Electronic Organism Diverts Attention With Pretty Light, Steals Joules
20,754
67
37
About: Design researcher, DIY enthusiast, storyteller, admirer of robots.
Mischievous little organism distracts with bright light while stealing joules from batteries, especially ones thought to be dead! Trap one and rest easy knowing your batteries have been squeezed out of every drop. Careful! It has a talent for shining it's bright light at you, which at the right angle could be blinding, or mildly annoying.
suitable for nimble fingers and and a good work ethic!
Step 1: Internal Organs
Time to obtain body parts:
1 x Prototype board (cut down to 2cm x 2cm square)
insulated wire ( in exotic colours!)
1 x Ferrite core
1 x 1K resistor
1 x 2N3904 transistor
1 x Superbright LED (blue or white)
1 x single AA battery holder
thin PVC sheeting (for observation box)
Step 2: Make a Heart!
Now if this little creatures body is going to work, it'll need something to pump life into it!
using to contrasting strands of insulated wire, wrap together around the ferrite core. When it's filled up (about 8 turns) twist together two alternate wires from each side.
Step 3: Transplant...
-Fix the three wires (veins) coming from the core into the prototype board (our skeleton).
-Add the resistor to the board, soldering one of it's leads to one of the single leads coming off the core.
-Insert the transistor into the board. Attach the other resistor lead to the middle transistor lead.
-insert the LED through the middle of the core and through the prototype board.
-With the positive (longer lead) side of the LED on the right facing the flat side of the transistor, solder the outside transistor leads to the LED leads.
-Solder the remaining single wire coming off the core to the positive LED lead.
-Solder the negative battery holder wire to the negative LED (flat side) lead.
-Solder the positive battery wire to the double wire off the core.
Step 4: Contain Your Organism!
Better contain your creature so it doesn't sneak away...
-Make up a net: this one was length: 60mm x height: 30mm x width: 35 mm
A bit bigger than a match box.
-Use a scalpel to cut out of PVC and lightly score the fold lines.
Step 5: Make an Army!
Be careful, they have a way of finding each other! Together their light is even more momentarily distracting, but think of all the batteries to be cleaned!
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    37 Discussions
    GitarGr8
    8 years ago on Introduction
    Kinda look like robot eyeballs. Nice job, but the engineer side of me cringes in your lack of an electrical schematic. I know it's an easy circuit and all, but the point of an instructable is to make it easy for someone to learn how to make things. /soapbox
    GitarGr8madrobot3600
    In case you haven't found an answer yet, you absolutely need the ferrite core, it's a main ingredient in creating a "joule theif".
    BlondGuy101
    9 years ago on Introduction
    Why is it that the LED must be white or blue only? All the other instuctables and other sources also mention that, but none say why so far as I can see. Also, where can I salvage the requsite transistor and resistor? I'd like to make one but my electronics shop doesn't stock those so far as I know. I prefer to salvage anyway. Thanks in advance for your consideration
    zimmemic25
    i have a few questions: what do i need the ferrite cote for? i think its a coil, but why do we use it? couldn't i just add a resistor&LED to a battery for the same effect? can you tell a bit more about wiring the coil? i didnt really understand which wires to solder to which parts
    spline9zimmemic25
    Its called a Joule Thief. A clever little circuit. Look here for more details and excellent instructions;<br/><a rel="nofollow" href="http://www.evilmadscientist.com/article.php/joulethief">http://www.evilmadscientist.com/article.php/joulethief</a><br/>The Make vid is the first link in the article. <br/>
    petitjosdu91
    10 years ago on Introduction
    Can you please tell me where do your ferrites cores come from? I only found some really little ones on an old radio poste, and don't know where to find biggers =s. It makes a really nice joule thief.<br/>
    many times you can find really big ones in computer power supplies, but cd players, radios, etc. also have them.
    ReCreateMatanSilver
    Its a ring of a metal-ish material...It Came From a PSU and Had coil wrapped around it...there where like 5 cables coming out of it,that where connected to the coils...it looked allot like what is in those pictures
    MatanSilverReCreate
    Yeah, it is a ferrite. I found a few itty bitty ones in a cd player. these small ones can be used in ultra-dense versions of this exact circuit, and people put thes tiny circuits in torch lamp cases, to make joule theif led lamps, that fit into old-school torches.
    osgeldsysadmn
    yes fluorescent lamp ballast (probally not large ones inside of CF's tho)
    high powered stereo equipment can have them measured in inches
    computers motherboards (stop those numbskulls from tossing that PII in the dumpster)
    power supplies
    or most electronics that can be found at the Goodwill or similar thrift shops (i love goodwill, 2$ for a 1990 power amp = loads of parts)
    also most computer cables have ones that are more cylindrical, like that big chunk of plastic @ the end of a vga cable, ... most of those are considered chokes to help suck out weak interference but its the same material. Cut it up with a hack saw and 1 old vga cable might produce 4-8 cores
    petitjosdu91osgeld
    Thanks a lot, I found a really big one on an USB cable, but not on stereo equipement (I only have a (very) little radio poste) and don't have any computer screen right here, so I won't dimount one for a long . Moreover, I don't know if it's because I'm french, but I opened up two transfos (or power amps), one with a french plug (230 V - 50Hz), the other with the USA plug (don't know the spec.). On the Usa's one, there was a lot of electronic parts, but not on the french one, and it was the same for Fluorescent lights : Mine don't have any ferrite cores.
    you can get a huge one on a computer screen, it is wrapped around the glass tube just under all the circuitry.
    hominidpetitjosdu91
    I've seen these available at Dick Smith Electronics (Au) but in USA I suppose that Radioshack would be the same. If all fails they are in the base of compact fluoro lights. Cheers, Hominid.
    petitjosdu91hominid
    Yes, all fails I just found some ferrite sheets inf form of "E" (that are assembled with some glue and make aferrite core) and them in the radio are too little ones. I'll see what are "fluoro lights" (I'm french and didn't understood) but really thank you for your help All
    hominid
    I get the impression that folks think that bigger is better w.r.t. toroids, but the whole point is to miniaturise by using the tiniest ferrite cores you can get.
