Dewalt Bluetooth Speaker and Power Bank
9,679
142
17
About: I am 37, I have a job that allows me to build and make daily. I love my job. I have 6 children, my oldest is also a maker and has written her own instructables. I own a computer repair shop, and I build a lo...
I have made a Dewalt Power Bank, and I have made a Dewalt Bluetooth Speaker. But I have not made a bluetooth speaker and power bank all-in-one, so I decided to make one. Actually I have a buddy who is a forklift driver, he had mentioned to me that he would like a way to listen to music without draining his phone. So I told him that I could build him something.
Supplies:
Step 1: Parts and Materials
These are the parts that I used to build the Dewalt Power bank and bluetooth speaker.
Parts
1. Bluetooth Board and Amplifier -- Here is a Link to it on Amazon
2. DC to DC Buck Converter -- Here is a Link to it on Amazon
3. Computer speakers -- I just found some old computer speakers and Dissected them for the speakers.
4. Dewalt Case -- Here is a Link to it on Amazon
5. On / Off Switch -- Here is a Link to it on Amazon
6. Momentary Switch -- Here is a Link to it on Amazon
7. Power Bank Board -- Here is a Link to it on Amazon
8. Batteries -- I borrowed the batteries from a broken Chromebook.
Step 2: Prepare the Case
The case that I chose has some internal dividers that will need to be removed in order to make room for the electronics. I used the dremel tool to remove all of the internal dividers. Then I used a Drill with a Hole saw to drill the two holes for the speaker, along with the holes for the on / off switch for the bluetooth board, and the button to turn on the power bank.
Step 3: Wire It Up
The Wiring on this project is really simple. The speakers were placed over the holes and hot glued into place. The the bluetooth board was hot glued into place between the two speakers. The speakers are plugged intot he bluetooth board. The Power for the bluetooth board needs to be between 8v -24v. Because the battery pack will only give us 3.7v we will need to use the dc-dc converter to step up the voltage to an acceptable level. I hooked the converter up to the battery pack, and the other side of the converter was hooked to my meter. I watched the voltage on the meter as I turned the little screw on the converter. The little screw is actually a potentiometer that will increase or reduce the voltage depending on the direction turned. I turned the screw until the meter showed about 12v. Now I can wire the batteries into the converter with the on /off switch in between. For the switch I ran the positive from the battery to one side of the switch, and then the other side went to the positive on the converter.
The batteries were also wired to the USB power bank board so that they can be charged. I also wired a momentary switch to the power bank board so I could turn it off and on without opening the case.
Step 4: All Done
I am happy with he way that this project turned out, My buddy was really happy at how it worked. I liked it so much that I will be building one for myself as well. Thank you for taking the time to read through this Instructable.
Favorite, Comment, Subscribe, and Vote.
Most Importantly Keep on Building.
Power Supply Contest
Third Prize in the
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    17 Discussions
    jbbentz
    1 year ago
    So the same USB port is used to both pull power from the batteries (as a power bank) and to charge the batteries?
    Or is there more to it? Maybe that white USB cable in some of the pictures has something to do with charging. I'm a little unclear.
    ZOUDIOjbbentz
    Reply 1 year ago
    That would not be good because of two things: 1) power goes through two converters, thats inefficient 2) power banks have a power limit, which would cause the amp to cut out at high power. @MakrToolbox I hope that the battery has its own protection circuit? Otherwise deep discharge may damage the cells.
    MakrToolboxZOUDIO
    Reply 1 year ago
    The battery goes directly to the converter and to the power bank board, with a switch cutting the positive to the step up converter, it does not go through both, that would be bad. as for battery protection, the power bank has built in protection if you are using the usb ports, the bluetooth board does not, but I just watch the power meter on the power bank board and don't let it run all the way down.
    MakrToolboxjbbentz
    Reply 1 year ago
    There is an Micro USB port that is used to charge the batteries, the white cable is just a lightning cable to charge my iphone
    Jimichan
    1 year ago
    I really like the case you used! I made something similar, but made a wood case and used a 8 x AA, 12V battery pack I found on Amazon for about $4. I filled with Eneloops, so I prefer to use the Panasonic charger.
    ZOUDIOJimichan
    Reply 1 year ago
    That's also nice indeed! Still 12v (high power), but no inefficiency from the DC DC converter. With a step down converter you could still charge your phone too
    Ovog15
    1 year ago
    I don't understand this. It is supposed to charge your phone, and connect with it via bluetooth, to reproduce the music through the speakers?
    RichM5
    1 year ago
    I did something similar recently, 12 18650s in four triplets, no speakers or BT module. Gives something close to 30000mAh, takes forever to charge, but forever to run down, too.
    nixmix182
    1 year ago
    Any advice on what to look for as far as speakers go? I would really like to thrift some lonely ones for use in one of these.
    MakrToolboxnixmix182
    Reply 1 year ago
    Just about any smaller speakers should work, I used some old Computer speakers that I saved from the trash
    RobertC2
    2 years ago
    Very nice! Looks great!
    --> The DC to DC converter is a BOOST or STEP-UP converter. Not a buck or step-down converter.
