Diy Simple Soda Bottle Mousetrap
234,816
1,069
386
About: how to make, how to build, how to do it yourself, create, invent
I have been staring at soda bottles for years and thought there had to be a way to make a mousetrap out of one. They're strong and lightweight and many others have come up with some pretty cool uses for them from funnels to scoops to bird houses. I wanted it to be friendly and humane. I also wanted it to be something anyone could build. It had to be simple to operate and easy to bait. I was able to achieve all of those goals all in one with my diy humane soda bottle mousetrap. It's amazing how simple it is and how well it works.
Step 1: Watch the Video
Watch how easy it is to make and bait . No slamming doors or tricky latches to set. The mouse stays very calm during his capture and it's very easy to release him.
Step 2: Parts List and Tools
PARTS
1) small soda, cola or pop bottle and the cap.
2) a small piece of 2x4 wood.
3) a metal coat hanger.
4) one screw
5) a clothes pin or paper clip
6) 2 pointy things (nails or pins)
TOOLS
1) a drill
2) a drill bit, one size bigger than a coat hanger
3) a drill bit one, size smaller than a coat hanger
4) screw driver
5) pliers
6) hammer
7) cutters
Step 3: Balance the Bottle
First take the 2 nails or pins and gently lift the bottle and find where the balance point is by placing the pins at the same spot on opposite sides of the bottle. Mark the spot. Now make 2 more marks 1/4" (6mm) ahead of those marks towards the bottle opening (not towards the bottom) By doing this, the bottle will be balanced a bit more towards the rear. This is where you'll drill 2 holes that are one size bigger than the coat hanger rod.
Step 4: Build the Pivot
Take a pair of cutters and cut the bottom portion of the coat hanger off. Then cut that piece in 2, one piece longer than the other. Use the shorter one to put through the holes in the bottle and place it against the wood so as to have 1/2" (13mm) of clearance at the bottom of the bottle. Now hammer it into the 2x4 like a nail. Slide the bottle onto it and use the clothespin to hold it on.
Step 5: Bend the Rod
Take the other piece of coat hanger and bend a hook in it. Then bend it at a 90 degree angle. Take your screw and washer and screw it into the wood. Slide the hook under the washer and snug it down. We'll make an adjustment in a few steps.
Step 6: Drill the Cap
Now take the smaller drill and drill 2 holes in the side of the cap. If you're new at drilling, you may want to use a pair of pliers to hold the cap.Take the cap and wiggle and push and slide it onto the rod. (We want the hole to be smaller so that the cap is a tight fit and the mouse won't be able to move it)
Step 7: Adjusting
This part is easy. Move the bottle up and down with your finger. Move and adjust the cap so that it doesn't touch the bottle, but comes as close as you can get it, and that it's centred. You can loosen the screw and slide the coat hanger, you can twist the cap, you can slide the cap, it's adjustable in all directions! Remember that the coat hanger metal is pretty soft too. If things aren't quite aligned, just give it a bend to make it right. Once you play with it for a while, you'll get it perfect.
Step 8: Baiting the Bottle
Using peanut butter is best. Just a smidgen on the end of your finger is all you need. Put it in the top of the inside of the bottle as far in as you can reach with your finger.
Step 9: Placement
The best place to put the trap is along a wall since they don't like to travel across open spaces.
Step 10: Capture and Release
Wait until he's at the bottom end of the bottle then slide the bottle off and screw on a cap. Now take him to where you would like to release him, undo the cap and lay the bottle on the ground. When he's comfortable, he'll leave the bottle.
Step 11: If You Missed the Video at the Start, Here It Is Again!
Happy Humane Mouse trapping! You'll find that looking at him up close in the bottle, you can't help but like the furry little guy!
Animals in the Wild Challenge
Grand Prize in the
5 People Made This Project!
  • Classroom Science Contest
  • IoT Challenge
    IoT Challenge
  • Gardening Contest
    Gardening Contest
386 Discussions
ClaudioK3
1 year ago
Super, easy to make
ellens77
1 year ago
This is brilliant. I'm going to make this. If you set the mouse free and he comes back in for more PB, do you think he would learn not to go in the bottle the second (or third) time?
jeanniel1
1 year ago
How funny to read a mouse trap 'ible be peppered with so many cockroach comments! So, what about rats - larger bottle opening, and bottle?
insydney
2 years ago
here in australia we have a big problem with cockroaches... i'm sure there's a simple solution lurking in here somewhere to catch the dirty little b***ards using a drinks bottle or similar ? obviously gravity won't be the key, maybe friction (or lack of)... ?
insydneyinsydney
Reply 2 years ago
Btw i wasn't thinking of a 'humane' release for cockroaches...
John T MacF Moodinsydney
Reply 2 years ago
Neither was I. A sawed off shotgun with fine bird shot makes too much noise, and stomping on them takes too long. Abd a blowtorch is a good way to burn down the building! Powdered borax does work...
insydneyJohn T MacF Mood
Reply 2 years ago
there must be some sad creature out there that looks on cockies as a feast... make friends with them :p
geeserinsydney
Reply 2 years ago
Huntsman spiders eat cockroaches apparently
Ferntoegeeser
Reply 1 year ago
Anything bigger than a soda can is one hell of a spider I don't want to be tripping over!
DanB306geeser
Reply 1 year ago
What eats Huntsman spiders?
NancyK63insydney
Reply 2 years ago
Chickens love to eat roaches. They chase them down.
Anthony.NancyK63
Reply 2 years ago
If that be true and you eat chicken, then you know that your eating that cockroach too.
NancyK63Anthony.
Reply 2 years ago
No, actually not. You are eating some few substances absorbed by the chicken from the cockroach. Did you know that the water you drink has touched fish sperm. Does that gross you out.
CurtRinsydney
Reply 2 years ago
some lizards eat them
GoWolves11insydney
Reply 1 year ago
You should, as cockoaches are good pets as you can see in my profile picture.
SimonA2insydney
Reply 2 years ago
hahahaha. I looked for this before and what I can recall was setting up a huge jar and placing bait inside for the roaches. to prevent them from crawling back up, put vaseline on the inside of the jar.
tafeliceSimonA2
Reply 2 years ago
I heard talc on the sides keep a lot of bugs from climbing. very slippery.
insydneySimonA2
Reply 2 years ago
that's not a silly idea... :)
however i love the idea of a device like the one the OP constructed, so simple but 'prof brainstorm'ish'... lol
MarkH555insydney
Reply 1 year ago
Use pet anti flee spray on the locations they're in. The pet anti flee contains fipronil. It will kill the pest for you in a breeze.
