Easy In-Wall Theater Rack
46,587
495
24
Theater racks can be very noisy and distracting to your movie experience...here is how to fix that.
I wanted my Theater Room to be clean a quiet. This In-Wall Rack allows everything to be located anywhere you choose. I chose to put mine in a wall under the basement stairs with the back of the components in the Mechanical Room for easy access.
Please vote for me if you like this or are thinking about making one.
Step 1: Location...Location...Location
I only had a limited amount of space to put the rack in the wall. My issue was that in the mechanical room you can see there is the furnace to the right and a stud running in the center of where I want to put the rack.
My largest component in the rack is the receiver and it is 17" wide. Therefore I wanted the hole for the rack to have at least 1/2" on each side so I needed to make the hole 18" wide. The height is completely up to you. I wanted to add a couple of empty spots in mine so I could expand later on and not have to re-cut the hole.
Step 2: Framing It In
I had to cut the stud that was running right in the middle of the hole I cut out. I also had to add a new stud to the right side of the cutout. Once you do this you must frame the whole thing in. For my design you must have a stud all the way around the cutout and it should be flush with the hole. I will explain why later.
Step 3: Adding Shelves
My intention was to have enough room on both sides of the hole on the inside to just screw in a Dual Shelf Track
like the one pictured from the hardware store. I was able to screw one into the left side but the right side of the hole is flush with the furnace and I don't have enough room for the track. After a lot of thinking I picked up what are called an "over under shelf support". They have 90 degree bends at both ends but I had to flatten one of them out. I then screwed the flatten side into the inside framing of the hole. Then screwed the other end into the bottom side of the shelves. The left side of the shelves were supported with the simple Dual Track Shelf Supports and screwed to the bottom of the shelves.
You will have to mess around with the locations of your components and which notch you locate your shelf on. This would have been a lot simpler had I been able to use the tracks for both sides.
In the last photos here you can see that the shelves have a notch cut out on the left side so the track support can catch the shelf. The right side had to be cut straight because the Over Under shelf support wraps around the shelf
Step 4: Face Plates
For the face plates I went to a local machine shop and asked for some 1/16" aluminum pieces to be cut for me. You want to make them all individual pieces because if one of your components goes bad, you don't want to have to replace the whole aluminum sheet. You only have to replace the one section. You need to make the aluminum pieces at least 1" wider than the hole in the wall. This will give you 1/2" on each side to screw the aluminum plate into the studs.
I recommend placing the first aluminum piece at the top about 1/2" above the hole and centered up with 1/2" overhang on each side of the hole. Use tape and tape this piece really good to the wall. Then repeat with the other plates under this one. This pattern is the best way to prevent gaps between the pieces later.
Once you have all of you pieces taped to the wall add your shelves on the back side and add your first component. Push the component just up to the aluminum piece and trace the profile on the back side of the aluminum piece. Once you do that one move onto the next one until you have all of the profiles traced on the back of the aluminum pieces.
Step 5: Aluminum Cut-outs
This next step is the time consuming one. You need to cut out the profile of each of your components. You can use a Dremel, or drill a hole and use a hacksaw. You want to cut on the inside of your line and intentionally make the hold too small. Then you need to use a file to get the final profile you need for the sheet to slide right over the component. If you find the hole is located too high or too low, you can always make the component taller by stacking something under the feet, or if it is too tall you can take the feet off.
Once all of you components are cut out you can drill a small hole in all 4 corners of each of the aluminum plates. These will be screed into the studs and it will also make it look like a real server.
Step 6: Final Stages
I used a Matte Black spray paint with a slight texture to paint these plates. They turned out extremely well and I am glad I used the textured paint.
Only thing left now is to add trim around the aluminum plates.
I also added 2 angle brackets behind each component so I could not push them inward from the front.
Thank you for taking the time to read this Instructable!
Please vote for me!
  • Pie Contest
    Pie Contest
  • Pocket Sized Contest
  • Tape Contest
    Tape Contest
24 Discussions
suds1
3 years ago on Introduction
i did this think and it is safe now! but i used QSC professional amp because i have a large hall so speakers also pioneer 1000watts & pioneer 3D blu-ray system. i have 2
QSC profes amps & pioneer subwooffer amp& a 1ch qsc professional amp!
Martinlogan
4 years ago
Thank you so much . I found this on Google this morning . And I'm already 85% done . Just need to put the molding and the mat black front panels . Thank you
erik.teichmann
4 years ago on Step 5
Don't take the feet off -- that 1/4" to 1/2" of room is critical to ventilating your electronics. Without that space for airflow, you could overheat and cause damage. Obviously, some components generate more heat than others.
jimvandamme
4 years ago on Introduction
Commercial and professional gear fits in a 19 inch wide rack with standard screw spacings. Look around in the surplus market for a rack, aluminum panels, and hardware.
espdp2
I LOVE the idea of a dedicated home theater room, but I've never lived in a place where I could have one. We'll be moving soon, though. You can bet that I'll be keeping this excellent 'Ible in mind when we're house hunting!
kurtz64espdp2
Reply 4 years ago on Introduction
Thank you! I would love to see your work if you decide to move forward with this.
scaprara
Great ible! I like the low cost shelving setup. Great professional install look without the high dollar cost! I also concur with the other comment about the ease of wiring.
How far are you running the HDMI cable? Did you need a signal booster?
kurtz64scaprara
Thanks for the comments. I used a 25ft. HDMI cable with no booster and it still looks great.
It looks very nice and there are some good ideas presented, but if anyone else decides to do something like this, make sure you verify that it is not a load bearing wall. If it is, there are very specific rules that need to be followed to properly reinforce the wall when you cut out a stud like that.
One advantage to this setup that wasn't mentioned but is very nice, is how easy it is to wire up the system. You just walk up to the back of the rack instead of reaching your hand around from the front.
First, let me say that this is really well done, and very professional looking. I had a couple hints if you want to make things a bit easier. There are professional rack mount parts available from places like Parts Express which might save you some time and money. Here are some rails: https://www.parts-express.com/penn-elcom-r0828-12-...
And shelves to attach to those rails: https://www.parts-express.com/rack-shelf-2u--262-8...
They even have shelves that are perforated so you can zip tie things to it, or shelves that have clamping bars to keep things from sliding around.
The idea with the aluminum sheets is great, but you can also get black countertop laminate and cut that out, it does a nice job also, I usually just attach it with velcro. However, your way would be more durable if the front panel will be removed a lot.
Good job on leaving extra space, that's something even the pros forget to do half the time.
kurtz64JimTheSoundman
Thank you for your input. I wanted to make this from scratch as much as possible but I really appreciate you taking the time to post links for others that might be able to utilalize them. And thank you for taking the time to read my Instructable!
Build_it_Bob
4 years ago on Step 6
Nice work , very clean finish too.
Build_it_Bob
yan03
4 years ago
Nice job !! I have a setup like this into a enclosed "box" and for your audio/video amplifier you shoud refer to your user's manual for the clearance dimensions to have a good ventilation I make a setup like this into a enclosed "box" like you and for your audio/video amplifier you should refer to your user's manual for the clearance dimensions to have a good ventilation. for my denon 3312 and i need 12" clearance into the top.
kurtz64yan03
I was also worried about overheating of the amp in this setup. So once setup i put a thermalcouple inside the amp to check the temperature rise. It actually only went up a couple of degrees from that of being in an open space. This is because of the back being completely open and since its a basement it stays fairly cool (even in mechanical room). I guess it make since because most people would place their amp in an inclosed endertainment system anyways so I dont see this being much worse. But I appreciate your concern and eye for detail. Glad you enjoyed this build.
diecast92
4 years ago
Awesome job! I plan on doing something like this in the next few months and this has helped me a bunch. thanks for doing this!
tcoyle1
Saw this just in time and it gave me a few ideas. I was going to build something like this in my basement for my equipment. Very, very nice job here.
kurtz64tcoyle1
Thanks. That's what makes doing these Instructables worth it. I would like to see yours once you are finished.
