Debossing (embossing / Letterpress)
112,759
453
29
A short instructable on how to do own debossing die and how to deboss into paper and other materials.
Done at Edinburgh Hacklab - time needed - about 4 hours (including trial and error).
Equipment, software, ect. needed:
- CNC Milling Machine + software + milling tools
- Piece of material for the die (plexiglass/hardwood/aluminium...)
- Press or vice
- piece of paper, journal or paper notebook for embossing
- tape
- Dremel (optional)
Supplies:
Step 1: Creating a Die Template
The die will be cut using CNC milling machine
I have downloaded the bitmap logo of Edinburgh Hacklab, imported into SolidWorks and made a new part where the logo was cut into a piece of solid body - exactly as it would look like on a final product. Now, to make the die, the template has to be mirrored.
This is easy with SolidWorks - use Cavity function from Mold functions. This will create a perfectly mirrored part which you can use to generate G code for milling machine.
To generate the G code I have used Cut3D - it is very simple and absolutely appropriate for this type of work. And is cheap!
Generate the G code and save into file - to be loaded into CNC control software.
Step 2: Mill the Die Out
Load the G code into your CNC milling software and set up the milling machine. You can use almost any material which can stand a bit of pressure - like hardwood, plexiglass or metals. I have used 5mm plexiglass and my model was 40x40mm in size.
The CNC milling machine at Edinburgh Hacklab is controlled by EMC2 (LinuxCNC) runnig on Ubuntu (RT).
Step 3: Finish the Die for Embossing
Finish the die so it does not contain any borders and can be easily pushed against the paper in the press.
I have used Dremel to remove the rest of the material.
Step 4: Embossing
Use vice or press to press the die against the material you want to emboss. Mind the position of the die - transparent die is great because you can check whether the final design will be properly embossed onto the final material.
You will have to experiment here. Use different materials to emboss, however make sure the material is always laid onto a soft(er) base so the die can actually push the material into the soft foundation to make a nice emboss.
Step 5: Final Product
Enjoy your products.
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    29 Discussions
    JustinB3
    4 years ago on Introduction
    Can you tell me what kind of vice/press that is. I am having trouble finding one that size but it looks like the size I would need for my project?
    AlexDima
    Interesting, but I have a question, is it possible to use the dye with heat for embossing with gold hot foil!? thanks!
    Lethrwolf
    6 years ago on Introduction
    very nice... but where would the average person get a milling machine and use it enough to be worth the price. On another note, it has already been said that this is a 'deboss'. Just to let those that do not know the difference; a debossed image is pressed into the material with one die and an embossed image has two dies, a raised image die on the bottom and a mirrored inset image on the top (male and female, if you will), when pressed, the raised image on the bottom presses the material into the recessed image on the top creating a raised image on the surface of the material, instead of a recessed image as shown in these pics..... just a little leg wetting fact you can pass on to your grandchildren....
    maco22Lethrwolf
    Reply 6 years ago on Introduction
    I have build my own CNC machine several years ago and using the one in hacklab just because I moved my house recently - it is a great machining / DIY / electronics / 3D modelling experience - you learn a lot by building your own CNC and you can do that for a relatively low price ($1000 or so)
    DavidKaineLethrwolf
    Hackerspaces often have small CNC equipment available... you can ask someone to cut your project or even better, work with them on learning how to program/operate it. It's a whole lot of fun. If you don't have a hackerspace in your area, you may be able to find a machine shop that will mill your piece(s) for you, though you might end up paying a bit more for their time. At the very least, you can find someone on the internet with the equipment and have them cut your piece and mail it to you.
    LethrwolfDavidKaine
    looked them up and thee are only 2 in AZ .. both quite a distance from me. I have had dies made from a place here in phoenix that cuts them, but they are fairly expensive... can you use those two words together? $60 for a 4 x 5 or less. when I have a die made I usually do several to make it worth while. Thanx
    togo1919
    Beautiful!
    An inspiring project for business cards - I am considering something similar in acrylic that can be rastered/etched with a laser.
    maco22togo1919
    Im not sure if using laser would be good enough. You need sharp edges on the die to make nice-looking emboss and also would probably take ages to do at least 1mm laser cut into acrylic with laser. But maybe you can completely cut the logo/letter out from acrylic and then glue it onto a base for debossing.
    togo1919maco22
    That would be the technique. For example, I can cut the design shapes from 1/4" acrylic and set them into a stencil block of the same shapes. The block could be of 1/8" acrylic. I could glue these onto a thicker base of wood or acrylic.
    maco22togo1919
    maybe place those two acrylics on top of each other and try to cut the 1/4 acrylic so you cut through it and at the same melt the 1/4 to the 1/8 block. really depends on the design.
    togo1919maco22
    ckevinb2001
    Very nice. I wonder if you could 3D print the die. (Sorry can't make myself stop... that's debossing in the pic).
    maco22ckevinb2001
    Thanks for the correction! Let me know how that went with 3D print - i believe if you use ABS plastic and an industrial 3D printer this could work. The issue is, that the edges will probably be not sharp enough to make a nice edges on the deboss. You really want to focus on the edges on the die as they make the most of the work.
    Wazzupdoc
    The "letterpress" moniker is a bit misleading as that is a specific type of "ink,paper,steel" printing press. That said, good job on the embosser!
    maco22Wazzupdoc
    As ckevinb2001 mentioned - it is actually a debossing technique. For me the letterpress is actually any technique which changes/touches the paper with intentions to make letters visible on it - either printing (historically the proper letterpress) or embossing/debossing. The world is changing and to sustain the techniques we need to sacrifice a bit of a tradition. There is no way this article would be so popular if i did not name it the way I did and much less people would start to be interested in the actual methodology.
    maco22bfk
    Its a cheap desktop mill converted into CNC mill. Simple and cheap.
    booga007
    6 years ago on Step 5
    Very cool, thanks for the ideas :)
