ESP-01 Module Programming Board
1,753
22
5
About: Software developer but I love electronics, wood, nature, and everything else as well.
ESP-01 is low cost esp8266 module, with built-in WIFI.
It was created as Arduino WIFI module, but It's more power than an Arduino, than now if you must do a little module to control a relay or some simple digital datalogger It's the best solution.
You can find news or update about this board here.
Step 1: Specs
Exists some variant of this module, but all have a processor L106 32-bit RISC microprocessor core based on the Tensilica Xtensa Diamond Standard 106Micro running at 80 MHz, when you buy one of It you must pay attention only on Flash, some have 512 KiB Flash, other 1MiB
Pin Definition
  • VCC: Power 3.0 ~ 3.6V
  • GND: Ground
  • RESET: External reset signal (Low voltage level: Active)
  • CH_PD: Chip Enable. High: On, chip works properly; Low: Off, small current
  • GPIO0: (FLASH) I/O General purpose IO, If low while reset/power on takes chip into serial programming mode
  • GPIO1: (TX)I/O General purpose IO and Serial TXd
  • GPIO3: (RX)I/O General purpose IO and Serial RXd
  • GPIO2: I/O General purpose IO and Serial1 TXd
Step 2: Programming
As you can see this module haven't on board usb so the easiest way to program is to use a USB to TTL converter, you can find it at 0,50$.
I have some problem with more expensive FT232RL or FT232 module, instead a CH340G or CH340 working very good.
Step 3: Base Connection to Programming
The base connection schema is quite simple, you must put 3.3v on VCC and CH_PD (to power and enable), then put on GND the GND and GPIO0 (the last to put module on programming mode), than connect RX to TX and TX to RX.
Step 4: Configure Your Ide
Than you must configure your Arduino IDE, first you must add new board in Boards Manager.
In the board manager, the board to select is esp8266.
Now you can select generic esp8266 board from the list of board
Step 5: Programming Board
This process is tedious, you must connect then remove connection and so on, and to use all pins It's very tedious.
My solution to this problem is to create a programming board (I'm fan of service board).
The functionality is:
  • External power source to give more ampere to the circuit;
  • a switch to select programming mode and than release the GPIO0 pin;
  • 2 switch to activate RX and TX and than to grant the use of that pin for the circuit;
  • a reset button to start programming.
Step 6: PCB Prototype
Step 7: Milling PCB
I add the gcode file that I used with my CNC, so you can replicate my milling process.
You can find news or update here.
Step 8: Gerber
If you want reinterprete the board you can use the gerber file.
This file can be also used as data to send to service like PCBGoGo(http://www.pcbgogo.com/?code=y) that can create the board for you at very low cost.
Step 9: Etching
I don't use this technique, but a lot of people prefer this type of creation.
Step 10: Result of Milling Process
I'd like to add the result of my old glorious router (created with an epson scanner and printer), quite rough but ok.
There is also a bug fixed by wire (in the file I give you is no more present).
In a few days I hope to add the tutorial to create my new CNC, and the tutorial to create a gcode. This site is a working in progress.
Step 11: PCB Assembly
Now start to assembly the board.
Step 12: How to Use the Programming Board
The usage is quite simple:
First insert esp01 in the board, than connect GND to GND, TX to RX and RX to TX of TTL to USB converter.
Now you are ready to program, I add some usage examples.
Upload a blink file
  • In the board you must set the left switch in programming mode than click the resetbutton.
  • Check that the switch of RX and TX It's in trasfer mode. Than start upload the sketch.
  • When finish put in "use mode" the board to put the programmer pin free, and the button to put TX in "use mode".
  • So you can check that external led blink because BUILTIN_LED is connected to TX pin.
Step 13: Use All 4 Pins of the Board
  • In the board you must set qith left switch in programming mode than click the resetbutton.
  • When finish put in "use mode" the board to put the programmer pin free, and the button to put RX and TX pins in "use mode". So you use all 4 pin to control the led.
Step 14: Use 3 Pins to Control Led and One to Serial Debug
  • Than start upload the sketch.
  • Connect the serial monitor to the correct port.
  • When finish put in "use mode" the board to put the programmer pin free, and the button to put RX in "use mode".
  • So you use 3 pins to control the led and TX to debug the program.
Step 15: Thanks
If you have problem or other write comment or open topic to the forum.
    • Build a Tool Contest
    • Warm and Fuzzy Contest
    • Epilog X Contest
      Epilog X Contest
    5 Discussions
    kamil47
    Question 4 weeks ago
    Nice and useful project. To program ESP8266 01 without programming board is not so easy.
    But anyway, can you provide some schematics? I can follow and trace wires from the breadboard (STEP 5), but I prefer to clearly see how components are connected.
    1 answer
    warhawk8080
    5 weeks ago
    Very Awesome! I used an arduino as a passthru and a 5vdc converter module to program mine as a wifi repeater and as a 3D Printer controller
    This is such a great design...good job!
    xxreefwarhawk8080
    Reply 5 weeks ago
    Thanks,
    I used an Arduino as well.
    To check the 3D printer I was interested in this project https://octoprint.org/.
    In this card is missing a pin dedicated to serial debugging with Serial1 (I publish update on my site www.mischianti.org soon).
    In my work in progress, a Solar panel Inverter web centraline
    ( https://www.youtube.com/watch?v=uInRM3YqIv0 )
    I use a D1 wemos as server REST and Web I have found that the debug pin is really useful when you need of a serial hardware interface.
    warhawk8080xxreef
    Reply 5 weeks ago
    Oh yeah...octoprint rocks for 3D printing...I use it on 2 of my printers...I just wanted a wifi board and pronterface...
    It's amazing how much can be accomplished with such a tiny little board
