Desk Lamp
63,003
689
39
If you spend a lot of hours behind your desk in the evenings, than good lighting is crucial. Make yourself this ecological and economical efficient desk lamp.
The total cost of the 10w led lamp plus dimmer plus power supply =  26 dollar. All the other parts were laying around in my garage.
Supplies:
Step 1: Materials and Tools
Materials:
  • Four bolts M3
  • Four bolts M6
  • Four screws
  • Wooden board approximately 9 cm x 324 cm
  • Four dowels
  • Heat sink
  • Aluminum disk 20 mm
  • Led dimmer (Velleman MK 187)
  • 10w high power led
  • 12v, 1 amp power supply
  • Thermal paste
  • Electric wires
Tools:
  • Wood glue
  • Wood wax
  • Jig saw
  • Screw driver
  • Sand paper
  • Wood clamps
  • Drill
  • Drill bit  2,5 mm, 5 mm, 6 mm,  10 mm, 32 mm
  • Router
  • Router bit 12 mm
  • Solder
  • Solder iron
Step 2: Sawing and Gluing
I got my scrap wood from the dumpster of a parquet company. No worries, I asked permission to do so, most people come here to collect the wood for their wood stove.
All the wood pieces have different sizes. For this project the wooden pieces have to be 9 cm wide.
I don't have a table saw, so I used my jig saw to saw the excess wood off.
Glue the wooden pieces together 2 layers thick until you have a length of 108 cm.
Glue one layer of wooden pieces together until you have a length of 108 cm.
Saw these long pieces in to three lengths: 65 cm, 23 cm and  20 cm.
Step 3: Routing, Gluing and Drilling
Route a slot in every double layered piece.
On the double layered 23 cm piece draw a 8 cm by 4 cm rectangle  to fit the led dimmer. Use a jig saw to saw the rectangle out.  In the single layered piece drill a 6 mm hole for the led dimmers potentiometer. Glue these two pieces together.
On the double layered 20 cm piece draw a 6 cm by 9 cm rectangle (the size depends on your heat sink). Saw the rectangle out with a jig saw. Glue the double layered 20 cm piece onto the single layered 20 cm piece. Draw a cross in the rectangle and make a mark 1 cm from each corner. Drill a 6 mm hole in each mark and drill a 32 mm hole in the middle of the cross.
Measure 3 cm from one end of the 65 cm double layered piece and drill a 6 mm hole.
Glue the 65 cm single layered piece onto the 65 cm double layered piece. Saw a 45 degree corner off the 65 cm piece on the opposite end of the previous drilled hole.
Step 4: More Drilling and Gluing
Take the 23 cm piece. On top of this piece make a mark 2 cm from each side. Drill a 10 mm hole 1 cm deep on these marks. Glue the dowels in it.
Do the same for the 20 cm piece.
Measure 24.45 cm from the straight cut end of the 65 cm piece and make a mark 2 cm from each side and one in the middle. Drill a 10 mm hole 1 cm deep on these three marks.
Step 5: Gluing Plus Wiring
Put the electric wires in place: one will lead to the power supply, the other will lead to the led.
Glue the 23 cm piece and the 20 cm piece  to the 65 cm piece. Use wood clamps to hold it all  together while the wood glue dries.
Step 6: Aluminum Work
Draw a cross on the heat sink which connects the corners and mark 1 cm from each corner. Drill a 5 mm hole on each mark.
Draw a 1,5 cm by 1,5 cm square in the middle of the heat sink. Drill a 2,5 mm hole in each corner of the square.
Drill a 5 mm hole in the middle of the aluminum disk. Screw a 1,5 cm piece of screw-thread in the hole. Sand the disk until it is smooth.
Step 7: Electronics Plus Installation
Use the M3 bolts to bolt the led to the heat sink and put thermal paste in between for maximum heat transfer from led to heat sink.
Solder the wires on top of the lamp to the led. Use M6 bolts to bolt the heat sink to the wood.
Connect the cables from the power supply and from the led to the led dimmer (check polarity). Screw the led dimmer in to place.
Screw the aluminum disk on top of the led dimmers potentiometer.
As finishing you can apply wood wax.
Step 8: Enjoy.
Enjoy reading under the light of your desk lamp.
    • Fandom Contest
      Fandom Contest
    • IoT Challenge
      IoT Challenge
    39 Discussions
    rafununu
    Reply 3 years ago
    How could you dare comparing a beautiful and rare object of wood with a boring ugly lamp maybe not dimmable !
    Yonatan24rafununu
    Reply 2 years ago
    This commenter is a spammer, just to let you know. he has commented on many other wooden desk lamp I'bles Next time, report these types of comments!
    kubante
    Reply 3 years ago
    paul pls stay at home.
    ZiddiK
    Reply 3 years ago
    buying and making one yourself are different things
    sypher
    3 years ago
    looking for inspiration, that is gorgeous...
    d.moskalyk
    5 years ago on Introduction
    Thanks for posting this. Worked out great for a puzzle building lamp for the wife. Not as complicated as yours, but works great.
    It won't let me post a pic of it but if your curious here's a link.
    http://dalemoskalyk.wordpress.com/2013/08/26/finally-got-back-in-the-shop/
    Thanks again.
    masmarius
    6 years ago on Introduction
    buddy, this is awesome... and the wooden box fan blew my mind too!
    cabolero1993
    7 years ago on Introduction
    In step 2, how thick should the boards be after you glue them together? That step confuses me just a little bit (first project), do you mind going in to more detail?
    HHarrycabolero1993
    Each wooden board is 9 mm thick, so 2 layers equals 18 mm and the total thickness (3 layers) equals 27 mm.
    acoleman3
    if anyone wants an outlet for leds and drivers, thecustomsabershop has what you need i believe.
    newbeatle
    hi so nice the design of the lamp, congratulations !! i like the minimalist concept of the lamp, and also that wooden detail to avoid the "coldness" of the strict minimalist things.. i oly have a disappoint , and is that you can do you own dimmer!! i have not so much time to post how to build one, but if someone makes a google search about pwm circuits ( i have found one that seems to me so simple to build, but i dont know if its ok to post it here, but google it and its the second) and that can do the job for the dimmer. instead of a motor, you can put the led , just bear in mind that you need a resistor for current control .
    again , nice design
    salutes from mexico
    HHarrypaulstaf
    The 10w led is from ebay (just type 10w led) http://www.ebay.com/sch/i.html?_nkw=10w+led+warm+white&_frs=1&_trksid=p3286.c0.m359 . The led dimmer i got from a local electronic store, it is a velleman MK187 kit http://http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=525683
    Klister
    I've never worked with an LED before, so it would be nice to know exactly what parts you used. But here is my real question. Does a 10 W fixture really need a heat sink? I know its in wood, but the residual heat has to be minor. Most of the electricity from the 10 W goes to light and only amount not converted to light becomes heat, or are these fixtures not as efficient as they claim?
    HHarryKlister
    You would be surprised how much heat this led creates. The created heat is not a problem but the fact that the 10w led cant handle the heat is. If i would power the led without the heat sink the led will burn down after approximately 45 seconds. The bigger the heat sink the longer the lifespan. The commercial available heat sinks for the 10w led are even bigger than my CPU heat sink. If you don't like the big heat sink you can choose for cob leds they have better heat dissipation properties. The 10w led is from ebay (just type 10w led) http://www.ebay.com/sch/i.html?_nkw=10w+led+warm+white&_frs=1&_trksid=p3286.c0.m359 . The led dimmer i got from a local electronic store, it is a velleman MK187 kit http://http://www.vellemanusa.com/products/view/?country=us&lang=enu&id=525683
