Desk Lamp, With Articulated Arm
3,821
96
8
About: It all began with legos... And now, I'm a woodworking lover, and DIY passionate! -- Mackero por conviccion, Windowsero por obligacion, admirador de Unix, y amante de CMD
Hi everyone. This is my 1st instructable, even when is not my 1st diy project.
Please excuse my grammar, this is not my default language, but I hope the instructions and the photos being enough for understanding.
I hope to upload more projects, anytime soon!
Thanks for your visit!
Supplies:
Step 1: Materials - Materiales
First of all, we need to get the materials and tools for this project.
Most of it, I get it on a hardware store, and a few items, get them from and old, broken lamp (The Cone, the clamp and the piece of threaded pipe)
2 Inches width, PVC Pipe, as much as many arms you want, I use 25 cm for each arm
A Lamp Cone, or you can use a PVC Fitting adapter.
A Plastic Clamp, to hold your lamp on the edge of a table
2 PVC Caps, one for the clamp, and one for the cone, if you gonna use a fitting adapter, you can replace it with a 90° degress piece
Obviusly, a light bulb socket.
A light bulb maybe?
A piece of threaded pipe, wich goes on the socket, and trough the cone, and another one, wich goes between the PVC cap and the plastic clamp.
4 Locknuts to the threaded pipe, 2 for each piece
Screws, locknuts and washers. I use 2 washers for each Screw, you'll see the picture later
Step 2: The Light
Insert the threaded pipe inside the socket, then trough the cone and pute a locknot.
It should look like the last photo.
Step 3: Cutting the PVC Pipe for the Arms
First, draw a mark every 25 cm / 10 inches, on the PVC Pipe.
Use the HandSaw, to cut the pieces.
After that, use some sand paper to get a smooth finish.
Step 4: Making the Flat Shape for the Arms
This step, will be much easier with a soldering torch, but I don't have one, so I use my stove instead.
Keep the PVC spinning to avoid overmealted parts or black bubbles.
With a low flame, I keep it around 20 seconds spinning and then, using the edge of the counter and a hard drive, I press the PVC to close the gap, and get a straight edge.
Wait a few second to cold down, and put a washer over the flat PVC, to mark the hole in the center and the use the outside to make the edge curve.
Use a drill to the center hole, and the HandSaw to cut the edge arround your marks.
Make sure you left 2 PVC parts, with one end rounded, where goes the PVC caps.
Step 5: Building the Articulation
Split the flat side of one PVC piece, and insert in between, the flat side of another one
Put a washer on one side of the screw, the screw inside the center hole, another washer on the other side, and close it with a locknut.
Step 6: The PVC Caps
Lets start with the clamp side.
The clamp I had, already have a hole for the original lamp.
So, you just need to drill a hole on one of the sides, and then, put a piece of threaded pipe inside the hole and the PVC cap.
Put a washer on each side of the pipe, and close it with a locknut on heach side.
In the cone side, put the threaded pipe inside the cap, and the cone to get a 90° degress shape, and secure it with washers and lock nuts on each side.
Step 7: The Electronics
Now is time to make the electrical part.
This is a very simple circuit, just the light bulb, a switch to on/off the light, and the electrical plug, all in series.
Make sure you left anough cable to connect your lamp anywhere.
Step 8: Finished!
And thats all folks!
Just plug the lamp, turn it on, and enjoy!
I make all this instructable, with hand tools, that everyone could just have around, and the cheapest way possible.
Either way, any comment or recomendation, will be appreciated.
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    8 Discussions
    rachesv99
    2 years ago
    Alhaxxor, glad you like it.
    I think, considering the weight, you should add a couple of strings to reinforce the strength of the articulations
    alhaxxor
    2 years ago
    I've been looking for a good cheap articulating arm to mount a computer monitor. I'll give this a try. thanks for the 'ible!
    waddoyouwant
    2 years ago
    Very cool! It looks a little like the arm on the space shuttle... if you squint.
    rachesv99waddoyouwant
    Reply 2 years ago
    I use to think of it, like the homless brother of luxo Jr
