Electromechanical Decimal to Binary to Hexadecimal Converter
11,265
52
14
About: Electromechanical Engineer, Product Designer, Maker. I love to make prototypes and teach others in the process. I graduated from UCF and spent two years working at NASA.
It is using an ESP32 equipped with an OLED display, two mechanical 7 segment displays and 14 relays. I'm using two NXP MC33996's along with the DPDT relays in an h-bridge configuration. To set(display) each individual segment it needs at least a 1ms pulse and to reset the segment it needs to be pulsed with the opposite polarity. This was a proof of concept before I design a much larger clock with 6 digits and 46 relays with two sets of flip dots as colons. The sound is amazing and I could not be happier with how it turned out.
Supplies:
Step 1: Bill of Materials
(1 ×) ESP32 with OLED Display
(2 ×) Mechanical 7 Segment Displays
(11 ×) LEDs - 0805 SMD
(1 ×) Dual Voltage Power Supply - RD-50A MEAN WELL
(11 ×) 180 ohm Resistors for LEDs - 805 SMD
(3 ×) 470uF Electrolytic Capacitors
(2 ×) 47uF Electrolytic Capacitors
(3 x) Momentary Push Button - SMD
(3 ×) 10K Pull-up Resistors - 805 SMD
(14 ×) DPDT Relays
(14 ×) Schottky Diodes - 1.5KE18CA-T - Used as flyback diodes for the relays
(14 ×) TVS Diodes - 1.5KE18CA-T - Used as flyback diodes for the AC segment coils
Here is an overview of the mechanical 7 segment displays:
Step 2: Schematic With PCB Build Files
You can order the board shown in the video from a PCB manufacturer or you can solder it up on your own with through hole components if you'd like with my schematic.
Step 3: Solder the PCB
In this video I use a stainless steel solder paste stencil to perfect put solder where I want. I use a hotplate set to 170C and a hot air gun to solder the SMD components.
Step 4: Program the ESP32 With the Arduino IDE
Download the Arduino core for the ESP32 here:
Download my attached source code and program your ESP32 with the Arduino IDE.
Step 5: Questions?
Thank you for reading my Instructable. Let me know if you have any questions and I will be happy to answer what I can.
Anthony Garofalo(Proto G)
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    • Woodworking Contest
      Woodworking Contest
    14 Discussions
    ripthoofficial
    Question 5 months ago
    Absolutely love this project I just have 2 questions for you. First of all did you order your 7 segments directly from the manufacturer via email? Secondly would you mind sharing your 32-soic breakout boards kicad files so I can breadboard my MC33996s before I make a custom clock? If you've given up on the clock project I'd love to finish it for you!
    Ps I'm enjoying following your delta robot build keep up the good content.
    AnthonyMiller141
    First of all, I’d like to commend you on an amazingly cool project and thank you for sharing an instructable.
    I’m currently an Electrical Engineering student in the US, going into my second Junior semester. I’d love to build this to further expand and apply my circuitry knowledge and it’s always exciting to build a new project.
    I have a couple of questions for you. In the comments, I see a few things that have changed and your long comment about said changes including, “So keep in mind if you want to use these gerbers as is, you will need to rework the board just as I did.” I also see that you mention using your own custom built controller? I have also discovered that the MC33996 chips are obsolete on most sites. I will research a compatible chip. I was just curious if this is something you’ve already thought about.
    Ok, onto my question. With the BOM listed and current schematics on the site, can I build this and have it function? I have done several projects in the past and can get through a challenging schematics. I want to be sure that all of the components are compatible as written. I’m still learning and have much more to learn, so I’d like to check with you before I start purchasing parts and get stuck at 95% completion and may not be able to diagnose where I went wrong on my own.
    Thank you for your time and willingness to help those of us attempting to advance to the next level.
    jondaddio
    Question 1 year ago
    You list the same part number 1.5KE18CA-T for the relays and segment coils, yet the schematic shows a 1N5817 across the relay coils and 1.5KE18CA-T for the segment coils. Should something be different in the parts list from what the schematic shows?
    kd6not
    Question 1 year ago on Step 5
    Anthony - I would be very interested in your proposed clock. Do you plan to do an Instructable on that as well?
    Mark
    1 answer
    BenG30
    1 year ago
    Very Very Cool..
    Just a little constructive critique, your schematic diagram is quite difficult to read, and is fairly cluttered.
    I would have shown a the connection from the chip, through the relay and to the segment on a single continuous diagram, but for just one segment, and make a note that the relay circuit is the same for each segment, and then just list off each segment circuit at the NXP chips.
    This would make it easier to follow and far easier for someone to use and expand for their own projects.
    Proto GBenG30
    Reply 1 year ago
    Thanks, I agree, but I will not be updating that schematic any more but I will try to make the clock easier to understand. Feel free to update the schematic as I have released all the build files including the KiCAD PCB files.
    Proto G
    Reply 1 year ago
    Thank you! Experimenting with 12V proved perfectly fine for me and I have never had a misfire even at full speed. The coils are not heating up at all with my setup even though I am driving them faster than recommended but that may be because I'm using 12V.
    Using relays was used for the sound but they are being used in an h-bridge configuration. Using MOSFETs would be quieter but you wouldn't be able to run the segments any faster because I'm already running them faster than recommended.
    The schematic in the instructable is updated to include rework I had to do and improvements I made. MC33996 reset pin needs to be connected to reset of the ESP32 or 3.3V. I added shottky diodes to the relays and TVS diodes to the individual segment coils. Also changed the SOPWR pin on the MC33996 from 12V to 3.3V. So keep in mind if you want to use these gerbers as is, you will need to rework the board just as I did. The footprint on my ESP32 board was mirrored as well so I had to add the protoboard with the pins swapped.
    I also thought I didn't need the TVS diodes or the schottky diodes either because the MC33996 has internal protection but I was wrong. The relays and segment coils have spikes of over 300Volts without the changes I made. Both NXP chips partially failed the first time I powered the board up. In the video where the digits are being driven at maximum speed, repeatedly slamming those chips with 300V isn't good. Now they're below 50V spike which the chips are rated for and everything is working perfectly.
    Gawron
    Question 1 year ago
    Are relays obligatory? I mean, they are very expensive - can't we use transistors in H bridge configuration?
    1 answer
    Proto GGawron
    Answer 1 year ago
    The relays are not necessary and are purely a aesthetic decision and the digits could just as easily been driven with an MC33880 operating as an SPI octal h-bridge. The relays are currently used in an h-bridge configuration.
    Proto Ggarthdb
    Answer 1 year ago
    No, I made my own controller.
    tlow1
    1 year ago
    I don't even know what the title of this instructable means, but I'm sure its very impressive. I clicked the link in hopes to learn something, but this is just way over my head. I get that you're using flippy numbers to make a clock that clicks... and something to do with binary. LOL. That said, I do think that the resulting clock will be really freaking cool and I hope that when all is finished, you add a video of that. It looks cool, it sounds cool... and thank you for the video explaining the 7 segment displays and your plans - it helped a dummy like me get the gist of what you're trying to do.
    I'm going to have to spend hours now researching "electro-mechanical" and "hexadecimal". I did about 30 seconds of research on them and am more confused than when I clicked the link.
    Anyway, just wanted to say good job, and I think the end result is going to be awesome and I'm actually sorry that I'm not able to fully appreciate it.
    Bionicjoetlow1
    Reply 1 year ago
    https://www.youtube.com/watch?v=9xbJ3enqLnA
    Hex is a base-16 numbering system.
    People use base-10 because we have 10 fingers.
    In base 10 there are ten symbols: 0, 1, 2.....9. When you get to 9 you run out of room so you put a 1 in the tens place. Repeat this process until 99. Add a hundreds place, etc.
    In hex there are 16 symbols: 0, 1, 2,....9, a, b, c, d, e, f
    a = 10, b = 11, and so on until f = 15.
    So when you get to 15 (f) you move over to the sixteens place. So "10" in hex actually equals 16. a0 equals 160 (the a is worth ten, but it is in the sixteen spot). a1 = 161, a2 = 162,......FF = 255
    Why do this?
    Hex is a better way to represent binary, a base-2 system. It only uses 0 and 1. So 10 in binary equals two. 11 = 3. 100 = 4.
    Computers & electronics work by turning bits (transistors) on (1) or off (0).
    If you've ever seen a computer crash it spits out stuff like 0xffa0dfff. These are memory addresses
    FF is 255. In binary it would be written as 11111111. This is an 8-bit address.
    FFFFFFFF is a 32-bit address. Imagine trying to read a string of 32 ones & zeroes.
