Fallout 4 Bottle Openers!
19,228
342
18
About: Come spend some time in the shop. I'm a hobbyist woodworker and professional computer geek in Northern California. I guess my projects will vary widely, and I have no clue what I plan to make next...
I've been playing a LOT of Fallout 4. Yes, I've got the Shishkabob from the Forged and Grognak the Barbarian's axe and costume. I've digested dozens of bottles of Nuka Cherry and now I need to bring a little bit of that fun back into the real world...
Step 1: Raise Your Agility Score First!
I started with a couple scraps of hard maple. They need to be at least 3" square, but a bit over is fine.
Find center on the pieces by drawing two straight lines from opposing corners. Where they meet is your center line.
Now for holding these on the lathe I'll be using a chuck with a set of pin jaws. These are expanded into a hole and create ample force needed to hold the blank while turning.
I used a 35mm forstner bit at the drill press and drilled down about 1/4" or so. Any bit in the range of 1" - 1 1/2" should be more than large enough for most pin jaws.
Step 2: Pick the Workbench Perk!
After turning the blank into round with a roughing gouge, I switched over to a round nose scraper.
I gave the piece a steep angle to the sides until my eye thought it looked like a bottle cap. I avoid too much measuring at the lathe, and prefer to just turn till it feels right.
The maple I used was 1" thick material. This seemed a bit on the heavy side after turning ( I think 3/4 or even 5/8 would have made a better choice) so I removed about 1/4" off the top and called it good.
It's a pretty simple turning, and it was already beginning to look like a bottle cap. Now just sand it smooth (about 220) and lets move on to shaping.
Step 3: How's Your Melee Rating?
l used my Dremel with a small sanding attachment, and fine grit paper, to shape the sides into what I hoped looked like bottle cap crimps.
My lathe has an index feature. It simply means that it will lock the head stock in 12 evenly spaced points around the diameter of the spindle.
360°/12 point = 30° between points.
Since I only have a twelve point indexer on my lathe, the spacing on the bottle cap crimps is a bit large, but I think it still gives a good indication of the look I was going for.
I also struggled a bit getting the shape the way I wanted it. With a few more of these under my belt, I think I'd get it closer. Regardless, I more than happy with the shape I got.
Step 4: Science Lvl 1
The next step is to drill a recess for the bottle opener lever. In this case, I am using a steel washer secured with a wood screw. Keep it simple! I then drilled out a 7/8 hole that overlaps the larger hole. I then pre-drilled a pilot hole and secured the flat washer with a #8 wood screw, making sure it is all flush with the back of the opener.
At this point you have a fully functional bottle opener in the shape of a bottle cap. Now… what can we do to step it up just a hair?
Step 5: Add Another Point to Luck!
I first saw this image transfer method on Steve Ramsey’s YouTube channel. I’m not sure who came up with it originally.
I took a Nuka-Cola image I liked from the Internet and used GIMP to reverse the image and scale it to a 2” square.
I then used some wax paper from my kitchen supplies.
I just roughly cut it to letter size and sent it right though the inkjet printer. The trick here is that wax paper will not absorb the ink so it will just sit on the surface of the paper till you transfer it.
Simply press it onto the raw wood and use some pressure to transfer the image. The lighter the wood and more uniform the grain the better this works. Maple is near perfect for this technique, but it should work to some degree on most woods.
After that use some spray lacquer to seal in the image. I used wipe on poly, and it worked, but I cannot recommend it as it was a bit fussy.
Step 6: Quest Completed!
You’re done! Make them in varying themes, or use fancy wood and skip the image transfer altogether.
It’s a great homemade gift or a fun item to use for parties. Add a couple of rare earth magnets to the back and you’ve got a cool refrigerator magnet with a purpose!
Now, It's back to the commonwealth for me. I've got a lot of work to do before I'm ready to save Shaun. Mostly customizing the paint job on my amour....
4 People Made This Project!
  • Arduino Contest 2019
  • Fandom Contest
    Fandom Contest
  • Gardening Contest
    Gardening Contest
18 Discussions
jefflahay
3 years ago
Here's my version. I rough cut it on a bandsaw, finished the circle shape on a belt sander and used a Dremel cone shaped bit for the crimp effect. Then drilled the recesses with a couple forstener bits and attached the washer and screw. The biggest problem was trying to get the wax paper to feed through the printer. I ended up using freezer paper. It works great. Oh, my son loved it! He was really suprised when I told him I made it. Thanks for the 'ible.
JesseW6
3 years ago
Just a note of concern to those who may be uninformed: Wax paper will not fare well in a laser printer due to the hot roller.
hpsm13
3 years ago
Best and safe bottle opener...
tasios
3 years ago
Neat project, from one Fallout nerd to another! Thumbs up!
PS I've been playing every day since release as well, lol, I like the changes they made, but there are a few I don't care for but I still love 4, none the less!
kludge77tasios
Reply 3 years ago
I'm a big fan of everything but the fusion core. I think that sucks!!
Watch me make
3 years ago
How thick is the finished product and could you explain more on the transfer technique
OutlawKtuluWatch me make
Reply 3 years ago
Check out this Youtube video for the transfer technique. I've used it on a couple of projects and it works great. https://www.youtube.com/watch?v=Zq2O66QGCwg
cronosamv
3 years ago
I am such a sucker for Fallout and this idea is a winner for sure. So simple and so very cool!!!
Great job. If i could find my lathe and table saw in my garage I would make some before Christmas.LO! Make sure you use a ss washer and screw, also protect the table saw surface prior to placed cold drinks on it. My is covered.
pcgirl
3 years ago
Fantastic!
FPSXGames
3 years ago
Turned out great, that printing transfer technique is useful. Thanks again.
nancyCpants
3 years ago
Cool project and really good Instructable; I never would have learned about index points otherwise. Thanks for actually explaining things in each step.
smcmasters1
3 years ago
Sorry about all the auto-correct!
smcmasters1
3 years ago
Love it. I've been playing nonstop since release day. Bout jones cola's special edition release of Nyla cola quantum. And tomorrow morning- well later this morning- I'm going to go make myself one of these. Then use it to open a NCQ!
ArticAkita
3 years ago
Awesome! also the bit about wax paper & the ink jet trick!
