Elevated Garden Planter
5,402
100
15
Published
Introduction: Elevated Garden Planter
About: My name is Mitch. I make videos about the things I make and what I learn along the way. I have a Youtube Channel called Made by Mitch. I also love the coffee and the outdoors.
This was a very simple DIY project that you can make in just a few hours. Last year we had a very nice garden with lots of things in it including lettuce. The only problem was that the rabbits also really enjoyed the lettuce. So this year I decide to make an elevated garden planter for my lettuce and herbs.
Step 1: Tool and Materiels
TOOLS
  • Circular Saw
  • Table Saw
  • Drill and Impact Driver
  • Wire Snips
  • Staple Gun
MATERIALS
  • (3) 1x6x8 Cedar Boards
  • (1) 1x4x8 Cedar Board
  • (2) 4x4x8 Board (cedar if possible)
  • 2” Wood Screws
  • ¼” x ¼” Galvanized Steel Fencing Wire
  • Landscaping Fabric
  • Raised Bed Garden Soil
  • Plants or Seeds
Step 2: Cut the Boards
The first thing I you will have to do is cut the boards you are using into the size you are wanting your planter to be. I first cut the cedar boards I used for the sides using a circular saw. I made my box two foot wide by four foot long. I cut 4 boards at 24” and 4 boards at 48” long. I actually used 1x6 paneling boards for the sides of my planter. The boards are tongue and groove and I used two boards on each side and each end of the planter box. I cut the tongue off of the top boards and the groove off of the bottom boards so the boards would be smooth on the top and bottom.
Then I cut the 4x4 boards to 30” long using a circular saw. My saw blade wouldn’t go all the way through board so I marked both sides with a speed square, cut one side, then flipped the 4x4 over and cut the other side.
Step 3: Attach the Boards to the Legs
Attaching the boards to the legs was pretty simple. I basically assembled the box upside down. First I used clamps and a speed square to attach a side and an end board to the leg making an L shape. Make sure when you do this you are checking that everything is lined up properly. This is why I used the speed square. I made two L shapes and then put them together by adding the opposite legs and attaching the boards to the legs. To attach them I pre-drilled so the wood wouldn’t split and then attached the boards using 2” wood screws. Once I attached the first row of boards around, I then put the second boards on top all the way around and attached it pre-drilling and screwing them to the legs.
Step 4: Add Wire to the Bottom to Hold the Dirt
Next I added the wire to the bottom of the planter but before I could do this I added 5 1x4 boards to stretch across the width of the planter box. This would help support the weight of the dirt. I pre-drilled and screwed the 1x4’s to the bottom of the planter spreading them out evenly. Then I flipped the box over and added the wire. I used ¼” x ¼” galvanized steel fencing for this. It was pretty easy to install. I just cut it to length using wire snips and then cut out where the 4x4 legs would need to be. I had to bend it and move it around a good bit to get it to fit where I wanted it to and then I used a staple gun to secure it in place.
Step 5: Fill With Dirt and Plant
At this point the planter was pretty much finished. I added a layer of landscaping fabric so the dirt would stay in the planter box. I used scissors to trim the access around the edge. After it was in place, I put 2 bags of gardening soil in the bed and then I added the plants. I just had a few herbs to put in mine and for the remainder of it I planted lettuce from seed. After doing this the planter box was complete!
Step 6: Video
Be sure to check out the video for the entire process. It was very simple to make. If you are interested in this project, you may enjoy some of the other DIY projects I have available on my website. You can also follow me on instagram and twitter to see what I’m up to on a regular basis. Thank for checking this out. I hope it is useful for you.
Website - http://madebymitch.net
Instagram - http://www.instagram.com/made_by_mitch
Twitter - http://www.instagram.com/made_by_mitch
  • Oil Contest
    Oil Contest
  • Creative Misuse Contest
  • Stick It! Contest
    Stick It! Contest
15 Discussions
1.Hola es un trabajo excelente, mis felicitaciones!!!
tengo una consulta, como haces para que la madera no se pudra, ya que las plantas para lo que ,lo voy a realizar son de exteriores asi que recibira tanto agua de riego como de lluvia.
Gracias, por compartir tus trabajos.
Saludos Natalia
1 more answer
Yes I have the same question actually. How does this hold up in wet weather? Plus the wet soil itself, I'm thinking the wood will rot in no time.
Very cool John! Thanks for sharing. I like yours a lot. How have the 2x4 legs held up?
Thank you Madebymitch, The 2x4 legs are doing fine, but they are sitting on a disused side walk in the front of my house that is facing South. I took the pictures against my neighbours fence, (it was less cluttered) so that is why it is sitting on the ground. When I make something that is in direct ground contact, I use a wood preservative, like is shown in the Instructable about the saw horses I made. I like the use of the galvanized fencing at the bottom of your planter. Keep up the good work.
I like the idea of (galvanized) screen beneath the fabric. Virtually all the designs I've seen use a complete floor or inserted container(s), both with drilled holes. This is a lighter, easier, less expensive technique and is definately strong enough while still having good drainage. I'll be using method in mine.
Thanks Philbert! It has worked surprisingly well. I will definitely use this method the future.
Even though there is garden paper at the bottom, if you have this over concrete, like in the picture; you will soon have a blackened area underneath from fine particles dripping through. That will be followed by a green moss... because if you keep that watered properly, you are going to maintain a nutrient rich, damp area right under the planter...
I believe the landscaping fabric used is some kind of rubber, so the drip through might not happen for decades. :)
Thanks for pointing this out Joecutolo. I will keep an eye out to see if it darkens. If so, I can easily move it. Thanks
If you use construction screws they are coated for weather and you dont have to pre drill and wont split the wood due to a special thread design.
Thanks for sharing this DabblerD. I didn't realize that. I always predrill to be safe. But now I know. Thanks!
Very good instructable. Great video, impressive editing. What do you use to do the editing?
I’ve built a few elevated planters like this. Here is what I ran into: you cannot plant peppers, tomatoes or other tall plants and reach the plants to tie them or harvest. It’s awesome having them elevated until the plants grow. I would love to see a way to lower these closer to the ground as the plants grow.
Very nice! But just a word to the wise...
I built something similar a few years ago. I turns out that ground hogs can climb up those legs! I was astonished to actually see it happen. For readers in ground hog territory, beware.
Happy gardening!
