Digital Manufacturing - Project Four Laser Cut Box
8,006
32
About: Fixer, Finder, Fabricator.
This is the forth in a series of Instructables on how to use CAD (Computer Aided Drawing) and CAM (Computer Aided Machining)
if you have been following along you should be getting quite good at using prodesktop so there is not as much detail in the photos and we will be focusing more on the design part of the program as engineering drawings and photo album have been covered in the first three instructables.
This project is a simple laser cut box which little kids love to play with, or you can cut it out of clear and use it to display an object.
If you haven't seen project one, take a look as it covers where to get the Prodesktop, how to activate the software,  how to navigate the screen, what you will need and the mouse functions.
Digital Manufacturing - project one Key tag
Digital Manufacturing - project two desk name plate
Digital Manufacturing - project three 3D printed box
Digital Manufacturing - project five printed toy car
As computer tutorials don't translate to text very well, for this series of  instructables most of the info is in the photos. So click on the first photo and use the arrows to go to the next photo. The boxes in the photos show the location of the icons and have have text in them when you hover the mouse on them.
Step 1: Designing the Front and End
As a normal box has six sides it may surprise you to know you only really need to design the front and end of the box. The top and bottom just need to be traced.
A couple of things before you start, if you make the box too big, it may not fit on the laser cuter, so think a ahead, will six sides and the lid all fit on the bed of the laser? The other problem with making a large box out of acrylic is the material is not very strong so a large box is more likely to break if it  is dropped or handled roughly.
Also fitting legs to  box will help protect the bottom from scratches and also help the box to sit flat on a surface.
Ok let get started, click on the photo and use the arrows to follow along.
Step 2: Assembling the Front, Back and Ends
Assembling the front, back and ends is required to set up the next step and is the easiest way to get the design of the top and bottom correct.
We need to keep our 2D drawing so cut and paste the parts into new designs, and is is also important to get the parts correctly orientated so we will be using the "work-plane new sketch" command
As always click on the photo and use the arrows to follow along.
Step 3: Tracing the Top and Bottom
We are going to sketch in the assembly drawing, tracing the top and copying it into your 2D drawing and a new design. It important that after you do this, that you delete the sketch from the assembly drawing. You can then extruded the bottom and fit it to your project.
click on the photos...
Step 4: Designing the Handle and Final Assembly
In this step we are gong to copy the front, end, and bottom, and design a handle for the top. You can then copy the handle and top into new designs and extrude, then assemble the last two parts of your project. This is the time to check your project to make sure everything fits and it looks the way you want.
If you have a problem when assembling a part often is is easier to delete the component and  add it again
Click on the photo to begin
Step 5: Speeding Up Cut Time and Exporting to DXF
This step will show you how to move the pieces around to minimize the cut time of the laser and reduce the amount of material waste. If you are hiring a laser this will reduce the cost of your project, as the cut time is reduced, and if you have your own laser your increasing the life span of your equipment.
It is important that you delete the "lines on top of lines" as if you don't the laser will cut in the same place twice.
This step also covers how to export a DXF file which is the format the laser cutter needs to cut out your project.
click on the screen-shots...
Step 6: Laser Cuttting and Glueing
Once you have laser cut the box, it can be glued together. A cotton bud works well to apply the glue but make sure that you get the glue on the right edges. It also helps to tape the sides on while the glue drys and sit the box on a flat surface so the box doesn't rock around after the glue drys.
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    3 Discussions
    KonstantinG
    4 years ago on Introduction
    May I suggest a free online open source tool for designing these boxes: http://makeabox.io/ – i am the author and I am adding new features daily. Would love some feedback!
    I love your design! I haven't done any CAD in a long time (since high school) and was wondering if you had a suggestion for a program to use to do this?
    Hi Penolopy, I use a free program Pro desktop, which has a link on the key tag project
    A couple of months ago dropbox said that it was generating too much traffic and they disabled it, so I dont know if it will work or not, it still works from my end.
    If you get stuck let me know and Ill see what i can do. Prodesk top needs to be activated and you can see how to do this in the keytag project. also if you have a new version of windows you will have to fiddle around with "run as xp" and "run as administrator' settings.
    i use these instructables to teach CAD to high school kids, that why they are in that "slide show" format, and kids get the idea very quickly.
    thanks
