ESP8266 WIFI Remote Relay Switch
17,537
152
4
About: Software, electronics, do-it-yourself
In this tutorial I will show you how to convert an old power strip into WIFI remote control. This will allow us to control electrical devices from the Internet via HTTP. For example we will be able to turn on and turn off a heater, fan or light over the internet. To build i will use a popular electronic circuit ESP8266 D1 mini. ESP8266 is a good platform for iot (the Internet of things)
This article can also see here:
Supplies:
Step 1: Components
  • ESP8266 D1 mini
  • Power strip
  • Relay Module 250V 10A
  • AC-DC buck step-down module 220V turn 5V
  • Button switch
  • Some wires
Step 2: Preparing the Power Strip
At the beginning I removed the broken switch and everything cleaned.
Step 3: Measuring and Cutting
I measured and cut the plexiglass board for electronic circuits. For cutting I used Hot wire foam cutter from the previous project. Follow this link to see how I built this tool.
Step 4: Drilling
I drilled mounting holes, for plexiglass board. Then I mounted the plexiglass board inside the power strip.
Step 5: Scheme
Step 6: Mounting the Plexiglass Board
The next step is assembling the plexiglass board and electronic circuits together.
In this project, I only use one relay to control power strip.
Step 7: Mounting ESP8266
Because my power strip is made of metal, I'm afraid there might be a problem with the WIFI connection.That's why the ESP8266 is assembled inside a plastic case and screwed to the power strip.
Step 8: ESP8266 Flashing Firmware
I had a problem with flashing firmware. My version of the ESP8266 D1 mini has something wrongwith the RST pin, it does not work. That's why, I disconnect the USB cable from the computerinstead of using the RST button. In this article, step by step, I described the entire software flashing procedure.
SONOFF - ESP8266 Update Firmware With Arduino IDE
Download source code: ESP8266_on_off.ino
Before you upload the software to ESP8266 setup your WiFi connection.
#define WIFI_SSID ""
#define WIFI_PASSWORD ""
Step 9: Testing HTTP Server on ESP8266
  1. Open serial monitor in Arduino IDE.
  2. Get your server IP from serial monitor.
  3. Now open WWW page in your browser.
Now we can control the power strip using the web browser, we can also use the button on the plastic box.
Other related projects:
SONOFF - ESP8266 update firmware with Arduino IDE
ESP8266 and multiple temperature sensors DS18b20 with HTTP server
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    • Party Challenge
      Party Challenge
    4 Discussions
    martinvandiemen
    Question 11 months ago on Introduction
    Hi sir is build esp8266 remote switch , but I get just as in the video 1 switch to operate.
    Can u advise what I have to add to the http software from the esp8266
    to get the other 3 switches in and work
    So i can operate them to.
    Regards, Martin .
    StanisławN3
    Question 1 year ago
    Can you reupload sketch?
    m.alip
    2 years ago
    I made smth similar. And then I didn't use it cuz local ip connection just not convenient enough.
    adachsoftm.alip
    Reply 2 years ago
    Hi, thanks for the comment. This is a right, the use of ip is not very comfortable. Instead of ip, you can also use HOST_NAME.
