ESP8266 WiFi Analyzer
41,015
340
39
About: Make it yourself if you cannot buy one!
This instrucatables show how to make an ESP8266 version WiFi Analyzer clone.
Step 1: What Is WiFi Analyzer?
WiFi Analyzer is a handy app in Android, it help to visualize the WiFi signal information around you. It is very useful for helping select a right channel for setting a new AP. If you selected a channel that as same as another AP near you, you may encounter interference and degrade the network performance.
However, you may not have a Android phone in hand and it is a little bit overkill dedicate an Android phone for WiFi scanning. ESP8266 is good enough for scanning WiFi signal, let's make this handy tools together!
Step 2: Preparation
ESP8266 Board
I am using NodeMCU this time, any ESP8266 board that have SPI pins is ok
Display Board
I am using a 2.4" ili9341 board this time, 320x240 resolution is good enough for visualize WiFi signal information
Others
Some bread boards and pin connectors
Step 3: Connection
LCD VCC   -> Vin / 3V3
LCD GND   -> GND
LCD CS    -> D8
LCD RESET -> RST
LCD D/C   -> D1
LCD SDI   -> D7
LCD SCK   -> D5
LCD LED   -> 3V3
P.S. : Adafruit ili9341 library does not require connect LCD reset pin, but this pin should pull up to make it works. At the same time it is better reset the LCD display when the MCU reset so I direct connect both reset pin together.
Step 4: Deploy Program
Download the program from GitHub and program to ESP8266 board:
https://github.com/moononournation/ESP8266WiFiAnal...
If you are not familiar program ESP8266 with Arduino IDE, here is a good instructables:
https://www.instructables.com/id/Programming-ESP82...
Step 5: Happy Scanning!
It's time to scan WiFi signal around you and share what you have done to your friends!
3 People Made This Project!
  • Build a Tool Contest
  • Pocket Sized Contest
  • Weaving Challenge
    Weaving Challenge
39 Discussions
stankhunt666
Question 22 hours ago
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Abed Herrera\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\ESP8266WiFi
Using library SPI at version 1.0 in folder: C:\Users\Abed Herrera\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI
Using library Adafruit_GFX_Library at version 1.4.6 in folder: C:\Users\Abed Herrera\Arduino15\preferences.txt\libraries\Adafruit_GFX_Library
Using library Adafruit_ILI9341-master at version 1.3.3 in folder: C:\Users\Abed Herrera\Desktop\arduino-1.8.8\libraries\Adafruit_ILI9341-master
exit status 1
expected unqualified-id before '{' token
Invalid library found in C:\Users\Abed Herrera\Desktop\arduino-1.8.8\libraries\ESP8266WiFiAnalyzer-master: no headers files (.h) found in C:\Users\Abed Herrera\Desktop\arduino-1.8.8\libraries\ESP8266WiFiAnalyzer-master
Invalid library found in C:\Users\Abed Herrera\Desktop\arduino-1.8.8\libraries\libraries: no headers files (.h) found in C:\Users\Abed Herrera\Desktop\arduino-1.8.8\libraries\libraries
stankhunt666
1.8.8\libraries\ESP8266WiFiAnalyzer-master: no headers files (.h) found in C:\Users\BLANK\Desktop\arduino-1.8.8\libraries\ESP8266WiFiAnalyzer-master
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
gadgets_guy
1 year ago
I have the exact same display and I'm using an NODEMCU V0.9 board, when trying to upload the code I receive the following error(also I downloaded the current Adafruit_GFX) library files, any suggestions?:
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:67:67: error: section attribute not allowed for 'bitmap'
drawBitmap(int16_t x, int16_t y, PROGMEM const uint8_t bitmap[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:69:67: error: section attribute not allowed for 'bitmap'
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:75:68: error: section attribute not allowed for 'bitmap'
drawXBitmap(int16_t x, int16_t y, PROGMEM const uint8_t bitmap[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:77:76: error: section attribute not allowed for 'bitmap'
drawGrayscaleBitmap(int16_t x, int16_t y, PROGMEM const uint8_t bitmap[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:82:36: error: section attribute not allowed for 'bitmap'
PROGMEM const uint8_t bitmap[], PROGMEM const uint8_t mask[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:82:66: error: section attribute not allowed for 'mask'
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:86:71: error: section attribute not allowed for 'bitmap'
drawRGBBitmap(int16_t x, int16_t y, PROGMEM const uint16_t bitmap[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:91:37: error: section attribute not allowed for 'bitmap'
PROGMEM const uint16_t bitmap[], PROGMEM const uint8_t mask[],
C:\Program Files (x86)\Arduino\libraries\Adafruit_GFX/Adafruit_GFX.h:91:67: error: section attribute not allowed for 'mask'
陳亮gadgets_guy
Reply 1 year ago
Hi gadgets_guy, I have tried program with latest software and source code (Arduino 1.8.5, Adafruit GFX 1.2.2, Adafruit ili9341 1.0.11, esp8266 2.3.0) without any error. You may get update and try again.
陳亮WagnerA6
Reply 7 months ago
Hi WangnerA6, if you are not familiar with GitHub, simply click the "Clone or Download" green button at the right middle and then select "Download ZIP".
n88
Question 1 year ago
Can you use all thing from wifi analizer ? like on the phone?
1 answer
陳亮n88
Answer 1 year ago
use all thing?
陳亮Arduino Tech
Reply 1 year ago
Yes, since I am writing base on Adafruit_GFX, you may use any supported display. Just like my commented ST7735 code at ESP8266WiFiAnalyzer.ino.
wurth51
1 year ago
Excellent project. Quick and easy to make. Nice code work too.
Thanks,
RoyBoy
NeilRG
1 year ago
A wonderful project! I do not think that the person who created this can be held responsible for knowing material costs outside of his familiar area. I wish the nit pickers would stop it!! There are some useful things to be learned here.
Thank you.
NeilRG
yrralguthrie
1 year ago
I see the 32 CYN price. That screen can't be bought for $5 in the US, or likely anywhere outside of China.
DmitriyK10Espasio
Reply 1 year ago
Он же дал ссылку на Гитхаб
yrralguthrie
1 year ago
On AliExpress that particular display is a little less than $14.00 delivery to US. Makes the project in US about $25. Cheaper than I thought. I yield.
陳亮yrralguthrie
Reply 1 year ago
delivery cost is a big proportion on web order, so I always buy more parts for each order to reduce the relative cost. This behaviour make me addicting to electronics ╮( ̄▽ ̄"")╭
Howard Quinn
1 year ago
Greetings
I have just downloaded, wired, compiled, and run the analyser sketch and am getting errors, (see attached first photo), the program was run on 2(two) nodemcu v1.0 and a v0.9 all with same errors. To get the program to work I added lines to your program (see attached second photo), now it works on all of the nodemcu's. I am running Arduino v1.6.9 on Windows 10, can you explain.
