Drone Parachute
8,867
66
20
Summary
This is a spring loaded canister that can be attached on a GoPro Mount. It will hold a 36 to 48 inch paracute. It is meant for drones under 6 lbs. You will need a small screw to attach lid. (2mm x 30mm) and a spring from the inside of a tall sprinkler head. You can also go to Alibaba and find a much tighter compression spring.
Supplies:
Step 1: Buy a Chute
You can get your chute here:
http://www.sunward1.com/yellow-thin-mill-parachute...
Make sure to ask for ultra thin lead lines.
Step 2: Get a Metal Servo
Make sure to get a all metal servo.
This is the one I use:
http://www.ebay.com/itm/4x-EMAX-ES08MAII-Mini-Size...
Make sure your servo arm is also metal. I recommend this one:
http://www.ebay.com/itm/Hitec-Standard-Metal-Servo-Horn-3-4-Single-Sided-HRC55701-/371704171397?hash=item568b4b8b85:g:U84AAOSwbYZXVsnY
Step 3: Aquire 3D Print Files.
You can get the files on Google Drive:
https://drive.google.com/open?id=0B-JX5fq9m5VsNTN1...
or Thingiverse:
http://www.thingiverse.com/thing:1719808
Step 4: Aquire Compression Spring
You can get one out of a sprinkler head replacement like the one here.
http://www.lowes.com/pd/Rain-Bird-4-in-Plastic-Pop...
or go to Alibaba for a much stronger (and preferred) version
1.5 mm wire thickness. 35mm hoop diameter. 120mm height
Step 5: Put It Together
You can see that the servo will go in the square hole and the two screw holes are there.
You will need Paracord. This can be acquired at any craft shop.
When you cut it, burn the ends to seal.
For best results make your main line the length of the chute width.
Tie the main line to the bar at the bottom of the chute canister through the to hexagonal holes.
Tie the other end to the hoops of the chute.
Put a 2mm x 35mm screw through the lid holes carefully. Do this by screwing in and backing off without forcing the screw all the way on one shot.
This unit is attached with a male GOPRO adapter knuckle.
Step 6: Test It!
You will need to test the servo to make sure it is centered and working.
This system was made for a 3D Robotics Iris+ and powered with a Pixhawk flight system powered by a 5v UBEC.
You can hook this up to your Transmitter as a manual switch but the Pixhawk has auto failure detect and will deploy when drone fails.
Documentation here:
http://ardupilot.org/copter/docs/parachute.html
Full instructions on Parachute loading is here:
http://www.shadowquad.com/product/drone-parachute/
Drones Contest 2016
Runner Up in the
Drones Contest 2016
    • Arduino Contest 2019
    • Fandom Contest
      Fandom Contest
    20 Discussions
    karanp18
    Question 5 months ago
    Where are you selling this product on internet ? I would like to buy it.
    JimmyO9karanp18
    Reply 5 months ago
    I am not currently selling these. I can make one though. Contact me at Google Search: Shadowquad Aerial Imaging. Email link on top black bar.
    karanp18JimmyO9
    Reply 5 months ago
    I contacted you via email. Please reply on it.
    karanp18karanp18
    Reply 5 months ago
    The email link is not working anymore, please give me another email link.
    SilvioD11
    1 year ago
    Hi, what are the unit measures on the .STL files you uploaded on thingiverse? mm? inch?
    I don't have a 3D printer, so I'm calling a 3D service print for printing all the parts, and they want to know the unit measure to give me a quote.
    Thanks
    JimmyO9SilvioD11
    Reply 1 year ago
    MM - I sell this product for $99 on my website. shadowquad.com
    GonzaloS28
    1 year ago
    Any chance you have a link to the Alibaba springs you referred to? Having trouble finding it....
    JimmyO9GonzaloS28
    Reply 1 year ago
    I'd have to search em out again. I have some here.
    alexandre_willame
    1 year ago
    The Springs from Sprinklers, great idea! Thanks for sharing :)
    JimmyO9JpsManCave
    Reply 2 years ago
    Thanks. I need to put brackets for carbon fiber booms.
    Essyx42
    2 years ago
    Great instructable! You can use dynema instead of paracord, whit that you can reduce the diameter of the cords 'cause dynema is stronger. A few fabrics like, like silnylon or cuben can be great to try for the chute: they are really light and maybe you can get a larger chute in the same volume. I voted for you!
    JimmyO9Essyx42
    Reply 2 years ago
    Where do you get these fabrics?
    seamster
    2 years ago
    This looks pretty good.
    Is this for safe recovery in case the batteries run out? I figured that was the purpose, but wasn't sure! :)
    Mohammad WJseamster
    Reply 2 years ago
    I'm pretty sure in this case he flew the drone out of the remotes signal range triggering the safety feature. You could have it coded to open the servo motor when the battery status level reaches a threshold. Just enough for it to open the servo.
    JimmyO9seamster
    Reply 2 years ago
    I triggered this by switch. The apm code will trigger if angle is beyond 20 degrees or if it drops too rapidly. It shuts off props and pops the chute.
