Duvet Eating Alarm Clock
2,568
25
12
About: Maker with an obsession for the 8-bit!
This is an alarm clock machine that steals your duvet.
This invention is not nice. It does not make the world a better place nor make life more comfortable. It will not make you happy. When you are your most vulnerable it will thrust you shivering and naked into an unfair world, and get you the hell out of bed!
For some people the noise of alarm clocks is simply not motivation enough to wrench them from the dream world and face reality. They require an incentive that is rather more aggressive and physical. I am one of these people, and this is my solution to the problem of waking up.
Step 1: Gather Stuff
As per usual I didn't do a great deal of planning and just sort of made it up as I went along with things I had kicking about. These things were...
  • 12v Winch
  • Old car battery
  • Bicycle cogs & chain (amazon)
  • Arduino Uno
  • 5V Arduino Relay
  • Chunky 12V double throw relay
  • MDF sheet material
  • 19x32mm battening wood
  • Broom handle
Step 2: Hack a Winch
I picked up a 2000kg winch from eBay and set about taking it apart. I took off the cable and with the removal of a couple of bolts was able to detach the barrel.
Using a junior hacksaw I hacked off one of the flanges so that gear would slip on, and fixed it in place with bolts.
Step 3: Make a Big Barrel Under the Bed
Next up was to make a big barrel under the bed for the duvet to roll onto.
Using MDF I boxed out an area around 600mm deep under the foot of the bed, and the winch was mounted at the back.
Using a little router I cut a bunch of circles out of some 12mm MDF; two at around 150mm diameter, two around 20mm smaller, and one more a little larger than the gear to act as a flange.
I carefully measured our the center point on a couple of the circles and attached another bicycle cog with bolts as shown.
They all got a 23mm hole in the middle (cut with a flat bit) to receive the broom handle axle. A 23mm hole was also cut into the sides of the under the bed box.
Then it was just a case of sliding the discs onto the axle under the bed, then attaching lengths of battening timber between them (with glue and screws) to give the barrel its form.
As a last step I linked the winch to the barrel with a bike chain, and boxed the winch and chain in with MDF to avoid snags.
Step 4: Hack Together the Electrics
Now it was time to get the winch triggering with an alarm clock. My approach to electronics is to smoosh things together in a pretty kack-handed manner, so please feel free to shout in the comments if you know what you're doing.
I cut a strip of metal off a can and attached one bit to the bell, and one bit to the hammer of my alarm clock. So that when the alarm was on I'd get a circuit that an Arduino Uno could work with.
I opened up the winches handset and found two double pole switches. I fed wires from both sides of one of the switches to a double throw relay. There was going to be a fair bit of current going through this so I used a heavy weight relay. The 5V Arduino outputs didn't have enough oomph to switch the big relay so I used a little relay module to complete a circuit with a 9v battery that seemed to do the trick.
Then just some basic code on the Arduino just to tell the winch to run for a few seconds when the alarm pin was triggered. I also threw a big red button into the mix as a cut off for the battery in case of catastrophic failure.
Step 5: Extend the Duvet
The duvet didn't reach to the barrel so it was necessary to extend it a bit. I had a spare sheet that was close to retirement that with a little trimming and stitching did the job nicely.
I attached it to barrel with a batten...it wish I'd taken the time to do it in a way that wouldn't be such a pain to take off for cleaning, but c'est la vie.
The final problem was that I'm a cat man, and I didn't want my mog getting mangled because she was sleeping somewhere stupid. So, I finished off the project by making a shelf/cover for the foot on the bed.
And there you have it! If you've enjoyed this 'ible please check out my other projects, or hook a fella up with a follow over on instagram for updates on what I'm tinkering with... www.instagram.com/1upliving
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    12 Discussions
    midiansangel
    1 year ago
    Now, this has to be the daftest, yet most useful bit of kit I have ever come across! It's amazing!!!
    What a fun project, I wish I'd thought of this when my kids were growing up. They could have done with this.
    Brilliant idea. Keep up the good work :)
    DreamDabbler
    1 year ago
    Thanks for the great laughs! I think you could do without the Arduino if you just let the winch go until you turned it off, and that might be more incentive to wake up. You'd want to be sure the end of the duvet didn't keep flapping against the floor, though. Or you could add a sensor and kill switch that would activate when the end of the duvet went off the bed. Love the barnstorming approach to problem solving! Well done!
    1up LivingDreamDabbler
    Reply 1 year ago
    Thank you! The Arduino was more to even out the fluttering circuit from the alarm hammer, but yes, it would probably still work without it.
    nwaskow
    1 year ago
    Well. Done.
    annrrr
    1 year ago
    This video is hilarious! Although I was worrying about safety features so glad it seems like you've thought that out some!
    1up Livingannrrr
    Reply 1 year ago
    I don't know about making it safe, but it won't mangle the cat!
    Eric Brouwer
    1 year ago
    This is cool. I will show this to my colleague, who is hearing-impaired. Maybe we can get him to work on time :) :)
    dbyrd26
    1 year ago
    Probably the most frustrating alarm clock ever. BUT also the most effective.
    kebmoore
    1 year ago
    Excellent idea, entertaining Instructable! Well done.
    I don't need this (I have a beagle who will start licking my toes as soon as the alarm goes off) but my son might. He is the classic "Five more minutes..." pre-teen. Maybe something with a counterweight, a couple pulleys, and a solenoid release. As soon as the alarm sounds, the weight is released and the covers are snatched away. Hmmm...
    JmanNZ
    1 year ago
    Great Video
    This is genius! Pure genius. I need to make one of these for my son. Whahahaha
