Detachable Projector Wall Mount
13,857
143
8
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author ...
The detachable projector wall mount is a DIY solution for hiding your home theater projector when you are not using it. I made this because I have a narrow living room and wanted to mount my projector as far away from the screen as possible, which meant mounting it to the opposite wall. However, I did not want to have an ugly projector permanently mounted to the wall behind my couch. This solution allowed me to both mount it to the wall and not have to always look at it.
This simple system allows you to install and remove the projector mount in a matter of seconds. All you need to do to attach it is to slide the attachment plate onto two relatively unnoticeable bolts that are anchored securely to a wall stud. To remove it, just do the opposite. Also, because of the limited amount of hardware required, all of the components can be easily stashed away until movie time comes again.
Step 1: Go Get Stuff
Step 2: Cut the Brackets
Cut out the aluminum brackets using the attached template files.
WallPlate.eps should be cut out of 3/8" thick aluminum and ProjectorPlate.eps should be cut out of 1/8" thick aluminum.
To accomplish this I used a water jet. If like most people you don't have access to a water jet, you can use a host of traditional fabrication techniques to get the job done. With a little patience, you could even feasibly cut out these templates with a power drill, hand saw and/or Dremel.
This is not insurmountable. For more info check out the digital fabrication by hand Instructable.
Even though I used aluminum, you could also feasibly use plywood, polycarbonate, or a thick acrylic if you find that easier to work with.
Step 3: Attach
Pass an M12 bolt through the center hole of the slip-on base plate and the 0.4725" (12mm) hole in the projector plate.
Use a nut to fasten the two firmly together so they can't slip.
Step 4: Drill
Use the four holes around the perimeter of the 0.4725" (12mm) hole as guides for drilling four 0.166" holes with a #19 drill bit through the slip-on base plate.
Step 5: Tap the Holes
Thread the four holes drilled in the slip-on base plate with an M5 tap.
Step 6: Tap Some More Holes
Thread the two holes in the wall attachment plate with a 1/2-13 tap.
Step 7: Countersink
Countersink the four 0.166" holes in the projector plate such that a flat head bolt is flush with the top of the plate when inserted.
Step 8: Sand and Polish
Sand the projector plate using 220 grit sandpaper, and then incrementally increase up to 1000 grit.
Once done, polish to a nice shine using a buffing wheel.
Step 9: Bolt
Bolt the projector plate to the slip-on flange using M5 flat head bolts.
Step 10: Strap
Pass the velcro straps through the two channel slots to create a loop for holding the projector.
Step 11: Sand and Polish
Like the projector plate, sand the wall attachment plate using 220 grit sandpaper, and then incrementally increase up to 1000 grit.
Polish to a nice shine using a buffing wheel.
Step 12: Attach
Attach the slip on flange fitting firmly to the wall attachment plate with 1/2-13 bolts.
Step 13: Find the Stud and Mark
Before finding the wall stud, I needed to figure out the proper height of the projector. To do this I turned the projector on, and held it up until I found the height that best frames the image on the screen.
Next, to find the wall stud where I mounted the posts for the sliding plate, I first marked it by placing magnets on the hidden nail heads. By doing this and carefully knocking on the wall, I was able to approximate where the center of the beam was.
I then used the sliding plate to trace the position of the mounting holes.
Step 14: Drill
Use a 3/8" spade bit to drill the two markings in the wall through the drywall and deep into the wooden beam.
Step 15: Anchors
Thread the 1" shoulder bolts into the threaded inserts.
Using the pilot holes, sink these assemblies firmly into the wall stud until the base of the bolt head is protruding 3/8" out of the wall.
Step 16: Attach the Plate
Slide the plate down onto the shoulder bolts until it is locked in place.
Step 17: Post
Insert the 6" aluminum tube into the slip-on flange.
Step 18: Projector Plate
Place the slip on base plate down onto the top of the tube.
Step 19: Add Projector
Strap the projector down to the plate, plug it in, turn it on and enjoy!
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    8 Discussions
    Angelbane
    3 years ago on Introduction
    I really like to see i'bles that are well documented like this, thank you.
    I know this has nothing to do with the instructable but I had to double take because it looked like Johnny 5 as a glance taht is what made me click it.
    U_eriksen
    Very nice.
    One suggestion would be some soft padding on the back of the plate (adhesive cotton felt pads or whatever) to avoid leaving marks on the wall.
    Saiyam
    3 years ago
    Yes, it has only been a few months but earlier you published an instructable every now and then. This is the reason that a few months looks like a long time! :)
    Saiyam
    3 years ago
    So, you are back again after a long time! Another great instructable :)
