Emergency Lights
About: Always pass on what you have learned. https://www.youtube.com/yodha4u
Matches are a great way to start a fire when you don’t want to use torch or led lighting, but their short burn time makes them terrible when you just need a little light. Here’s a better idea: a matchstick box made with tiny matchsticks, In case of emergency use.
Required Items:-
  1. Crimp Tool (Wire Cutter)
  2. Glue Stick and Super Glue
  3. Matchbox
  4. Gel based Candle
This is a fairly simple process and its a good beginner DIY project. For this I am using a crimping tool (wire cutter), glue stick,super glue, matchbox and gel based candle, generally it went great and I am very happy, I hope you like this project.
Step 1: Things Required
These items are required for making this tiny emergency light.
Step 2: Cut the Match Sticks
Cut the Match stick with wire cutter, I'm Using crimping tool for cutting.
Step 3: Add Glue to Sticks
Adding glue and make a blocks of 4 sticks.
Step 4: Join All Pieces
Now join all pieces and make a rectangular like shape.
Step 5: Use Super Glue and Attach Matchbox and Gel Candle
On corner and gaps add super glue for better grip, and attach matchbox in front and candle on back side.
Step 6: Final Product
This is the emergency lights, I hope you like this project. Thanks!
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
