Duct Tape RC Airboat
23,914
308
28
About: My name is Simon Sörensen and I am the creator of RCLifeOn. I´m 19 years old and live in a town called Trollhättan, located in the southwestern part of Sweden. I´ve been in the RC hobby...
I went to my local hardware store and came across some sheets of foam. Earlier that day I had been working with my old airboat and realized how terribly built it really was. That's when I came up with the idea to make a super light, basically indestructible and powerful airboat. To my surprise it was actually easier to build than I initially thought. Since it's only a sheet of foam, it's not exactly rocket science to build one yourself. Try it, you won't be disappointed!
Step 1: The Construction
Simply, take the sheet of foam and draw the following dimensions. Length:75cm or 29.5" Width: 35cm or 13.8"
With these guidelines it should be quite easy to successfully make the first step of the build. Note: Make sure to have a sharp knife while cutting!
Make a 45 degree bevel on all the edges, except the back edge. Make the sharp corners soft with some sandpaper .
Step 2: Cover the Sheet
Cover the entire sheet of foam with duct tape, this will give a long lasting airboat, and make it practically indestructible. Make sure to rub the duct tape firmly onto the foam.
As you apply the tape, push the front of the airboat upwards, as this will give the nose a permanent pitch up and make it easier to go on water.
Step 3: Motor Mount
You don't need to make a more advanced motor mount than this. Even after a couple of crashes (flips), the mount for the motor has been intact.
You need a brushless motor, speed controller, servo, receiver, transmitter and a battery. You also need to make your rudder with some spare foam. I used depron and a 2mm steel rod to connect the servo and rudder. The gyro makes the airboat more stable but it's definitely optional.
Step 4: Install the Electronics
Install the electronics and you are done! It's now ready to run and will work on grass, sand, asphalt, water and dirt. It doesn't take more than a couple of hours to build and will be a blast to drive. Make sure to build one yourself!
Make sure to subscribe to my YouTube channel and thank you for watching!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
28 Discussions
charliej166
3 years ago
Is there any components out of a Rc speed boat I could use for this
20099720charliej166
Reply 2 years ago
probably , like the servos and maybe the motor but not the prop
charliej166
3 years ago
Hey quick question I've got a old hubsan quad copter there's 2 motors that work and wondering if I put the mother board on a small bit of foam would it work
fenderstrats
3 years ago
will it go across water
Only the rudder is connected to the gyro. If one were to use two engines instead of one (like I have), you would use the gyroscope to change the rpm of the motors. But in this case, a gyro on the rudder is all I have, and not even necessary.
Hmm, what is the rudder itself in your case? Is it something salvaged from a quadcopter that has a microcontroller? I am thinking of making something similar (thanks for the inspiration btw!) but I don't see how I'd avoid using a microcontroller to interpret the readings from the gyro.
Ash1202RCLifeOn
Reply 3 years ago on Introduction
hey pls can you give me all the the names of components you need to make a RC airboat
RCLifeOnAsh1202
Brushless motor, speed controller (esc), servo, battery, receiver and a transmitter.
Aha, as I imagined, this is something more advanced than what I consider as a gyroscope (a component that *just* returns angular velocity in the 3 axis) and you usually have to connect it to a microcontroller in order to interpret its data, by integrating them to get the angular displacement or simply "how much it turns".
I'll look the gyroscope you mentioned up, since it might make my life easier for other projects too. Thanks! :)
RCLifeOnkarlpinturr
I simply dug some foam out and put the motor mount glued in with some hot glue. Works great and is way stronger than I ever thought.
Starsword7
what motor did you use, you should be more specific about the electronics.
cool instructable- its like a hovercraft without a skirt
That is a really Cool RC! If I may make a couple suggestions: One: Some kind of beacon to help you find it if it manages to leave your site, A strobe and or radio beacon, and Two: A roll bar that would fit the design. It would protect your prop and put the vehicle back in an upright position. Aside from that, I WISH I could have done something like this when I was younger!! Brilliant !!!
