Dremel Belt Sander Attachment
35,993
461
31
About: Just a fellow who want's to learn new tricks and skills.
I made a small sander attachment to be used with my dremel rotary tools.
Sander can be mounted to my diy dremel lathe, or it can be used without it.
Its light weighted and easy to take outside, i like to work outside in the summer, so good mobility is a bonus.
With cordless dremel it really is very mobile.
Step 1: Frame
Structure is very simple
I used 3mm steel plate as a material, it can be made from l-profile bar too, for example.
I just like to re-use scrap... that 3mm plate was only what i found.
I used wheels and bearings from the skateboard, some nuts and bolts.
This one was very cheap, because those nuts and bolts we're the only things i needed to buy.
Step 2: Tightening.. Mounting..
For mounting the dremel and tightening the belt i made a simple part from the polycarbonate.
I took the thread part from the dremel shaping platform attachment, you can take it nearly any dremel attachment if you have one spare.
Video in the last step shows the process.
Step 3: Guide.. Assembly
To keep the belt straight i made a simple tilting mechanism from the steelplate and bolts.
In the steelplate is M8 thread in the middle and M6 threads in the sides, bolt that works as an axle for the upper wheel is placed in the middle of the plate. Plate and side bolts are in the same line with the belt. Tightening or loosening smaller bolts tilts the upper wheel, what guides the belt from side or another. With simple adjusting you can get the belt go straight.
As a drive wheel i mounted the dremel drum sander to the rotaty tool, tightened it to barrel shape. It works very well in that task.
I was suprised how powerfull it is, it was supposed to be for making small things, jewelry etc.. but i have used it with biger tasks too, with no problems.
Video shows more.
Step 4:
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    31 Discussions
    DylanS117
    1 year ago
    This is amazing! It'd cost and arm and a leg to get a belt sander on my budget...that's if I even found one. I'm definitely going to be making this. Do you have any more detailed measurements and pictures of the various steel plate parts?
    Jose ArturoG1
    2 years ago
    Hermoso muchas felicidades saludos.
    NeilRG
    2 years ago
    The tracking adjustment is a nice and essential feature. Nice project.
    ScottA133
    2 years ago
    I would like more information on to make this if you are willing to help explain. Can we talk private?
    Hi. You can send me mail to Ttsoikkeli@gmail.com I tried to send you a message, but it doesn't seem to work...
    Juanmigp
    2 years ago
    Buena herramienta, eres un manita.Felicidades.
    TúC2
    2 years ago
    yes
    Leei1337
    2 years ago
    This is amazing, I was literally thinking about making one of these last week using the same techniques!
    Thanks. Yep, that's sometimes amazing how two persons think in the same way, in the other sides of the world.
    GENGHIS KHAN JR III
    2 years ago
    Looks like an amazing tool that'll make Knife ownership and maintenance easier .
    TomK147
    2 years ago
    I was wondering if I could use my Dremel to drive a belt sander. Thank you for the awesome video showing how you did it! Also, thanks for showing how you re-purposed scrap material. I would do the same thing :-)
    cavalier19
    2 years ago
    Versatile tool gets better. Very neat craftsmanship. Looks very professional.
    branke
    2 years ago
    Great,
    I can use one of these.
    But I am not sure that the Dremel shaft will last under the tension.
    It will not carry all the stress long.
    Please correct me if I am wrong!
    The other Finnish guybranke
    Reply 2 years ago
    I have used mine for a 8 months now, i use it also with my lathe and haven't notkced any problems. Belt doesn't need to be very tight, sanding drum is made from rubber and has enough friction.. So it doesn't "bend" the shaft very much. I think it stresses the dremel as much or less than routing or cutting with the spiral cutting bits does.
    brankeThe other Finnish guy
    Reply 2 years ago
    Hello there,
    Thanks for your answer.
    Seems like I have underestimated the Mighty Dremel.
    Will build one A.S.A.P.
    Regards,
