Desktop Terrarium With Night Light
110,733
1,473
61
About: Steampunk-Design builds and developed the most modern technical equipment, fine jewelry and futuristic devices implemented with funds and materials of the Victorian era.
Almost every Steampunker has the same problem, to finance all the big projects in your head you must sit many hours on your desk to earn the money.
Often the office is dismal and grey. This is quietly no place for an awesome mind.
Now I invent this Desktop Terrarium who allows you to put your own exotic habitat on your desk. You can study rare plants in a perfect eye catcher setting.
And if you some weeks not in, no problem my habitat needs only a few drops of water every four month.
All you need is
- One old defect bulb (clear or matt)
- One solar power Garden LED light
- Small wooden board
- Brass or Copper tube
- Brass or Copper tin (wall clock)
- sundry brass parts
- Switch
- AAA Battery + holder
Also don't miss to visit my website with more great projects under Steampunk-Design.
Supplies:
Step 1: Prepare the Bulb
In the first step I prepare the bulb.
Attention! Please use gloves and a safety goggles…
The bulbs are very thin and there is a high risk that they broke during work.
Try to work in front of a vacuum cleaner because this will avoid that small cullet spread over the area you work in.
In the middle of the socket is a small metal plate you can lift it and pull out with a small knife.
If you remove the plate you will find a small hole in the black glass seal.
Stick a small screwdriver in this hole and break the glass. Now you can also remove it.
Now you see a small glass tube which holds the filament.
With a small plier you can also break the tube and remove all.
After this you make the hole round and enlarge it a little bit.
The glass breaks not complete because it can only brake until the glued socket.
Now you can clean the bulb with water.
You see on my pictures that I use a matt bulb. The matt colour is only a fine powder that can easily wash away with water.
Step 2: Solar Power Light
For the automatically night light I use a solar garden light.
This is the easiest way because you only need to dissemble it and make some wires longer and finally mounting all in the bulb and base tin.
Remove all screws and get the circuit with the LED out of the housing.
Cut the wires to from the solar panel to the circuit.
Cut with a cutting wheel from the Dremel the solar panel out.
Solder out the LED and solder two long wires on.
Later the circuit is placed in the base tin with the switch and battery and the LED wires goes through the brass tube to the bulb.
Drill two holes into the tin then fit the switch in one and take the wires for the solar panel out.
Take care with duct tape that no parts of the circuit has contact to the brass parts!
If you have checked all parts again you can switch the power on.
When you hold your hand above the solar panel it must switch on the light.
When the solar panel is in the light it will charge the battery.
Very important:
To bend the small brass tubes is necessary to filled it with sand!
Only if your pipes filled with fine sand you can bent the brass tubes, otherwise you pipe kink directly and is destroyed.
I filled the tubes with bird sand and sealed at the ends with electrical tape.
Then I use a brake pipe tool from Hazet (Art. Nr. 2193-1) the bent the radius.
The last picture show you an only battery powered version with a CR2032 cell.
Step 3: Chassis
For the chassis you can use everything you find in your workshop let your mind play and create something beautifully.
At last I add some pictures of my different versions.
You are free to copy it.
Have fun with this weekend project and stay tuned on my website. I will launch an English version shortly.
Step 4: Filling
Some of you ask for the filling of the bulb.
My first Terrarium is filled with orchidaceous flower soil, white stones and moss out of the forest.
Moss is ideal for this application because it work like an anti fungal. That means if the glass is humid in the sun you get no mildew.
Another bulb is filled with fine black sand and a carapace from a prawn.
Currently I work on a very big bulb (500 Watt) I try to put sea monkeys in.
Green Living & Technology Challenge
Finalist in the
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Classroom Science Contest
    61 Discussions
    NancyG45
    3 years ago
    This looks so cool I can't wait to make it.
    Nancy
    PLC55
    5 years ago on Introduction
    Hi, I thought this was so cool, I just had to have a go. Took a while to find some worthwhile bits and pieces but it's finally all together and working, just have to add the little garden. This one uses two LED's off a double A battery, that's how the solar light came. Thanks heaps for taking the time to share your Ible, I found it very interesting and look forward to trying a few more of your projects!
    Pete.
    CraigRJessPLC55
    Reply 4 years ago on Introduction
    Really nice! Love the shiny copper too.
    Where did you get the brass parts on each end of the copper and how does it stop the copper from pulling out? Did you have to flare the ends of the copper?
    PLC55CraigRJess
    Reply 3 years ago on Introduction
    Hi Craig, sorry not to have gotten back to you but I formatted and lost all my stuff (no hard copies, live and learn), anyway, I hunted around markets, second hand stores, garage sales and even a car parts shop (for a brass welsh plug to fit the cell into), took a good while to get enough bits and pieces to start it. the tube ends are all flared with plumbing fittings so they dont move or come out, welsh plug is flared and soldered.
    CraigRJessPLC55
    Hey no problem.... **it happens. :~)
    Ok, you used a flaring tool for the ends of the copper pipe, and a Welsh plug - which part is that? Terminology may be different here.
    How are you securing it into the light bulb?
    PLC55CraigRJess
    Well, here in Aust, a welsh plug is a replaceable plug (in this case, the biggest one available) for the water jacket of a car engine.
    The bulb attaches to a hose connector with a thread on one end, I crushed down the rim of the metal end of the bulb and got the connector to screw in, the tube is flared so it cant come out. Heres a few pictures, thought it might help.
    CraigRJessPLC55
    Ok, I got you now. Makes sense. Thanks for that :~) Will have to try one for myself.
    I bought that Suzuki in the avatar from up in Melbourne and used it in Tassie for a bit then sold it b4 heading home.
    PLC55CraigRJess
    Nice bike! Bet it was great riding around Tassie on that!
    Yeah, have a shot at one, I really enjoyed getting mine together, a bit frustrating sometimes, going to markets etc and finding nothing I could use, but now and then I'd come across heaps of good stuff. I have even had several decent offers on it, I dont think I could part with it tho.
    CraigRJessPLC55
    I lived in Tassie for a year :~)
    Even saw Chopper Reid walk by the coffee shop in Hobart my pal and I were sitting at. He said, "there goes Chopper Reid" and I said, "who the HELL is Chopper Reid?" LOL Me not knowing his history, watched him walking down the street.
    PLC55CraigRJess
    I'v never been to Tassie, and I live in Melbourne, its cold enough here!
    This used to be Choppers old stomping ground, he moved to Tasmania when he got out of jail for a quieter life, he passed away from cancer a while back.
    CraigRJessPLC55
    Ya, thats what I read from his book and the Eric Bana movie: Chopper. Eric was awesome in that movie!
    Bojangles in Melbourne right?
    PLC55CraigRJess
    Bojangles (nightclub) is gone now I believe, it was in St kilda near the old sea baths.
    sparko118
    hay thanks for the inspiration for this project it was fun to make
    here mine
    https://www.instructables.com/files/deriv/FWY/Z2JF/HHS9IQ5G/FWYZ2JFHHS9IQ5G.THUMB.jpg
    HrdWodFlor
    I really like this! Just a note for those who cant get fine grained sand, you can use salt or fill the tubing with water, seal the ends and freeze it before you bend it. I know that some companies that make French horns use the frozen water method to put the bends into the horn.
    nmvb
    6 years ago on Introduction
    Made one as a Christmas gift for my dad. Turned out great. I used a 30 watt bulb which gives a lot more room for plants. Great ible.
