this so bad but could never make it myself. Can I pay someone to do it for me please?? :)
Dr. dB
1 year ago
Oh, now you just HAVE to make an assortment of tiny, little, rechargeable, WiFi, cartoon unicorns and such, to dance on the kitchen counter in front of him, whenever a knife triggers the sensor at the bottom of its slot!
Different character for each slot, of course... .
NicolaM45
1 year ago
I spent an hour looking on google and websites to actually buy this. Kudos on making such a professional kitchen item.
BrittLivNicolaM45
Reply 1 year ago
Thanks a lot for the compliment. I am sorry that it can't be bought.
danea9
1 year ago
omg epic
ShannaW73
2 years ago
If this is ever designed and sold for mass production, as Fry would say " shut up and take my money!" This is awesome! I think eve Francis would want one!
LeslieGeee
2 years ago
Britliv, EXCELLENT!!! I love Deadpool. I hope you can register your design and possibly have it made for sale. You did a wonderful job on it. There is nothing out there like this. I would get in touch with a lawyer who deals in licensing brands.
" I wanna shoop baby shoop"
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 12.0px Helvetica}
rnorton2
2 years ago
I love the Idea, I think its spot on since deadpool go stabbed in the head in the movie. I read all the rabble about dead pool. sorry about that some people seam to get off track of the Ible and hung up on the superficial. I don't own a printer so i cant make this but it would definitely sit on my counter.
YvoW
3 years ago
Nice tutorial! Cool idea!
But Deadpool..? :)
I have problems to accept the outlandish popularity of Deadpool.
I am comicfan aswell as comic artist myself for more than 30 years.
I never stumbled over/ heard/ read of Deadpool before 2016 when the movies advertisement started...
So i deem its popularity a made-up one by hollywood.
And i like to add, we should have a caesar bust for storing Knives too...
Because the real Julius Caesar, was killed by real knives.
coconuthead13YvoW
Reply 2 years ago
YvoW. Nice comment. Dead pool wasn't a main character. he became one because of the video games and then movie. I'm a big Marvel fan (having worked there), but I refuse to go see this movie. Deadpool is just too annoying and his kids are at a kindergarten level
